Can someone please help me. I just can’t figure this out.
I have created an expandable card widget inspired by a few other similar widgets here on the forum.
It is mostly working well, but the problem is that slider items don’t use the full width of the card when expanded. They only go as far as the non-expanded card was wide before it expanded. Make sense?
I think I have tracked it down as far as being something to do with - card-expandable-animate-width on line 71.
When I remove this line the sliders behave as expected, but obviously this has broken the positioning and alignment of everything as they don’t move about properly with the expanding card.
The annoying thing is, is that this works properly in the widget editor, but when loaded in a real page the sliders are broken again.
In my widget editor:
In a page
uid: widget_heating-TRVControls
props:
parameters:
- description: Location
label: Location
required: false
type: TEXT
- context: item
label: Humidity
required: false
type: TEXT
- context: item
label: Temperature
required: false
type: TEXT
- context: item
label: Target Temperature
required: false
type: TEXT
- context: item
label: Heating Power
required: false
type: TEXT
- context: item
label: Zone Operation Mode
required: false
type: TEXT
- context: item
label: HVAC Mode
required: false
type: TEXT
- context: item
label: Timer Duration
required: false
type: TEXT
- context: item
label: Overlay End Time
required: false
type: TEXT
- context: item
label: Battery Low Alarm
required: false
type: TEXT
- context: item
label: Contact Sensor 1
required: false
type: TEXT
- context: item
label: Contact Sensor 2
required: false
type: TEXT
timestamp: Jun 13, 2021, 8:56:44 AM
component: f7-card
expandable: true
swipeToClose: true
backdrop: true
class:
style:
background: '=(items[props.temp].state < "17") ? "linear-gradient(to bottom, hsla(207, 90%, 54%, 1), hsla(207, 90%, 95%, 1), 10% , hsla(0, 0%, 100%, 1) )": (items[props.temp].state >= "17" && items[props.temp].state < "18") ? "linear-gradient(to bottom, hsla(130, 65%, 57%, 1), hsla(130, 65%, 95%, 1), 10% , hsla(0, 0%, 100%, 1) )": (items[props.temp].state >= "18" && items[props.temp].state < "19") ? "linear-gradient(to bottom, hsla(66, 70%, 54%, 1), hsla(66, 70%, 95%, 1), 10% , hsla(0, 0%, 100%, 1) )": (items[props.temp].state >= "19" && items[props.temp].state < "20") ? "linear-gradient(to bottom, hsla(48, 100%, 50%, 1), hsla(48, 100%, 95%, 1), 10% , hsla(0, 0%, 100%, 1) )": (items[props.temp].state >= "20" && items[props.temp].state < "22") ? "linear-gradient(to bottom, hsla(35, 100%, 50%, 1), hsla(35, 100%, 95%, 1), 10% , hsla(0, 0%, 100%, 1) )": (items[props.temp].state >= "22" && items[props.temp].state < "23") ? "linear-gradient(to bottom, hsla(20, 100%, 57%, 1), hsla(20, 100%, 95%, 1), 10% , hsla(0, 0%, 100%, 1) )": (items[props.temp].state >= "23" && items[props.temp].state < "24") ? "linear-gradient(to bottom, hsla(349, 100%, 59%, 1), hsla(349, 100%, 95%, 1), 10% , hsla(0, 0%, 100%, 1) )": (items[props.temp].state >= "24") ? "linear-gradient(to bottom, hsla(3, 100%, 59%, 1), hsla(3, 100%, 95%, 1), 10% , hsla(0, 0%, 100%, 1) )": "white"'
height: 170px
width: auto
margin: 5px
margin-top: 10px
slots:
default:
- component: oh-button
iconF7: ellipsis
iconSize: 30px
color: gray
style:
position: absolute
top: 0
right: 0
padding-top: 10px
padding-right: 15px
padding-bottom: 40px
z-index: 999
class:
- cell-open-button
- card-opened-fade-out
- component: f7-card-content
style:
padding-top: 30px
