Openhab 2.5.3
I havent installed any persistence bindung/action but I get this message in my log.
I deleted everything with jdbc/mysql/mariadb in all files also in .cfg/.persist/.config in userdata/*
[ERROR] [.core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-persistence-jdbc'
nothing installed:
openhab> bundle:list | grep -i jdbc
openhab> bundle:list | grep -i maria
openhab> bundle:list | grep -i mysql
I want to use jdbc with mariadb, but can not get it to work.
I installed via karaf and feature:install - after the installation finished i got a lot of messages in log, but after some seconds i got an error message and after that a bundle:list or feature:list shows me an uninstalled persistence again.
Before the error message the .list showed me an installed and active persistence.
I tried jdbc-mariadb and jbdc-mysql
2020-04-07 23:48:29.290 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::setItemRegistry
2020-04-07 23:48:29.292 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::activate: persistence service activated
2020-04-07 23:48:29.296 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::updateConfig
2020-04-07 23:48:29.302 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::JdbcConfiguration
2020-04-07 23:48:29.303 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: configuration size = 10
2020-04-07 23:48:29.307 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: user=openhab
2020-04-07 23:48:29.309 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: password exists? true
2020-04-07 23:48:29.310 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: url=jdbc:mariadb://192.168.3.3:3306/openhab
2020-04-07 23:48:29.311 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: found serviceName = 'mariadb'
2020-04-07 23:48:29.312 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: Init Data Access Object Class: 'org.openhab.persistence.jdbc.db.JdbcMariadbDAO'
2020-04-07 23:48:29.318 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::initSqlTypes: Initialize the type array
2020-04-07 23:48:29.319 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::initSqlQueries: 'JdbcMariadbDAO'
2020-04-07 23:48:29.321 [DEBUG] [b.persistence.jdbc.db.JdbcMariadbDAO] - JDBC::initSqlTypes: Initialize the type array
2020-04-07 23:48:29.322 [DEBUG] [b.persistence.jdbc.db.JdbcMariadbDAO] - JDBC::initSqlQueries: 'JdbcMariadbDAO'
2020-04-07 23:48:29.324 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: dBDAO ClassName=org.openhab.persistence.jdbc.db.JdbcMariadbDAO
2020-04-07 23:48:29.366 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: tableUseRealItemNames=true
2020-04-07 23:48:29.368 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: enableLogTime false
2020-04-07 23:48:29.409 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: load JDBC-driverClass was successful: 'org.mariadb.jdbc.Driver'
2020-04-07 23:48:29.410 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: configuration complete. service=jdbc
2020-04-07 23:48:29.411 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::pingDB
2020-04-07 23:48:29.413 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection isDriverAvailable: true
2020-04-07 23:48:29.415 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2020-04-07 23:48:29.597 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::setDbConnected true
2020-04-07 23:48:29.599 [DEBUG] [b.persistence.jdbc.db.JdbcMariadbDAO] - JDBC::initAfterFirstDbConnection: Initializing step, after db is connected.
2020-04-07 23:48:29.634 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - dbMajorVersion = '10'
2020-04-07 23:48:29.636 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - dbMinorVersion = '4'
2020-04-07 23:48:29.637 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - driverMajorVersion = '1'
2020-04-07 23:48:29.639 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - driverMinorVersion = '3'
2020-04-07 23:48:29.640 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - dbProductName = 'MySQL'
2020-04-07 23:48:29.641 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - dbProductVersion = '10.4.11-MariaDB-1:10.4.11+maria~bionic-log'
2020-04-07 23:48:29.643 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::pingDB asking db for name as absolutely first db action, after connection is established.
2020-04-07 23:48:29.752 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::checkDBAcessability, first try connection: true
2020-04-07 23:48:29.754 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::createItemsTableIfNot
2020-04-07 23:48:29.756 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doCreateItemsTableIfNot sql=CREATE TABLE IF NOT EXISTS items (ItemId INT NOT NULL AUTO_INCREMENT,itemname VARCHAR(500) NOT NULL,PRIMARY KEY (ItemId))
2020-04-07 23:48:30.503 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::getItemIDTableNames
2020-04-07 23:48:30.504 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetItemIDTableNames sql=SELECT itemid, itemname FROM items
2020-04-07 23:48:30.534 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:48:30.537 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::updateConfig: configuration complete for service=jdbc.
