I am converting my home automation server to openHAB running on a Raspberry Pi running DietPi. I installed the openHAB demo, and modified the demo so the frames are organized according to my home. I got nest and few other supported devices working.
In the past, I created some of my own home automation devices. Obviously, they are not supported … yet. I would like to add a link to an unsupported device’s home page until I have time to figure out how to get them supported in openHAB.
In openHAB, is there a way to add a link to an unsupported device on my network?
I would like to see something like: label and button. Clicking on button would take me to the link. In sitemap, I tried variations on:
Text item=MyDevice visibility=[link==“url-ip-address”]
@andreas_furrer68
I’ve the same problem as you in my application, and I’m searching a solution: in a browser the link is working, but Habdroid is only showing a href string.
Have you solved?
It doesn’t work for me in the basic ui either (classic is fine) but what I noticed is that if you put in a nonexistent sitemap then it will give you a list of all your sitemaps as links which you can then click on.