slots:
default:
- component: f7-icon
material: '=(items[props.heatP].state > 0 ) ? "local_fire_department": (items[props.open1].state == "OPEN" || items[props.open2].state == "OPEN") ? "sensor_window" : "power_settings_new"'
size: '=(items[props.open1].state == "OPEN" || items[props.open2].state == "OPEN") ? "80px" : (items[props.heatP].state == 0) ? "50px" : 40 ++ items[props.heatP].state + "px"'
color: '=(items[props.heatP].state == 0) ? "black": (items[props.heatP].state >= 1 && items[props.heatP].state < 20) ? "lightblue": (items[props.heatP].state >= 20 && items[props.heatP].state < 40) ? "teal": (items[props.heatP].state >= 40 && items[props.heatP].state < 60) ? "yellow": (items[props.heatP].state >= 60 && items[props.heatP].state < 80) ? "orange": (items[props.heatP].state >= 80 && items[props.heatP].state <= 100) ? "red": "white"'
style:
opacity: '=(items[props.heatP].state > 0 ) ? items[props.heatP].state * 1.5 + "%": "100%"'
position: absolute
top: '=(items[props.heatP].state > 0 ) ? 120 + -items[props.heatP].state + "px": (items[props.open1].state == "OPEN" || items[props.open2].state == "OPEN") ? "75px" :"95px"'
right: '=(items[props.heatP].state > 0 ) ? 40 + -items[props.heatP].state * 0.5 + "px": (items[props.open1].state == "OPEN" || items[props.open2].state == "OPEN") ? "18px" : "15px"'
- component: f7-chip
text: '=(items[props.heatP].state > 0) ? items[props.heatP].state + " %": (items[props.open1].state == "OPEN" || items[props.open2].state == "OPEN") ? "OPEN WINDOW": "0%"'
style:
position: absolute
top: 140px
right: 20px
iconF7: xmark_circle_fill
iconSize: 30px
color: black
style:
position: absolute
top: 0
right: 0
padding-top: 10px
padding-bottom: 35px
z-index: 999
class:
- card-opened-fade-in
- cell-close-button
- card-close
- component: oh-link
class:
- cell-open-button
- justify-content-flex-end
style:
width: auto
height: auto
position: absolute
top: 0
left: 0
z-index: 0
- component: f7-block
class:
- no-padding
style:
margin: 0px
height: 200px
width: auto
slots:
default:
- component: f7-row
style:
height: 65px
width: 100%
white-space: nowrap
flex-wrap: nowrap
slots:
default:
- component: f7-col
slots:
default:
- component: Label
text: =props.location
style:
font-weight: 600
text-overflow: ellipsis
overflow: hidden
white-space: nowrap
text: =items[props.temp].displayState
color: '=(items[props.temp].state > "1" && items[props.temp].state < "17") ? "blue": (items[props.temp].state >= "17" && items[props.temp].state < "18") ? "green": (items[props.temp].state >= "18" && items[props.temp].state < "19") ? "lime": (items[props.temp].state >= "19" && items[props.temp].state < "20") ? "yellow": (items[props.temp].state >= "20" && items[props.temp].state < "22") ? "orange": (items[props.temp].state >= "22" && items[props.temp].state < "23") ? "deeporange": (items[props.temp].state >= "23" && items[props.temp].state < "24") ? "pink": (items[props.temp].state >= "24") ? "red": "white"'
- component: f7-row
style:
height: auto
width: 100%
overflow: hidden
margin-bottom: 5px
slots:
default:
- component: f7-col
style:
flex-wrap: nowrap
align-self: flex-end
slots:
default:
- component: f7-row
class:
- justify-content-flex-start
style:
flex-wrap: nowrap
slots:
default:
f7: arrow_up_to_line
