Failed to start rpi-eeprom-update.service
since recently I am seeing an error message in the overview after logging into my system. It seems that after a reboot the rpi-eeprom-update.service is not started accordingly. If I restart it after the boot everything seems fine though.
I was wondering if anybody else experienced this issue and how to fix it?
I would use the dmesg, systemctl status and/or journalctl command to check if the output gives any hint on the root cause.
I have the same issue with like @Ltty showed in the screenshot. Same OH version as but I had it also earlier.
I can start the service and it is actually enabled, but it is always initially reported as ‘failed’ when I start the ssh session:
openhabian@openhabian:~ $ sudo systemctl is-active rpi-eeprom-update.service
failed
openhabian@openhabian:~ $ sudo systemctl start rpi-eeprom-update.service
openhabian@openhabian:~ $ sudo systemctl status rpi-eeprom-update.service
● rpi-eeprom-update.service - Check for Raspberry Pi EEPROM updates
     Loaded: loaded (/lib/systemd/system/rpi-eeprom-update.service; enabled; preset: enabled)
     Active: active (exited) since Mon 2024-09-23 16:35:38 CEST; 5min ago
   Main PID: 2178576 (code=exited, status=0/SUCCESS)
        CPU: 84ms
Sep 23 16:35:38 openhabian systemd[1]: Starting rpi-eeprom-update.service - Check for Raspberry Pi EEPROM updates...
Sep 23 16:35:38 openhabian rpi-eeprom-update[2178576]: BOOTLOADER: up to date
Sep 23 16:35:38 openhabian rpi-eeprom-update[2178576]:    CURRENT: Tue Sep 10 01:40:30 PM UTC 2024 (1725975630)
Sep 23 16:35:38 openhabian rpi-eeprom-update[2178576]:     LATEST: Tue Sep 10 01:40:30 PM UTC 2024 (1725975630)
Sep 23 16:35:38 openhabian rpi-eeprom-update[2178576]:    RELEASE: latest (/lib/firmware/raspberrypi/bootloader-2712/latest)
Sep 23 16:35:38 openhabian rpi-eeprom-update[2178576]:             Use raspi-config to change the release.
Sep 23 16:35:38 openhabian systemd[1]: Finished rpi-eeprom-update.service - Check for Raspberry Pi EEPROM updates.
dmesg:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[    0.000000] Linux version 6.6.50-v8-16k+ (dom@buildbot) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1795 SMP PREEMPT Tue Sep 10 19:41:02 BST 2024
[    0.000000] KASLR enabled
[    0.000000] random: crng init done
[    0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000002000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000002000000..0x0000000005ffffff (65536 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable atf@0
[    0.000000] OF: reserved mem: 0x000000003fd165e0..0x000000003fd16616 (0 KiB) nomap non-reusable nvram@0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
[    0.000000]   node   0: [mem 0x0000000000080000-0x000000003fbfffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[    0.000000] On node 0, zone DMA: 256 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 14 pages/cpu s183976 r8192 d37208 u229376
[    0.000000] pcpu-alloc: s183976 r8192 d37208 u229376 alloc=14*16384
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: SSBS not fully self-synchronizing
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=D8:3A:DD:A3:56:A5 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=2f2c2eb2-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
[    0.000000] Dentry cache hash table entries: 1048576 (order: 9, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 8, 4194304 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 521984
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbffc000-0x00000000ffffc000] (64MB)
[    0.000000] Memory: 8163568K/8384512K available (13376K kernel code, 2224K rwdata, 4288K rodata, 5056K init, 1213K bss, 155408K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 43307 entries in 43 pages
[    0.000000] ftrace: allocated 43 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000162] Console: colour dummy device 80x25
[    0.000166] printk: console [tty1] enabled
[    0.000343] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000351] pid_max: default: 32768 minimum: 301
[    0.000374] LSM: initializing lsm=capability,integrity
[    0.000437] Mount-cache hash table entries: 16384 (order: 3, 131072 bytes, linear)
[    0.000463] Mountpoint-cache hash table entries: 16384 (order: 3, 131072 bytes, linear)
[    0.000795] cgroup: Disabling memory control group subsystem
[    0.001179] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.001204] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.001229] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.001284] rcu: Hierarchical SRCU implementation.
