## The problem
Using a JS transform script which throws e ClassNotFoundExcept…ion completely breaks mainUI.
To fix this problem once it occurs, there are 2 options requiring access to the file system:
1. delete the offending JS transform (foo.js)
2. remove the offending JS transform pattern in the JSON database: stop openHAB service, edit `$OPENHAB_USERDATA/jsondb/org.openhab.core.items.Metadata.json` to remove the offending metadata by hand, then start the openHAB service.
## Expected behavior
MainUI should not crash when this type of errors occurs.
## Steps to reproduce
Create a JS transform 'foo.js' as a file under `$OPENHAB_CONF/transform/foo.js` that will fail, e.g.:
```js
(function(data) {
var QuantityType = Java.type('org.openhab.core.library.types.QuantityType');
return 'test';
})(input)
Logging (`openhab.log` will show:
```txt
2023-04-30 10:56:33.255 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - Problem with writing the data, class org.openhab.core.io.rest.Stream2JSONInputStream, ContentType: application/json
2023-04-30 10:56:33.257 [ERROR] [internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
java.lang.RuntimeException: java.lang.ClassNotFoundException: org.openhab.core.library.types.QuantityType cannot be found by org.apache.aries.jax.rs.whiteboard_2.0.0
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:531) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:428) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine$3.eval(NashornScriptEngine.java:521) ~[jdk.scripting.nashorn:?]
at javax.script.CompiledScript.eval(CompiledScript.java:89) ~[java.scripting:?]
at org.openhab.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:126) ~[?:?]
at org.openhab.core.transform.TransformationHelper.transform(TransformationHelper.java:125) ~[?:?]
at org.openhab.core.transform.TransformationHelper.transform(TransformationHelper.java:100) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.considerTransformation(EnrichedItemDTOMapper.java:148) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:81) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:64) ~[?:?]
at org.openhab.core.io.rest.core.internal.item.ItemResource.lambda$2(ItemResource.java:222) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) ~[?:?]
at java.util.HashMap$KeySpliterator.tryAdvance(HashMap.java:1642) ~[?:?]
at java.util.stream.StreamSpliterators$WrappingSpliterator.lambda$initPartialTraversalState$0(StreamSpliterators.java:294) ~[?:?]
at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.fillBuffer(StreamSpliterators.java:206) ~[?:?]
at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.doAdvance(StreamSpliterators.java:169) ~[?:?]
at java.util.stream.StreamSpliterators$WrappingSpliterator.tryAdvance(StreamSpliterators.java:300) ~[?:?]
at java.util.Spliterators$1Adapter.hasNext(Spliterators.java:681) ~[?:?]
at org.openhab.core.io.rest.Stream2JSONInputStream.fillBuffer(Stream2JSONInputStream.java:91) ~[?:?]
at org.openhab.core.io.rest.Stream2JSONInputStream.read(Stream2JSONInputStream.java:67) ~[?:?]
at java.io.InputStream.read(InputStream.java:280) ~[?:?]
at java.io.InputStream.transferTo(InputStream.java:704) ~[?:?]
at org.openhab.core.io.rest.core.internal.GsonMessageBodyWriter.writeTo(GsonMessageBodyWriter.java:83) ~[?:?]
at org.openhab.core.io.rest.core.internal.MediaTypeExtension.writeTo(MediaTypeExtension.java:84) ~[?:?]
at org.apache.cxf.jaxrs.utils.JAXRSUtils.writeMessageBody(JAXRSUtils.java:1543) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.serializeMessage(JAXRSOutInterceptor.java:249) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.processResponse(JAXRSOutInterceptor.java:122) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.handleMessage(JAXRSOutInterceptor.java:84) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.OutgoingChainInterceptor.handleMessage(OutgoingChainInterceptor.java:90) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[bundleFile:3.4.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:74) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:90) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.46.v20220331]
Caused by: java.lang.ClassNotFoundException: org.openhab.core.library.types.QuantityType cannot be found by org.apache.aries.jax.rs.whiteboard_2.0.0
at org.eclipse.osgi.internal.loader.BundleLoader.generateException(BundleLoader.java:529) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:524) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:416) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:168) ~[org.eclipse.osgi-3.17.200.jar:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:522) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:622) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.ops4j.pax.swissbox.core.BundleClassLoader.findClass(BundleClassLoader.java:176) ~[bundleFile:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:589) ~[?:?]
at org.ops4j.pax.swissbox.core.BundleClassLoader.loadClass(BundleClassLoader.java:192) ~[bundleFile:?]
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Class.java:398) ~[?:?]
at jdk.nashorn.internal.runtime.Context.findClass(Context.java:1180) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.objects.NativeJava.simpleType(NativeJava.java:546) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.objects.NativeJava.type(NativeJava.java:326) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.objects.NativeJava.type(NativeJava.java:318) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.objects.NativeJava.type(NativeJava.java:314) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$110$1A$\^eval\_/0x4e52a6c8.L:1(<eval>:2) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$109$\^eval\_/0x550c94b0.:program(<eval>:1) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:655) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:513) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:527) ~[jdk.scripting.nashorn:?]
... 75 more
## Your environment
```yaml
runtimeInfo:
version: 3.4.3
buildString: Release Build
locale: en-BE
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.18
javaVendor: Raspbian
osName: Linux
osVersion: 6.1.21-v7+
osArchitecture: arm
availableProcessors: 4
freeMemory: 6851840
totalMemory: 324403200
startLevel: 100
bindings:
- buienradar
- nikohomecontrol
- openweathermap
- sonos
- systeminfo
- telegram
- tradfri
- zwave
clientInfo:
device:
ios: false
android: false
androidChrome: false
desktop: true
iphone: false
ipod: false
ipad: false
edge: false
ie: false
firefox: false
macos: true
windows: false
cordova: false
phonegap: false
electron: false
nwjs: false
webView: false
webview: false
standalone: false
os: macos
pixelRatio: 2
prefersColorScheme: dark
isSecureContext: false
locationbarVisible: true
menubarVisible: true
navigator:
cookieEnabled: true
deviceMemory: N/A
hardwareConcurrency: 4
language: en-GB
languages:
- en-GB
onLine: true
platform: MacIntel
screen:
width: 1680
height: 1050
colorDepth: 24
support:
touch: false
pointerEvents: true
observer: true
passiveListener: true
gestures: false
intersectionObserver: true
themeOptions:
dark: dark
filled: true
pageTransitionAnimation: default
bars: light
homeNavbar: default
homeBackground: default
expandableCardAnimation: default
userAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15
(KHTML, like Gecko) Version/16.4.1 Safari/605.1.15
timestamp: 2023-04-30T09:14:38.141Z
## Browser console
```txt
[Error] Viewport argument key "minimal-ui" not recognized and ignored. (items, line 1)
[Debug] loading i18n messages from: ./bg.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./ca.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./cs.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./da.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./de.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./el.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./en.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./es.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./fa.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./fi.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./fr.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./he.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./hu.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./it.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./iw.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./lb.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./lt.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./lv.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./nl.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./no.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./pl.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./pt-BR.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./pt.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./ru.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./sk.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./sl.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./sv.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./tr.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./uk.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] loading i18n messages from: ./zh.json (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] Initializing state tracking store proxy (app.d702c20a4e09bf4012ea.js, line 7)
[Debug] sseConnected – false (app.d702c20a4e09bf4012ea.js, line 35)
[Error] Unhandled Promise Rejection: parseerror
## Browser network traffic
## Additional information
openHAB version 3.4.3 running on openHABian (Raspberry Pi 3B+).