color: '=(items[props.targetTemp].state > "1" && items[props.targetTemp].state < "17") ? "blue": (items[props.targetTemp].state >= "17" && items[props.targetTemp].state < "18") ? "green": (items[props.targetTemp].state >= "18" && items[props.targetTemp].state < "19") ? "lime": (items[props.targetTemp].state >= "19" && items[props.targetTemp].state < "20") ? "yellow": (items[props.targetTemp].state >= "20" && items[props.targetTemp].state < "22") ? "orange": (items[props.targetTemp].state >= "22" && items[props.targetTemp].state < "23") ? "deeporange": (items[props.targetTemp].state >= "23" && items[props.targetTemp].state < "24") ? "pink": (items[props.targetTemp].state >= "24") ? "red": "gray"'
- component: Label
text: '=(items[props.hvac].state == "OFF") ? "OFF": items[props.targetTemp].state'
style:
margin-left: 8px
font-size: 12px
color: gray
overflow: hidden
white-space: nowrap
- component: f7-row
visible: '=(items[props.timerD].state > "0") ? "true": "false"'
style:
white-space: nowrap
flex-wrap: nowrap
height: auto
class:
slots:
default:
f7: timer
color: blue
- component: Label
text: =items[props.timerD].displayState
style:
margin-left: 6px
font-size: 12px
color: gray
overflow: hidden
white-space: nowrap
style:
width: auto
class:
- card-prevent-open
- card-content-padding
slots:
default:
- component: oh-list
config: {}
slots:
default:
- component: oh-toggle-item
title: On/Off
item: =props.hvac
icon: f7:power
iconColor: '=(items[props.hvac == "HEAT" ? "deeporange": "gray"'
actionCommand: HEAT
actionCommandAlt: OFF
- component: oh-slider-item
title: Target Temperature
item: =props.targetTemp
icon: f7:arrow_up_to_line
iconColor: '=(items[props.targetTemp].state > "1" && items[props.targetTemp].state < "17") ? "blue": (items[props.targetTemp].state >= "17" && items[props.targetTemp].state < "18") ? "green": (items[props.targetTemp].state >= "18" && items[props.targetTemp].state < "19") ? "lime": (items[props.targetTemp].state >= "19" && items[props.targetTemp].state < "20") ? "yellow": (items[props.targetTemp].state >= "20" && items[props.targetTemp].state < "22") ? "orange": (items[props.targetTemp].state >= "22" && items[props.targetTemp].state < "23") ? "deeporange": (items[props.targetTemp].state >= "23" && items[props.targetTemp].state < "24") ? "pink": (items[props.targetTemp].state >= "24") ? "red": "white"'
iconUseState: true
color: '=(items[props.targetTemp].state > "1" && items[props.targetTemp].state < "17") ? "blue": (items[props.targetTemp].state >= "17" && items[props.targetTemp].state < "18") ? "green": (items[props.targetTemp].state >= "18" && items[props.targetTemp].state < "19") ? "lime": (items[props.targetTemp].state >= "19" && items[props.targetTemp].state < "20") ? "yellow": (items[props.targetTemp].state >= "20" && items[props.targetTemp].state < "22") ? "orange": (items[props.targetTemp].state >= "22" && items[props.targetTemp].state < "23") ? "deeporange": (items[props.targetTemp].state >= "23" && items[props.targetTemp].state < "24") ? "pink": (items[props.targetTemp].state >= "24") ? "red": "white"'
min: 15
max: 25
label: true
scale: true
scaleSteps: 10
- component: oh-list-item
title: Mode
icon: f7:app_badge
badge: =items[props.zoneOp].displayState
badge-color: '=(items[props.zoneOp].state == "SCHEDULE") ? "green" : (items[props.zoneOp].state == "UNTIL_CHANGE") ? "yellow" : (items[props.zoneOp].state == "MANUAL") ? "red" : (items[props.zoneOp].state == "TIMER") ? "blue" : "white"'
action: options
actionItem: =props.zoneOp
- component: oh-stepper-item
title: Timer Duration
footer: in Minutes
item: =props.timerD
icon: f7:timer
iconUseState: true
color: blue
step: 30
fill: true
round: true
autorepeat: true
autorepeatDynamic: true
small: true