[    0.001288] rcu:     Max phase no-delay instances is 1000.
[    0.001852] EFI services will not be available.
[    0.001909] smp: Bringing up secondary CPUs ...
[    0.002051] Detected PIPT I-cache on CPU1
[    0.002091] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[    0.002251] Detected PIPT I-cache on CPU2
[    0.002284] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[    0.002435] Detected PIPT I-cache on CPU3
[    0.002463] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[    0.002489] smp: Brought up 1 node, 4 CPUs
[    0.002507] SMP: Total of 4 processors activated.
[    0.002511] CPU features: detected: 32-bit EL0 Support
[    0.002515] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.002520] CPU features: detected: Common not Private translations
[    0.002524] CPU features: detected: CRC32 instructions
[    0.002528] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.002532] CPU features: detected: LSE atomic instructions
[    0.002536] CPU features: detected: Privileged Access Never
[    0.002539] CPU features: detected: RAS Extension Support
[    0.002544] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.002577] CPU: All CPU(s) started at EL2
[    0.002581] alternatives: applying system-wide alternatives
[    0.004201] devtmpfs: initialized
[    0.007184] Enabled cp15_barrier support
[    0.007193] Enabled setend support
[    0.007249] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.007259] futex hash table entries: 1024 (order: 2, 65536 bytes, linear)
[    0.007524] pinctrl core: initialized pinctrl subsystem
[    0.007640] DMI not present or invalid.
[    0.007798] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.008382] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.008430] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.008479] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.008498] audit: initializing netlink subsys (disabled)
[    0.008548] audit: type=2000 audit(0.008:1): state=initialized audit_enabled=0 res=1
[    0.008662] thermal_sys: Registered thermal governor 'step_wise'
[    0.008674] cpuidle: using governor menu
[    0.008743] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.008772] ASID allocator initialised with 32768 entries
[    0.009080] Serial: AMBA PL011 UART driver
[    0.009780] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[    0.009981] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev2
[    0.009995] printk: console [ttyAMA10] enabled
[    0.764496] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-09-10T13:40:30, variant start_cd
[    0.778551] raspberrypi-firmware soc:firmware: Firmware hash is 5be4f30400000000000000000000000000000000
[    0.794143] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[    0.801226] Modules: 0 pages in range for non-PLT usage
[    0.801228] Modules: 129412 pages in range for PLT usage
[    0.811063] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[    0.824001] iommu: Default domain type: Translated
[    0.828905] iommu: DMA domain TLB invalidation policy: strict mode
[    0.835199] SCSI subsystem initialized
[    0.838993] usbcore: registered new interface driver usbfs
[    0.844506] usbcore: registered new interface driver hub
[    0.849844] usbcore: registered new device driver usb
[    0.854998] pps_core: LinuxPPS API ver. 1 registered
[    0.859980] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.869154] PTP clock support registered
[    0.873340] vgaarb: loaded
[    0.876158] clocksource: Switched to clocksource arch_sys_counter
[    0.882393] VFS: Disk quotas dquot_6.6.0
[    0.886339] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[    0.893443] FS-Cache: Loaded
[    0.896365] CacheFiles: Loaded
[    0.900902] NET: Registered PF_INET protocol family
[    0.905943] IP idents hash table entries: 131072 (order: 6, 1048576 bytes, linear)
[    0.915925] tcp_listen_portaddr_hash hash table entries: 4096 (order: 2, 65536 bytes, linear)
[    0.924543] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, linear)
[    0.932321] TCP established hash table entries: 65536 (order: 5, 524288 bytes, linear)
[    0.940539] TCP bind hash table entries: 65536 (order: 7, 2097152 bytes, linear)
[    0.949595] TCP: Hash tables configured (established 65536 bind 65536)
[    0.956289] MPTCP token hash table entries: 8192 (order: 3, 196608 bytes, linear)
[    0.963925] UDP hash table entries: 4096 (order: 3, 131072 bytes, linear)
[    0.970844] UDP-Lite hash table entries: 4096 (order: 3, 131072 bytes, linear)
[    0.978247] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.984047] RPC: Registered named UNIX socket transport module.
