adahmen
(ADA)
December 24, 2018, 10:56am
1
After updating my OpenHAB setup from 2.3 (stable) to 2.4 (stable), all my rules inside the experimental ruled engine seems to be deleted.
I found out that there was a change that caused this behaviour.
(see https://github.com/eclipse/smarthome/issues/5884 )
Is there any chance to recover my old rules?
And if not (what I assume): How can I delete my old rules?
I see that they are still somewhere inside OpenHAB (due to error messages during startup) …
rlkoshak
(Rich Koshak)
December 25, 2018, 6:32am
2
In. /var/lib/openhab2/jsondb/backup there are automatically generated backups of the jsondb files. Rules are stored in the file that has rules in the name. Copy the most recent version of that file back to the main folder and that should recover your Rules. If not, try an older backup from that folder.
adahmen
(ADA)
December 25, 2018, 10:03am
3
Thx for this hint.
Will this really solve my problem with older rules. I have the following error message during the start of openhab:
2018-12-25 11:22:20.554 [ERROR] [me.storage.json.internal.JsonStorage] - Couldn't deserialize value 'org.eclipse.smarthome.storage.json.internal.StorageEntry@e62c0'. Root cause is: Unable to invoke no-args constructor for interface org.eclipse.smarthome.automation.Rule. Register an InstanceCreator with Gson for this type may fix this problem.
If I want to get rid of my old rules … can I simply delete this file: /var/lib/openhab2/jsondb/automation_rules.json and restart openhab?
Or just empty the file …
5iver
(Scott Rushworth)
December 25, 2018, 8:56pm
4
I believe there was a format change. There was a related issue in the ESH GH repo… I’ll look for it. There may be a way to reformat them to work.
I’m not sure if deleting the jsondb files will be enough… you may need to clear the cache too.
adahmen
(ADA)
December 25, 2018, 11:10pm
5
Thx in advance.
No need to recover my rules … I need only a way to delete my old rules …
oelles
(oelles)
December 27, 2018, 7:35am
6
Hi there,
I have the same problem after upgrading to 2.4. It seems, that all my rules were deleted. They are not shown in the PaperUI anymore. Nervertheless they are still in the /var/lib/openhab2/jsondb folder but are not executed nor they are shown up in the PaperUI. PaperUI says only “No rules defined yet.”.
Any hints to get them up and running again? Thank you in Advance.
rlkoshak
(Rich Koshak)
December 28, 2018, 1:35am
7
All I can recommend is to stop oh, restore a backup from the backups folder, restart, and seder if that brings them back.
I’ve no idea otherwise. Paperui rules are still experimental, hence the name.
adahmen
(ADA)
December 29, 2018, 6:57pm
8
Not sure why this should work.
There was a change in the way how the rules are stored in the json (at least this is my understanding).
Why should a restore solve this problem?
Ahmed_Saad
(Ahmed Saad)
December 29, 2018, 8:24pm
9
I tried cd /var/lib/openhab2/jsondb/backup and this is the result
So,Can you please tell me what should i do?
1541623535642--automation_rules_disabled.json 1545725727123--org.eclipse.smarthome.core.items.Metadata.json
1541626652024--automation_rules_disabled.json 1545725744139--StorageHandler.For.OAuthClientService.json
1541684597722--automation_rules_disabled.json 1545725744160--org.eclipse.smarthome.core.items.Item.json
1541686325749--automation_rules_disabled.json 1545725744165--org.eclipse.smarthome.core.items.Metadata.json
1541704871054--automation_rules_disabled.json 1545725760380--org.eclipse.smarthome.core.items.Item.json
1541805743527--automation_rules.json 1545725760382--org.eclipse.smarthome.core.items.Metadata.json
1541805887105--automation_rules.json 1545725776742--org.eclipse.smarthome.core.items.Item.json
1541806119535--automation_rules.json 1545725776744--org.eclipse.smarthome.core.items.Metadata.json
1541806162907--automation_rules.json 1545725793906--org.eclipse.smarthome.core.items.Item.json
1541806192543--automation_rules.json 1545725793914--org.eclipse.smarthome.core.items.Metadata.json
1542169269780--automation_rules.json 1545725809984--org.eclipse.smarthome.core.items.Item.json
1542169269807--automation_rules_disabled.json 1545725809992--org.eclipse.smarthome.core.items.Metadata.json