2020-04-07 23:48:30.541 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:48:30.547 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:48:30.550 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:48:30.553 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:48:30.556 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:48:30.559 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:48:30.563 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:49:29.565 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-persistence-jdbc'
2020-04-07 23:49:31.384 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:49:31.386 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:49:31.388 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:49:31.390 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:49:31.392 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:49:31.394 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-07 23:49:31.397 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::deactivate: persistence bundle stopping. Disconnecting from database. reason=6
2020-04-07 23:49:31.399 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::unsetItemRegistry
2020-04-08 00:08:26.991 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::setItemRegistry
2020-04-08 00:08:26.993 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::activate: persistence service activated
2020-04-08 00:08:26.994 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::updateConfig
2020-04-08 00:08:26.999 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::JdbcConfiguration
2020-04-08 00:08:27.001 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: configuration size = 11
2020-04-08 00:08:27.004 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: user=openhab
2020-04-08 00:08:27.006 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: password exists? true
2020-04-08 00:08:27.007 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: url=jdbc:mariadb://192.168.3.3:3306/openhab
2020-04-08 00:08:27.008 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: found serviceName = 'mariadb'
2020-04-08 00:08:27.009 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: Init Data Access Object Class: 'org.openhab.persistence.jdbc.db.JdbcMariadbDAO'
2020-04-08 00:08:27.015 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::initSqlTypes: Initialize the type array
2020-04-08 00:08:27.017 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::initSqlQueries: 'JdbcMariadbDAO'
2020-04-08 00:08:27.018 [DEBUG] [b.persistence.jdbc.db.JdbcMariadbDAO] - JDBC::initSqlTypes: Initialize the type array
2020-04-08 00:08:27.019 [DEBUG] [b.persistence.jdbc.db.JdbcMariadbDAO] - JDBC::initSqlQueries: 'JdbcMariadbDAO'
2020-04-08 00:08:27.021 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: dBDAO ClassName=org.openhab.persistence.jdbc.db.JdbcMariadbDAO
2020-04-08 00:08:27.024 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: tableNamePrefix=Item
2020-04-08 00:08:27.025 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: tableUseRealItemNames=true
2020-04-08 00:08:27.026 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: enableLogTime false
2020-04-08 00:08:27.028 [ERROR] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: could NOT load JDBC-driverClassName or JDBC-dataSourceClassName. ClassNotFoundException: 'org.mariadb.jdbc.Driver cannot be found by org.openhab.persistence.jdbc_1.14.0'
2020-04-08 00:08:27.029 [WARN ] [ence.jdbc.internal.JdbcConfiguration] -
To avoid this error, place an appropriate JDBC driver file for serviceName 'mariadb' in addons directory.
Copy missing JDBC-Driver-jar to your OpenHab/addons Folder.
DOWNLOAD:
MariaDB: version >= 1.2.0 from http://mvnrepository.com/artifact/org.mariadb.jdbc/mariadb-java-client
2020-04-08 00:08:27.030 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: configuration complete. service=jdbc
2020-04-08 00:08:27.032 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::pingDB
2020-04-08 00:08:27.033 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection isDriverAvailable: false
2020-04-08 00:08:27.034 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2020-04-08 00:08:27.036 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::pingDB
2020-04-08 00:08:27.037 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection isDriverAvailable: false
2020-04-08 00:08:27.038 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2020-04-08 00:08:27.039 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::checkDBAcessability, second try connection: false
2020-04-08 00:08:27.040 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:08:27.041 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::updateConfig: configuration complete for service=jdbc.