[    0.989992] RPC: Registered udp transport module.
[    0.994711] RPC: Registered tcp transport module.
[    0.999429] RPC: Registered tcp-with-tls transport module.
[    1.004938] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.011408] PCI: CLS 0 bytes, default 64
[    1.015399] Trying to unpack rootfs image as initramfs...
[    1.020915] kvm [1]: IPA Size Limit: 40 bits
[    1.028183] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[    1.036988] kvm [1]: vgic interrupt IRQ9
[    1.040941] kvm [1]: VHE mode initialized successfully
[    1.109301] Initialise system trusted keyrings
[    1.113866] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    1.120357] zbud: loaded
[    1.123153] NFS: Registering the id_resolver key type
[    1.128242] Key type id_resolver registered
[    1.132444] Key type id_legacy registered
[    1.136476] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.143206] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.150699] F2FS not supported on PAGE_SIZE(16384) != 4096
[    1.156297] Key type asymmetric registered
[    1.160411] Asymmetric key parser 'x509' registered
[    1.165328] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.172811] io scheduler mq-deadline registered
[    1.177364] io scheduler kyber registered
[    1.181410] io scheduler bfq registered
[    1.186179] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 26)
[    1.191278] Freeing initrd memory: 11488K
[    1.194031] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 27)
[    1.205699] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 28)
[    1.213433] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 29)
[    1.223363] bcm2708_fb soc:fb: Unable to determine number of FBs. Disabling driver.
[    1.231057] bcm2708_fb: probe of soc:fb failed with error -2
[    1.270909] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    1.277584] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 31, base_baud = 6000000) is a Broadcom BCM7271 UART
[    1.288208] serial serial0: tty port ttyS0 registered
[    1.293556] iproc-rng200 107d208000.rng: hwrng registered
[    1.299035] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[    1.307547] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[    1.316544] brd: module loaded
[    1.320896] loop: module loaded
[    1.324166] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.331536] Loading iSCSI transport class v2.0-870.
[    1.337263] usbcore: registered new device driver r8152-cfgselector
[    1.343565] usbcore: registered new interface driver r8152
[    1.349089] usbcore: registered new interface driver lan78xx
[    1.354775] usbcore: registered new interface driver smsc95xx
[    1.360595] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.366381] dwc_otg: FIQ enabled
[    1.366383] dwc_otg: NAK holdoff enabled
[    1.366384] dwc_otg: FIQ split-transaction FSM enabled
[    1.366387] Module dwc_common_port init
[    1.366511] usbcore: registered new interface driver uas
[    1.371852] usbcore: registered new interface driver usb-storage
[    1.377978] mousedev: PS/2 mouse device common for all mice
[    1.391916] rpi-rtc soc:rpi_rtc: registered as rtc0
[    1.398333] rpi-rtc soc:rpi_rtc: setting system clock to 2024-09-21T08:23:07 UTC (1726906987)
[    1.407215] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[    1.413774] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.422532] sdhci: Secure Digital Host Controller Interface driver
[    1.428740] sdhci: Copyright(c) Pierre Ossman
[    1.433148] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.439017] ledtrig-cpu: registered to indicate activity on CPUs
[    1.445092] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.451571] hid: raw HID events driver (C) Jiri Kosina
[    1.456742] usbcore: registered new interface driver usbhid
[    1.462334] usbhid: USB HID core driver
[    1.466490] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
[    1.475046] NET: Registered PF_PACKET protocol family
[    1.480143] Key type dns_resolver registered
[    1.489954] registered taskstats version 1
[    1.494132] Loading compiled-in X.509 certificates
[    1.501244] Key type .fscrypt registered
[    1.505210] Key type fscrypt-provisioning registered
[    1.511242] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[    1.518256] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@120000, using [bus 00-ff]
[    1.527372] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[    1.535685] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[    1.543992] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[    1.552295] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[    1.561779] brcm-pcie 1000120000.pcie: Forcing gen 2
[    1.567008] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0000:00
[    1.573479] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.578987] pci_bus 0000:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[    1.589560] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[    1.600754] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400