1542389717151--automation_rules.json 1545725826280--org.eclipse.smarthome.core.items.Item.json
1542389717178--automation_rules_disabled.json 1545725826283--org.eclipse.smarthome.core.items.Metadata.json
1543766754426--automation_rules.json 1545725843036--org.eclipse.smarthome.core.items.Item.json
1543766754472--automation_rules_disabled.json 1545725843046--org.eclipse.smarthome.core.items.Metadata.json
1544483089942--automation_rules.json 1545725860712--org.eclipse.smarthome.core.items.Item.json
1544483089969--automation_rules_disabled.json 1545725860721--org.eclipse.smarthome.core.items.Metadata.json
1544489604823--automation_rules.json 1545725876781--org.eclipse.smarthome.core.items.Item.json
1544489604845--automation_rules_disabled.json 1545725876790--org.eclipse.smarthome.core.items.Metadata.json
1545416306857--automation_rules.json 1545725922269--org.eclipse.smarthome.core.items.Item.json
1545416306879--automation_rules_disabled.json 1545725922271--org.eclipse.smarthome.core.items.Metadata.json
1545422998879--automation_rules.json 1545725951622--automation_rules.json
1545422998909--automation_rules_disabled.json 1545725966150--automation_rules.json
1545539512830--automation_rules.json 1545725966168--org.eclipse.smarthome.core.items.Item.json
1545539512863--org.eclipse.smarthome.core.items.Item.json 1545725966177--automation_rules_disabled.json
1545539512865--automation_rules_disabled.json 1545725966179--org.eclipse.smarthome.core.items.Metadata.json
1545539568723--org.eclipse.smarthome.core.items.Metadata.json 1545725988618--automation_rules.json
1545539568729--org.eclipse.smarthome.core.items.Metadata.json 1545726002083--automation_rules.json
1545539568734--org.eclipse.smarthome.core.items.Metadata.json 1545726002113--org.eclipse.smarthome.core.items.Item.json
1545539568740--org.eclipse.smarthome.core.items.Metadata.json 1545726002114--automation_rules_disabled.json
1545539569242--org.eclipse.smarthome.core.items.Metadata.json 1545726002116--org.eclipse.smarthome.core.items.Metadata.json
1545540371621--automation_rules.json 1545726029828--automation_rules.json
1545540371641--org.eclipse.smarthome.core.items.Item.json 1545726052521--StorageHandler.For.OAuthClientService.json
1545540371649--automation_rules_disabled.json 1545726052522--automation_rules.json
1545540371652--org.eclipse.smarthome.core.items.Metadata.json 1545726052538--org.eclipse.smarthome.core.items.Item.json
1545540432463--StorageHandler.For.OAuthClientService.json 1545726052545--automation_rules_disabled.json
1545540493669--StorageHandler.For.OAuthClientService.json 1545726052547--org.eclipse.smarthome.core.items.Metadata.json
1545540493703--org.eclipse.smarthome.core.items.Item.json 1545726070510--automation_rules.json
1545540493707--org.eclipse.smarthome.core.items.Metadata.json 1545726092226--StorageHandler.For.OAuthClientService.json
1545540542413--StorageHandler.For.OAuthClientService.json 1545726092228--automation_rules.json
1545540543602--automation_rules.json 1545726092248--org.eclipse.smarthome.core.items.Item.json
1545542700465--org.eclipse.smarthome.core.items.Item.json 1545726092256--automation_rules_disabled.json
1545542728119--org.eclipse.smarthome.core.items.Item.json 1545726092260--org.eclipse.smarthome.core.items.Metadata.json
1545667160832--StorageHandler.For.OAuthClientService.json 1545726109692--automation_rules.json
1545667160838--automation_rules.json 1545726131295--StorageHandler.For.OAuthClientService.json
1545667160866--org.eclipse.smarthome.core.items.Item.json 1545726131296--automation_rules.json
1545667160867--automation_rules_disabled.json 1545726131323--org.eclipse.smarthome.core.items.Item.json
1545667160870--org.eclipse.smarthome.core.items.Metadata.json 1545726131324--automation_rules_disabled.json
1545667204675--StorageHandler.For.OAuthClientService.json 1545726131327--org.eclipse.smarthome.core.items.Metadata.json
1545667205423--automation_rules.json 1545726150606--automation_rules.json
1545724585513--StorageHandler.For.OAuthClientService.json 1545726172337--StorageHandler.For.OAuthClientService.json
1545724585516--automation_rules.json 1545726172339--automation_rules.json