2020-04-08 00:08:27.043 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:08:27.046 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:08:27.048 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:08:27.049 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:08:27.050 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:08:27.052 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:08:27.054 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:01.736 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:01.738 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:01.741 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:01.751 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:01.753 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:01.758 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:01.765 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::deactivate: persistence bundle stopping. Disconnecting from database. reason=6
2020-04-08 00:16:01.767 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::unsetItemRegistry
2020-04-08 00:16:02.159 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::setItemRegistry
2020-04-08 00:16:02.161 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::activate: persistence service activated
2020-04-08 00:16:02.162 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::updateConfig
2020-04-08 00:16:02.188 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::JdbcConfiguration
2020-04-08 00:16:02.206 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: configuration size = 11
2020-04-08 00:16:02.226 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: user=openhab
2020-04-08 00:16:02.228 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: password exists? true
2020-04-08 00:16:02.229 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: url=jdbc:mariadb://192.168.3.3:3306/openhab
2020-04-08 00:16:02.243 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: found serviceName = 'mariadb'
2020-04-08 00:16:02.245 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: Init Data Access Object Class: 'org.openhab.persistence.jdbc.db.JdbcMariadbDAO'
2020-04-08 00:16:02.340 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::initSqlTypes: Initialize the type array
2020-04-08 00:16:02.342 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::initSqlQueries: 'JdbcMariadbDAO'
2020-04-08 00:16:02.344 [DEBUG] [b.persistence.jdbc.db.JdbcMariadbDAO] - JDBC::initSqlTypes: Initialize the type array
2020-04-08 00:16:02.346 [DEBUG] [b.persistence.jdbc.db.JdbcMariadbDAO] - JDBC::initSqlQueries: 'JdbcMariadbDAO'
2020-04-08 00:16:02.348 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: dBDAO ClassName=org.openhab.persistence.jdbc.db.JdbcMariadbDAO
2020-04-08 00:16:02.363 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: tableNamePrefix=Item
2020-04-08 00:16:02.367 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: tableUseRealItemNames=true
2020-04-08 00:16:02.369 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: enableLogTime false
2020-04-08 00:16:02.379 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: load JDBC-driverClass was successful: 'org.mariadb.jdbc.Driver'
2020-04-08 00:16:02.380 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: configuration complete. service=jdbc
2020-04-08 00:16:02.382 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::pingDB
2020-04-08 00:16:02.384 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection isDriverAvailable: true
2020-04-08 00:16:02.398 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2020-04-08 00:16:02.650 [DEBUG] [ence.jdbc.internal.JdbcConfiguration] - JDBC::setDbConnected true
2020-04-08 00:16:02.652 [DEBUG] [b.persistence.jdbc.db.JdbcMariadbDAO] - JDBC::initAfterFirstDbConnection: Initializing step, after db is connected.
2020-04-08 00:16:02.717 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - dbMajorVersion = '10'
2020-04-08 00:16:02.736 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - dbMinorVersion = '4'
2020-04-08 00:16:02.745 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - driverMajorVersion = '1'
2020-04-08 00:16:02.753 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - driverMinorVersion = '3'
2020-04-08 00:16:02.758 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - dbProductName = 'MySQL'
2020-04-08 00:16:02.774 [DEBUG] [ab.persistence.jdbc.utils.DbMetaData] - dbProductVersion = '10.4.11-MariaDB-1:10.4.11+maria~bionic-log'
2020-04-08 00:16:02.782 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::pingDB asking db for name as absolutely first db action, after connection is established.
2020-04-08 00:16:02.897 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::checkDBAcessability, first try connection: true
2020-04-08 00:16:02.908 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::createItemsTableIfNot
2020-04-08 00:16:02.911 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doCreateItemsTableIfNot sql=CREATE TABLE IF NOT EXISTS items (ItemId INT NOT NULL AUTO_INCREMENT,itemname VARCHAR(500) NOT NULL,PRIMARY KEY (ItemId))
2020-04-08 00:16:02.918 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::getItemIDTableNames
2020-04-08 00:16:02.922 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetItemIDTableNames sql=SELECT itemid, itemname FROM items
2020-04-08 00:16:02.942 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:02.950 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::updateConfig: configuration complete for service=jdbc.
2020-04-08 00:16:02.953 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:02.959 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:02.961 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:02.970 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:02.974 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:02.982 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:16:02.986 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2020-04-08 00:21:01.499 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-persistence-jdbc'
I deleted all tables in my database, after installing, i have a new table “items” empty and nothing more.