[    1.606809] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.613238] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.728165] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[    1.734825] pci 0000:01:00.0: [1de4:0001] type 00 class 0x020000
[    1.740867] pci 0000:01:00.0: reg 0x10: [mem 0xffffc000-0xffffffff]
[    1.747165] pci 0000:01:00.0: reg 0x14: [mem 0xffc00000-0xffffffff]
[    1.753461] pci 0000:01:00.0: reg 0x18: [mem 0xffff0000-0xffffffff]
[    1.759820] pci 0000:01:00.0: supports D1
[    1.763842] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[    1.780169] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.786818] pci 0000:00:00.0: BAR 8: assigned [mem 0x1f00000000-0x1f005fffff]
[    1.793985] pci 0000:01:00.0: BAR 1: assigned [mem 0x1f00000000-0x1f003fffff]
[    1.801152] pci 0000:01:00.0: BAR 2: assigned [mem 0x1f00400000-0x1f0040ffff]
[    1.808319] pci 0000:01:00.0: BAR 0: assigned [mem 0x1f00410000-0x1f00413fff]
[    1.815486] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.820469] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
[    1.827636] pci 0000:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    1.836118] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    1.844662] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    1.850817] pcieport 0000:00:00.0: PME: Signaling with IRQ 36
[    1.856643] pcieport 0000:00:00.0: AER: enabled with IRQ 36
[    1.862317] rp1 0000:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[    1.871408] rp1 0000:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[    1.880675] rp1 0000:01:00.0: enabling device (0000 -> 0002)
[    1.887245] rp1 0000:01:00.0: chip_id 0x20001927
[    1.896717] genirq: irq_chip rp1_irq_chip did not update eff. affinity mask of irq 98
[    1.925091] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 104 (d8:3a:dd:a3:56:a5)
[    1.935959] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[    1.944518] xhci-hcd xhci-hcd.0: xHCI Host Controller
[    1.949595] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[    1.957289] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
[    1.966296] xhci-hcd xhci-hcd.0: irq 129, io mem 0x1f00200000
[    1.972135] xhci-hcd xhci-hcd.0: xHCI Host Controller
[    1.977206] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[    1.984460] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
[    1.990622] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    1.998926] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.006183] usb usb1: Product: xHCI Host Controller
[    2.011079] usb usb1: Manufacturer: Linux 6.6.50-v8-16k+ xhci-hcd
[    2.017196] usb usb1: SerialNumber: xhci-hcd.0
[    2.021769] hub 1-0:1.0: USB hub found
[    2.025544] hub 1-0:1.0: 2 ports detected
[    2.029701] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[    2.038004] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.045259] usb usb2: Product: xHCI Host Controller
[    2.050156] usb usb2: Manufacturer: Linux 6.6.50-v8-16k+ xhci-hcd
[    2.056286] usb usb2: SerialNumber: xhci-hcd.0
[    2.060904] hub 2-0:1.0: USB hub found
[    2.064676] hub 2-0:1.0: 1 port detected
[    2.068875] xhci-hcd xhci-hcd.1: xHCI Host Controller
[    2.073951] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[    2.081754] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
[    2.090762] xhci-hcd xhci-hcd.1: irq 134, io mem 0x1f00300000
[    2.096694] xhci-hcd xhci-hcd.1: xHCI Host Controller
[    2.101768] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[    2.109023] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
[    2.115280] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    2.123582] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.130935] usb usb3: Product: xHCI Host Controller
[    2.135830] usb usb3: Manufacturer: Linux 6.6.50-v8-16k+ xhci-hcd
[    2.141947] usb usb3: SerialNumber: xhci-hcd.1
[    2.146599] hub 3-0:1.0: USB hub found
[    2.150372] hub 3-0:1.0: 2 ports detected
[    2.154510] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[    2.162914] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.170170] usb usb4: Product: xHCI Host Controller
[    2.175088] usb usb4: Manufacturer: Linux 6.6.50-v8-16k+ xhci-hcd
[    2.181330] usb usb4: SerialNumber: xhci-hcd.1
[    2.185878] hub 4-0:1.0: USB hub found
[    2.189657] hub 4-0:1.0: 1 port detected
[    2.194209] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    2.202656] platform 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    2.210699] platform 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    2.218863] platform 1000800000.codec: Adding to iommu group 0
[    2.224727] platform 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    2.233056] platform 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    2.241272] platform 1000880000.pisp_be: Adding to iommu group 0
[    2.247333] platform 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    2.255296] platform 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    2.263361] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[    2.270532] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    2.278876] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[    2.286094] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    2.294437] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[    2.302201] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