1545724585534--automation_rules_disabled.json 1545726172359--org.eclipse.smarthome.core.items.Item.json
1545724585534--org.eclipse.smarthome.core.items.Item.json 1545726172368--automation_rules_disabled.json
1545724585537--org.eclipse.smarthome.core.items.Metadata.json 1545726172371--org.eclipse.smarthome.core.items.Metadata.json
1545724637858--StorageHandler.For.OAuthClientService.json 1545726225455--StorageHandler.For.OAuthClientService.json
1545724646804--automation_rules.json 1545752405688--automation_rules.json
1545725420227--StorageHandler.For.OAuthClientService.json 1545752405690--StorageHandler.For.OAuthClientService.json
1545725420229--automation_rules.json 1545752405713--automation_rules_disabled.json
1545725420253--org.eclipse.smarthome.core.items.Item.json 1545752405722--org.eclipse.smarthome.core.items.Item.json
1545725420254--automation_rules_disabled.json 1545752405725--org.eclipse.smarthome.core.items.Metadata.json
1545725420256--org.eclipse.smarthome.core.items.Metadata.json 1545752443965--StorageHandler.For.OAuthClientService.json
1545725443645--automation_rules.json 1545752445468--automation_rules.json
1545725465800--StorageHandler.For.OAuthClientService.json 1545775567948--StorageHandler.For.OAuthClientService.json
1545725465802--automation_rules.json 1545775567951--automation_rules.json
1545725465826--org.eclipse.smarthome.core.items.Item.json 1545775568030--org.eclipse.smarthome.core.items.Item.json
1545725465827--automation_rules_disabled.json 1545775568032--automation_rules_disabled.json
1545725465829--org.eclipse.smarthome.core.items.Metadata.json 1545775568037--org.eclipse.smarthome.core.items.Metadata.json
1545725483913--automation_rules.json 1545776953111--StorageHandler.For.OAuthClientService.json
1545725505447--StorageHandler.For.OAuthClientService.json 1545776953115--automation_rules.json
1545725505449--automation_rules.json 1545776953139--automation_rules_disabled.json
1545725505467--org.eclipse.smarthome.core.items.Item.json 1545776953141--org.eclipse.smarthome.core.items.Item.json
1545725505475--automation_rules_disabled.json 1545776953151--org.eclipse.smarthome.core.items.Metadata.json
1545725505478--org.eclipse.smarthome.core.items.Metadata.json 1545777486682--automation_rules.json
1545725524532--StorageHandler.For.OAuthClientService.json 1545777698834--StorageHandler.For.OAuthClientService.json
1545725526136--automation_rules.json 1545777698838--automation_rules.json
1545725547339--StorageHandler.For.OAuthClientService.json 1545777698864--org.eclipse.smarthome.core.items.Item.json
1545725547342--automation_rules.json 1545777698874--automation_rules_disabled.json
1545725547364--org.eclipse.smarthome.core.items.Item.json 1545777698876--org.eclipse.smarthome.core.items.Metadata.json
1545725547365--automation_rules_disabled.json 1545777730180--automation_rules.json
1545725547369--org.eclipse.smarthome.core.items.Metadata.json 1545777730384--StorageHandler.For.OAuthClientService.json
1545725562335--automation_rules.json 1545779090913--automation_rules.json
1545725573226--StorageHandler.For.OAuthClientService.json 1545779090914--StorageHandler.For.OAuthClientService.json
1545725573229--automation_rules.json 1545779090935--automation_rules_disabled.json
1545725573254--org.eclipse.smarthome.core.items.Item.json 1545779090937--org.eclipse.smarthome.core.items.Item.json
1545725573255--automation_rules_disabled.json 1545779090940--org.eclipse.smarthome.core.items.Metadata.json
1545725573258--org.eclipse.smarthome.core.items.Metadata.json 1545779164906--StorageHandler.For.OAuthClientService.json
1545725580394--automation_rules.json 1545779241971--automation_rules.json
1545725594473--StorageHandler.For.OAuthClientService.json 1546038079298--StorageHandler.For.OAuthClientService.json
1545725594474--automation_rules.json 1546038079300--automation_rules.json
1545725594505--org.eclipse.smarthome.core.items.Item.json 1546038079322--org.eclipse.smarthome.core.items.Item.json
1545725594507--automation_rules_disabled.json 1546038079323--automation_rules_disabled.json
1545725594516--org.eclipse.smarthome.core.items.Metadata.json 1546038079325--org.eclipse.smarthome.core.items.Metadata.json
1545725600439--automation_rules.json 1546038134913--StorageHandler.For.OAuthClientService.json
