I am trying to configure a new openHAB3 installation on my kubernetes PI cluster.
When I try to configure the mqtt binding with secure ssl I get the following error:
io.netty.handler.codec.DecoderException: javax.net.ssl.SSLHandshakeException: Failed to parse server certificates
I haven’t got a clue on why this is happening and how to fix it ![]()
I use mosquitto as an mqtt broker. I can connect to the broker using ssl from other software so the broker itself is working fine.
I am using a self signed certificate in the kubernetes cluster (using cert-manager).
Can I configure openhab to allow for self signed certificates? Or how else to fix this problem?