[    2.302424] of_cfs_init
[    2.307415] mmc0: CQHCI version 5.10
[    2.309767] of_cfs_init: OK
[    2.316185] clk: Disabling unused clocks
[    2.355841] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[    2.366657] Freeing unused kernel memory: 5056K
[    2.371258] Run /init as init process
[    2.374931]   with arguments:
[    2.374932]     /init
[    2.374933]   with environment:
[    2.374934]     HOME=/
[    2.374936]     TERM=linux
[    2.412182] usb 3-2: new full-speed USB device number 2 using xhci-hcd
[    2.464324] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[    2.499901] mmcblk0: mmc0:59b4 SD128 119 GiB
[    2.534393]  mmcblk0: p1 p2
[    2.537612] mmcblk0: mmc0:59b4 SD128 119 GiB (quirks 0x00004000)
[    2.611299] usb 3-2: New USB device found, idVendor=1a86, idProduct=55d4, bcdDevice= 4.42
[    2.619527] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.626695] usb 3-2: Product: SONOFF Zigbee 3.0 USB Dongle Plus V2
[    2.632916] usb 3-2: Manufacturer: ITEAD
[    2.636851] usb 3-2: SerialNumber: 20231009100444
[    3.209960] EXT4-fs (mmcblk0p2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
[    4.260263] NET: Registered PF_INET6 protocol family
[    4.265625] Segment Routing with IPv6
[    4.269319] In-situ OAM (IOAM) with IPv6
[    4.376090] systemd[1]: systemd 252.30-1~deb12u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    4.408953] systemd[1]: Detected architecture arm64.
[    4.420332] systemd[1]: Hostname set to <openhabian>.
[    4.513875] uart-pl011 107d001000.serial: no DMA platform data
[    5.180669] systemd[1]: Queued start job for default target multi-user.target.
[    5.208791] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    5.216554] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    5.224754] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    5.233896] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    5.242924] systemd[1]: Created slice user.slice - User and Session Slice.
[    5.249946] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[    5.261139] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    5.271854] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    5.284503] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-2f2c2eb2\x2d01.device - /dev/disk/by-partuuid/2f2c2eb2-01...
[    5.295905] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10...
[    5.303300] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[    5.311048] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    5.320041] systemd[1]: Reached target paths.target - Path Units.
[    5.326237] systemd[1]: Reached target slices.target - Slice Units.
[    5.332590] systemd[1]: Reached target swap.target - Swaps.
[    5.338247] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    5.346826] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    5.355679] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    5.364715] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    5.373192] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    5.382284] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    5.390091] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    5.398373] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    5.406528] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    5.436256] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    5.445182] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    5.454084] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    5.462302] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    5.480239] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    5.490175] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    5.500113] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    5.510461] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    5.520196] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    5.529532] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    5.538456] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    5.548491] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    5.557478] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[    5.565487] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    5.582515] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    5.592188] systemd[1]: Starting systemd-journald.service - Journal Service...
[    5.601177] fuse: init (API version 7.39)
[    5.603079] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    5.621002] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    5.632579] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    5.642826] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    5.652621] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    5.657925] EXT4-fs (mmcblk0p2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w. Quota mode: none.
[    5.670770] systemd[1]: Started systemd-journald.service - Journal Service.
[    5.746146] systemd-journald[268]: Received client request to flush runtime journal.