1545725614543--StorageHandler.For.OAuthClientService.json 1546038135156--automation_rules.json
1545725614545--automation_rules.json 1546045139748--org.eclipse.smarthome.core.thing.link.ItemChannelLink.json
1545725614564--org.eclipse.smarthome.core.items.Item.json 1546052007241--thing_status_storage.json
1545725614571--automation_rules_disabled.json 1546052007242--thing_status_storage.json
1545725614575--org.eclipse.smarthome.core.items.Metadata.json 1546052007243--thing_status_storage.json
1545725619545--automation_rules.json 1546052007601--thing_status_storage.json
1545725633379--StorageHandler.For.OAuthClientService.json 1546052007611--StorageHandler.For.OAuthClientService.json
1545725633381--automation_rules.json 1546052007613--automation_rules.json
1545725633402--org.eclipse.smarthome.core.items.Item.json 1546052007634--org.eclipse.smarthome.core.thing.Thing.json
1545725633409--automation_rules_disabled.json 1546052007642--org.eclipse.smarthome.core.thing.link.ItemChannelLink.json
1545725633413--org.eclipse.smarthome.core.items.Metadata.json 1546052007644--automation_rules_disabled.json
1545725638990--automation_rules.json 1546052007647--org.eclipse.smarthome.core.items.Item.json
1545725652917--StorageHandler.For.OAuthClientService.json 1546052007650--org.eclipse.smarthome.core.items.Metadata.json
1545725652918--automation_rules.json 1546052007746--thing_status_storage.json
1545725652934--org.eclipse.smarthome.core.items.Item.json 1546052049084--automation_rules.json
1545725652941--automation_rules_disabled.json 1546052055445--org.eclipse.smarthome.core.thing.Thing.json
1545725652945--org.eclipse.smarthome.core.items.Metadata.json 1546052055961--org.eclipse.smarthome.core.thing.Thing.json
1545725672154--StorageHandler.For.OAuthClientService.json 1546083249059--org.eclipse.smarthome.core.thing.Thing.json
1545725672171--org.eclipse.smarthome.core.items.Item.json 1546097829309--org.eclipse.smarthome.core.thing.link.ItemChannelLink.json
1545725672182--org.eclipse.smarthome.core.items.Metadata.json 1546100732688--org.eclipse.smarthome.core.thing.Thing.json
1545725691423--StorageHandler.For.OAuthClientService.json 1546101126259--org.eclipse.smarthome.core.thing.link.ItemChannelLink.json
1545725691453--org.eclipse.smarthome.core.items.Item.json 1546101170679--org.eclipse.smarthome.core.thing.link.ItemChannelLink.json
1545725691457--org.eclipse.smarthome.core.items.Metadata.json 1546105675047--org.eclipse.smarthome.config.discovery.DiscoveryResult.json
1545725709481--StorageHandler.For.OAuthClientService.json 1546106999391--org.eclipse.smarthome.config.discovery.DiscoveryResult.json
1545725709505--org.eclipse.smarthome.core.items.Item.json 1546113539604--org.eclipse.smarthome.config.discovery.DiscoveryResult.json
1545725709510--org.eclipse.smarthome.core.items.Metadata.json 1546113969802--org.eclipse.smarthome.config.discovery.DiscoveryResult.json
1545725727098--StorageHandler.For.OAuthClientService.json 1546114545174--org.eclipse.smarthome.config.discovery.DiscoveryResult.json
1545725727119--org.eclipse.smarthome.core.items.Item.json
rlkoshak
(Rich Koshak)
December 30, 2018, 12:54am
10
I have no idea but if the format changed then the files need to be reformatted. I don’t know anything about it right now.
MrCupola
(Mr Cupola)
January 11, 2019, 1:42am
11
Any solution so far? Updated to 2.4 some hours ago… just an absolute nightmare to lose all the rules is a real pain in the ass…
rlkoshak
(Rich Koshak)
January 11, 2019, 3:58pm
12
You can try to recreate one of the Rules and compare the new format with the same Rule in the old format. Then edit the old ones to include those changes.
I realize it is a pain, but you really shouldn’t be using this for production. It is named “experimental” for a reason. It’s not complete. It is full of bugs. It has no documentation.
MrCupola
(Mr Cupola)
January 11, 2019, 5:05pm
13
Yes, was my same idea, but where is the new file? The old one is automation_rules.json and it’s in /var/lib/openhab2/jsondb, but I’m not able to find the other…
rlkoshak
(Rich Koshak)
January 12, 2019, 6:44pm
14
there is no new file. it’s the same fike. it just always the format charged so that OH can no longer read in the old format.
