I try to expose a string item to alexa which should be readonly (not be changed by Alexa).
Just as example, let´s say the purpose of the item is to save the actual weekday.
So the item can have different string values (monday/tuesday/wednesday/…)
In openhab I can see the current value of the item, but I would like to ask Alexa something like “What is the state of weekday?” and receive an answer like “Tuesday”.
I tried to use ModeController.mode in combination with supportedModes. It was possible to ask for the state of the item, but I didn´t manage to make it readonly.
My item definition looks like this:
String state_weekday “today” { alexa=“ModeController.mode” [friendlyNames=“weekday”, supportedModes=“monday=monday,tuesday=tuesday,wednesday=wednesday”] }
The modes need to known on the Alexa end. If you are referring to dynamic modes defined by a binding, per the documentation: “In regards to supported modes and their mappings, by default if omitted, the openHAB item state description options, if defined, are used to determine these configurations.”.
