Expiration timer sometimes fails
OH3.1.0M3 running on centos 8.
I’ve set up an expiration timer on a bathroom fan switch. When it’s set to say 5 seconds it works just fine. I reconfigure it for two hours which is what I want eventually and the fan never turns off. The toggle switch isn’t getting activated by hand, the OH software isn’t being restarted and the system isn’t getting rebooted.
Added: I’m not seeing any state changes in the log beyond the actual physical toggle switching that is being done.
I tried changing the code to 7200 seconds and the fan is still on after five and a half hours.
I’ve tried setting:
2h0m0s
1h59m59s
7200 seconds
None worked
I’ve successfully tried:
5 seconds
10 seconds
1 minute
1 minute, 10 seconds
5 minutes
What’s the trick to getting a two hour timer working to send an off command?
A wild guess. Do you use persistence?
Could it be that ‘something’ is updating your timer items?
Have a look in the /var/log/openhab/events.log
Depending on the device technology, periodic routine updates may be sent. Updates to same state are not shown in logs.
@BiloxiGeek are you using the Expire binding?
Yes, I’m defining the timer in the expiration metadata.
The switch is z-wave, GE 14292 in-wall toggle switch.
Permanently powered zwave device make periodic status reports. You won’t be able to use a long ‘expire’ directly, because the periodic update restarts the timing.
More from the guru :slight_smile:
Okay, resurrected my old 2.5 timer into a rules file. Seems to be working as expected.
Thanks.
@OMR
There is no expire binding in OH3. It is part of the core functionality.
