Failed: null when passing SwitchItem to lambda
I am trying to create a lambda that will accept a SwitchItem as a paremeter but I am getting a:
Script execution of rule with UID 'automation_shutter-1' failed: null in automation_shutter
when trying to execute rule.
I have isolated issue to this example:
val LOGGER_NAME = "automation_blinds"
val foo = [ SwitchItem test |
  logInfo(LOGGER_NAME, "foo")
  //test.state
rule "automation_blinds"
  Time cron "*/5 * * ? * * *"
  logInfo(LOGGER_NAME, "calling foo with: " + aByAngleRoletaKuchniaOknoEnabled)
  foo.apply(aByAngleRoletaKuchniaOknoEnabled)
The result is:
2021-08-04 00:17:15.438 [INFO ] [.core.model.script.automation_blinds] - calling foo with: aByAngleRoletaKuchniaOknoEnabled (Type=SwitchItem, State=ON, Label=Auto (kat) - Roleta Kuchnia okno, Category=null, Groups=[gAParterRolety])
2021-08-04 00:17:15.442 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'automation_shutter-1' failed: null in automation_shutter
I have also tried to use GenericItem as parameter type but with no luck.
What’s LOGGER_NAME?
It is a constant that I forgot to copy paste to the post. Logger works reliably which is visible in logs
It was more of a hint, really.
LOGGER_NAME is a ā€˜global’ to this rule file.
You lambda is also a ā€˜global’.
These globals can’t ā€œseeā€ each other.
val X = 2  // so-called global
val Y = X + 2 // fails, can't "see" X in global space
Golden rule of DSL lambdas defined in global space, everything you want to use must be passed in as parameters.
In this case of course, you could just use a constant instead
logInfo("myLambda", "works with hardwired constant")
Thank you very much it was really unexpected for me.