[    6.277258] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[    6.277461] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[    6.277517] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[    6.277562] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[    6.277723] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[    6.277774] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[    6.277821] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[    6.277989] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[    6.278088] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
[    6.278125] input: pwr_button as /devices/platform/pwr_button/input/input0
[    6.278354] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
[    6.338185] mc: Linux media interface: v0.10
[    6.441531] videodev: Linux video capture interface: v2.00
[    6.636164] Bluetooth: Core ver 2.22
[    6.636212] NET: Registered PF_BLUETOOTH protocol family
[    6.636214] Bluetooth: HCI device and connection manager initialized
[    6.636222] Bluetooth: HCI socket layer initialized
[    6.636226] Bluetooth: L2CAP socket layer initialized
[    6.636230] Bluetooth: SCO socket layer initialized
[    6.684103] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    6.685359] pispbe 1000880000.pisp_be: Runtime PM usage count underflow!
[    6.759790] Bluetooth: HCI UART driver ver 2.3
[    6.759799] Bluetooth: HCI UART protocol H4 registered
[    6.759829] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    6.759951] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[    6.760003] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[    6.760033] Bluetooth: HCI UART protocol Broadcom registered
[    6.879783] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    6.887059] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    6.888348] rpivid 1000800000.codec: Device registered as /dev/video19
[    7.116587] Bluetooth: hci0: BCM: chip id 107
[    7.116795] Bluetooth: hci0: BCM: features 0x2f
[    7.117872] Bluetooth: hci0: BCM4345C0
[    7.117874] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[    7.166683] cdc_acm 3-2:1.0: ttyACM0: USB ACM device
[    7.166727] usbcore: registered new interface driver cdc_acm
[    7.166730] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    7.368051] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,5-model-b.hcd' Patch
[    8.052822] Bluetooth: hci0: BCM: features 0x2f
[    8.054227] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[    8.054230] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[    8.054521] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[    9.370000] zram: Added device: zram0
[    9.370783] zram0: detected capacity change from 0 to 2097152
[    9.397480] Adding 2097136k swap on /var/swap.  Priority:-2 extents:19 across:13672448k SS
[    9.443840] Adding 1048560k swap on /dev/zram0.  Priority:75 extents:1 across:1048560k SS
[    9.700804] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    9.700813] Bluetooth: BNEP filters: protocol multicast
[    9.700821] Bluetooth: BNEP socket layer initialized
[    9.702981] Bluetooth: MGMT ver 1.22
[    9.778031] NET: Registered PF_ALG protocol family
[    9.800222] systemd-journald[268]: Received client request to flush runtime journal.
[    9.808693] systemd-journald[268]: Received SIGTERM from PID 1 (systemd).
[    9.808910] systemd[1]: Stopping systemd-journald.service - Journal Service...
[    9.809570] systemd[1]: systemd-journald.service: Deactivated successfully.
[    9.809766] systemd[1]: Stopped systemd-journald.service - Journal Service.
[    9.811323] systemd[1]: systemd-journald-audit.socket: Deactivated successfully.
[    9.811518] systemd[1]: Closed systemd-journald-audit.socket - Journal Audit Socket.
[    9.811813] systemd[1]: systemd-journald.socket: Deactivated successfully.
[    9.812008] systemd[1]: Closed systemd-journald.socket - Journal Socket.
[    9.813524] systemd[1]: systemd-journald-dev-log.socket: Deactivated successfully.
[    9.813717] systemd[1]: Closed systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    9.828724] systemd[1]: rpi-eeprom-update.service: Main process exited, code=exited, status=1/FAILURE
[    9.828875] systemd[1]: rpi-eeprom-update.service: Failed with result 'exit-code'.
[    9.829112] systemd[1]: Failed to start rpi-eeprom-update.service - Check for Raspberry Pi EEPROM updates.
[    9.854670] systemd[1]: Started systemd-hostnamed.service - Hostname Service.
[    9.910417] zram: Added device: zram1
[    9.924394] zram1: detected capacity change from 0 to 1536000
[    9.937101] systemd[1]: Started raspi-config.service - LSB: Switch to ondemand cpu governor (unless shift key is pressed).
