F7 icons
Hello is there a way to give the icon color of the f7 chip one of the non default colors
 - component: f7-card-content
      slots:
        default:
          - component: f7-row
              style:
                height: 30px
                position: relative
            slots:
              default:
                - component: f7-col
                  slots:
                    default:
                      - component: f7-chip
                          iconColor: "=themeOptions.dark === 'dark' ? 'blue' : 'deeporange'"
                          iconF7: alarm
                          iconSize: 20
                          style:
                            --f7-chip-bg-color: rgba(255, 255, 255, 0)
                            font-size: 16px
                            margin-bottom: 10px
                          text: =items[props.item_update].displayState
I want to move away from the blue color in the dark theme but i cant set a custom color
There is no way to use a non-default color by setting anything using the iconColor property.
The icon on the chip is inside a div element with a class of chip-media. With this information you can add a stylesheet property to the chip and then use css to set any color you want.
    stylesheet: >
      .chip-media {
        background: css color definition here;
    rest of config....
thanks a lot thats exactly what i need, just made a css variable for the stylesheet color (found that solution in an other post of you)
 default:
          - component: f7-row
              style:
                height: 30px
                position: relative
            slots:
              default:
                - component: f7-col
                  slots:
                    default:
                          style:
                            --custom-icon-color: "=themeOptions.dark === 'dark' ? 'blue' : '#ff6b22'"
                            font-size: 16px
                          stylesheet: |
                            .chip-media {color: var(--custom-icon-color);}
                          iconF7: alarm
                          iconSize: 20
