I am a happy user of openHAB since version 1.x and have repeatedly performed fresh installations from scratch. In addition to backing up the configuration, which often is excellent, I wonder if there is a way to export a status report of the current installation? I am thinking of a report that lists items by name, which addons are installed, maybe the names of created rules, etc. This would serve as a quick reference and an overview of previous installations. It can be helpful when starting a new installation and also as a summary of what is included in each backup (in case I want to revert to an older backup and am unsure of what it contains).
Thank you, that was helpful.
Unless I am missing something, is there anywhere a list of created items (including the names) and a list of created rules (names)?
You can use the karaf console to get a list of items, things, rules, …
The API explorer / REST API offers similar functionality.
E.g. karaf console:
openhab:automation listRules
ID UID NAME STATUS
1 56019b0a5d test UNINITIALIZED
2 Einfahrt-1 rule triggered by Rule_Gate IDLE
3 GateDoorBell-1 Someone is at the gate IDLE
4 Helper-1 Helper Date IDLE
5 MQTT-1 gateway IDLE
6 MQTT-doorbell-1 doorbell IDLE
7 MQTT-frigate-1 Backpack IDLE
8 MQTT-frigate-10 Umbrella IDLE
9 MQTT-frigate-2 Bicycle IDLE
10 MQTT-frigate-3 Bird IDLE
11 MQTT-frigate-4 Bus IDLE
12 MQTT-frigate-5 Car IDLE
13 MQTT-frigate-6 Cat IDLE
14 MQTT-frigate-7 Dog IDLE
15 MQTT-frigate-8 Motorcycle IDLE
16 MQTT-frigate-9 Person IDLE
17 Shelly-1 HeatingPump ON IDLE
18 Shelly-2 HeatingPump OFF IDLE
19 SmartHome-1 Init IDLE
24 SmartHome-4 rule triggered by sun set ( to turn on aussenlicht on sunset ) IDLE
25 SmartHome-5 rule triggered by timer ( to turn off aussenlicht by time ) IDLE
