I tried to install Backup using openhabian-config Menu 50.
First I installed a new 64 GB SD card on a USB reader on my Pi 4 B, which appears to have mounted:
[09:45:58] openhabian@openhab:/dev$ systemctl status storage.mount
● storage.mount - /storage mount
Loaded: loaded (/etc/systemd/system/storage.mount; enabled; vendor preset: enabled)
Active: active (mounted) since Thu 2021-02-11 09:29:06 MST; 18min ago
Where: /storage
What: /dev/sda3
Tasks: 0 (limit: 4915)
CGroup: /system.slice/storage.mount
Feb 11 09:29:06 openhab systemd[1]: Mounting /storage mount...
Feb 11 09:29:06 openhab systemd[1]: Mounted /storage mount.
I removed the “#” in /etc/openhabian.conf in front of backupdrive=/dev/sda
In reading the above closely, I see at the beginning, it says that this file is only used for the initial configuration and that changes should be made thereafter using the openhabian-config menus, but I don’t see anywhere in the menus where I can change this.
I then ran Menu 53 and received the FAILED (destination mounted) error. I repeated it several times, each with the same eror.
lsblck shows that 3 partitions were created:
[10:11:39] openhabian@openhab:/dev$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 1 58.2G 0 disk
├─sda1 8:1 1 256M 0 part
├─sda2 8:2 1 29.6G 0 part
└─sda3 8:3 1 28.4G 0 part /storage
mmcblk0 179:0 0 29.8G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 29.6G 0 part /
I changed the log setting to maximum and reran the Backup install from the menu. Here is the output:
+ echo -e '\n\033[90;01m$ apt-get install --yes gdisk \033[39;49;00m'
+ apt-get install --yes gdisk
Reading package lists... Done
Building dependency tree
gdisk is already the newest version (1.0.3-1.1).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
+ return 0
+ echo OK
OK
+ cond_redirect install -m 755 /opt/openhabian/includes/set-partuuid /usr/local/sbin
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ install -m 755 /opt/openhabian/includes/set-partuuid /usr/local/sbin \033[39;49;00m'
+ install -m 755 /opt/openhabian/includes/set-partuuid /usr/local/sbin
+ return 0
+ [[ -n 1 ]]
+ select_blkdev '^sd' 'Setup SD mirroring' 'Select USB device to copy the internal SD card data to'
+ [[ -z 1 ]]
+ array=()
+ declare -a array
+ read -r id foo foo size foo foo foo
++ lsblk -i
++ tr -d '`\\|'
++ grep -E '^sd'
++ tr -d '\\-'
+ array+=("$id" "$size")
+ [[ 2 -eq 0 ]]
+ (( count=2 + 8 ))
++ whiptail --title 'Setup SD mirroring' --cancel-button Cancel --ok-button Select --menu '\nSelect USB device to copy the internal SD card data to' 10 76 0 sda 58.2G
+ retval=sda
+ [[ -z sda ]]
+ dest=/dev/sda
++ blockdev --getsize64 /dev/sda
+ [[ -n 62534975488 ]]
+ mount
+ grep -q /dev/sda
+ echo 'FAILED (destination mounted)'
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "50 | Backup/Restore"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed.' 14 80
+ return 0
+ true
+ show_main_menu
+ local choice
+ local version
+++ get_git_revision
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=main
++++ git -C /opt/openhabian describe --tags --abbrev=0
+++ latestTag=v1.6.3
++++ git -C /opt/openhabian log --oneline
++++ wc -l
I would appreciate any suggestions of what to try next to troubleshoot this.