[   10.366005] EXT4-fs (zram1): mounted filesystem ec9fd195-7b08-44b8-9b8f-1a8848b673aa r/w with ordered data mode. Quota mode: none.
[   10.393105] systemd[1]: Started wpa_supplicant.service - WPA supplicant.
[   10.568615] zram: Added device: zram2
[   10.572723] zram2: detected capacity change from 0 to 2097152
[   10.594429] EXT4-fs (zram2): mounted filesystem 5f2d5314-6aa5-4750-9c2e-01eaadd63164 r/w with ordered data mode. Quota mode: none.
[   10.608503] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   10.609764] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[   10.611033] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   12.112656] systemd[1]: Starting systemd-journald.service - Journal Service...
[   12.113023] systemd[1]: Started NetworkManager.service - Network Manager.
[   12.113560] systemd[1]: Reached target network.target - Network.
[   12.180574] systemd[1]: Mounting srv-openhab\x2daddons.mount - openhab-addons mount...
[   12.197636] systemd[1]: Mounting srv-openhab\x2dconf.mount - openhab-conf mount...
[   12.204189] systemd[1]: Mounting srv-openhab\x2dsys.mount - openhab-sys mount...
[   12.268624] systemd[1]: Mounting srv-openhab\x2duserdata.mount - openhab-userdata mount...
[   12.270782] systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
[   12.272637] systemd[1]: Starting mosquitto.service - Mosquitto MQTT Broker...
[   12.340581] systemd[1]: Starting ssh.service - OpenBSD Secure Shell server...
[   12.342315] systemd[1]: Starting systemd-user-sessions.service - Permit User Sessions...
[   12.344089] systemd[1]: Started zigbee2mqtt.service - zigbee2mqtt.
[   12.349363] systemd[1]: Started systemd-journald.service - Journal Service.
[   14.903864] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[   14.903873] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
[   14.906563] pps pps0: new PPS source ptp0
[   14.906659] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[   20.033293] macb 1f00100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx
[11535.925580] systemd[130838]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[134812.280265] usb 3-2: USB disconnect, device number 2
[135007.330105] usb 3-2: new full-speed USB device number 3 using xhci-hcd
[135007.521543] usb 3-2: New USB device found, idVendor=1a86, idProduct=55d4, bcdDevice= 4.42
[135007.521549] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[135007.521552] usb 3-2: Product: SONOFF Zigbee 3.0 USB Dongle Plus V2
[135007.521555] usb 3-2: Manufacturer: ITEAD
[135007.521557] usb 3-2: SerialNumber: 20231009100444
[135007.536630] cdc_acm 3-2:1.0: ttyACM0: USB ACM device
journalctl | grep rpi:
Sep 21 10:23:14 openhabian systemd[1]: Starting rpi-eeprom-update.service - Check for Raspberry Pi EEPROM updates...
Sep 21 10:23:18 openhabian systemd[1]: rpi-eeprom-update.service: Main process exited, code=exited, status=1/FAILURE
Sep 21 10:23:18 openhabian systemd[1]: rpi-eeprom-update.service: Failed with result 'exit-code'.
Sep 21 10:23:18 openhabian systemd[1]: Failed to start rpi-eeprom-update.service - Check for Raspberry Pi EEPROM updates.
Stefan
I am afraid this has nothing to do with openHABian or openHAB, so you‘d better ask in a raspi community.
You grepped for rpi. In case the error message itself did not contain rpi the it will not be shown in the output. Could you check if in the lines between ( the output you got ) are more details ?
This, @Wolfgang_S? There is a lot going on…
Sep 21 10:23:14 openhabian systemd[1]: Starting setserial.service - LSB: controls configuration of serial ports...
Sep 21 10:23:14 openhabian systemd[1]: Starting sshswitch.service - Turn on SSH if /boot/ssh or /boot/firmware/ssh is present...
Sep 21 10:23:14 openhabian systemd[1]: Starting systemd-logind.service - User Login Management...
Sep 21 10:23:14 openhabian systemd[1]: systemd-pcrphase.service - TPM2 PCR Barrier (User) was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKerne>
Sep 21 10:23:14 openhabian systemd[1]: Starting triggerhappy.service - triggerhappy global hotkey daemon...
