I’m trying to extract 2 values from a string so I can subtract one from the other, and postUpdate the result.
The String is taken from incoming JSON and after using “transform” I end up with
[[1038,1039]]
I can remove the square brackets by using
var String TransformString = (Incoming.replace('[[','').replace(']', ''))
which gives me 1038,1039
I’m unsure where to go from here to get the individual values to perform the subtraction with.