Sep 21 10:23:14 openhabian systemd[1]: Starting zram-config.service - zram-config...
Sep 21 10:23:14 openhabian cron[596]: (CRON) INFO (pidfile fd = 3)
Sep 21 10:23:14 openhabian systemd[1]: Finished networking.service - Raise network interfaces.
Sep 21 10:23:14 openhabian systemd[1]: Started zram-config.service - zram-config.
Sep 21 10:23:14 openhabian systemd-logind[605]: Watching system buttons on /dev/input/event0 (pwr_button)
Sep 21 10:23:14 openhabian systemd-logind[605]: New seat seat0.
Sep 21 10:23:14 openhabian thd[606]: Found socket passed from systemd
Sep 21 10:23:14 openhabian systemd[1]: Started triggerhappy.service - triggerhappy global hotkey daemon.
Sep 21 10:23:14 openhabian systemd[1]: Started setserial.service - LSB: controls configuration of serial ports.
Sep 21 10:23:14 openhabian systemd[1]: Started etc-setserial.service - LSB: controls configuration of serial ports.
Sep 21 10:23:14 openhabian avahi-daemon[591]: Found user 'avahi' (UID 104) and group 'avahi' (GID 110).
Sep 21 10:23:14 openhabian avahi-daemon[591]: Successfully dropped root privileges.
Sep 21 10:23:14 openhabian avahi-daemon[591]: avahi-daemon 0.8 starting up.
Sep 21 10:23:14 openhabian cron[596]: (CRON) INFO (Running @reboot jobs)
Sep 21 10:23:14 openhabian zram-config[649]: zram-config start 2024-09-21-10:23:14-CEST
Sep 21 10:23:15 openhabian zram-config[607]: createZdevice: Beginning creation of zDevice.
Sep 21 10:23:15 openhabian systemd[1]: sshswitch.service: Deactivated successfully.
Sep 21 10:23:15 openhabian systemd[1]: Finished sshswitch.service - Turn on SSH if /boot/ssh or /boot/firmware/ssh is present.
Sep 21 10:23:15 openhabian dphys-swapfile[598]: want /var/swap=16104MByte, restricting to config limit: 2048MBytes, checking existing: keeping it
Sep 21 10:23:15 openhabian kernel: zram: Added device: zram0
Sep 21 10:23:15 openhabian kernel: zram0: detected capacity change from 0 to 2097152
Sep 21 10:23:15 openhabian systemd[1]: Finished dphys-swapfile.service - dphys-swapfile - set up, mount/unmount, and delete a swap file.
Sep 21 10:23:15 openhabian kernel: Adding 2097136k swap on /var/swap.  Priority:-2 extents:19 across:13672448k SS
Sep 21 10:23:15 openhabian bluetoothd[595]: Bluetooth daemon 5.66
Sep 21 10:23:15 openhabian kernel: Adding 1048560k swap on /dev/zram0.  Priority:75 extents:1 across:1048560k SS
Sep 21 10:23:15 openhabian systemd[1]: Started dbus.service - D-Bus System Message Bus.
Sep 21 10:23:15 openhabian dbus-daemon[597]: [system] Successfully activated service 'org.freedesktop.systemd1'
Sep 21 10:23:15 openhabian avahi-daemon[591]: Successfully called chroot().
Sep 21 10:23:15 openhabian systemd[1]: Starting NetworkManager.service - Network Manager...
Sep 21 10:23:15 openhabian avahi-daemon[591]: Successfully dropped remaining capabilities.
Sep 21 10:23:15 openhabian avahi-daemon[591]: No service file found in /etc/avahi/services.
Sep 21 10:23:15 openhabian bluetoothd[595]: Starting SDP server
Sep 21 10:23:15 openhabian avahi-daemon[591]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
Sep 21 10:23:15 openhabian avahi-daemon[591]: New relevant interface lo.IPv6 for mDNS.
Sep 21 10:23:15 openhabian avahi-daemon[591]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Sep 21 10:23:15 openhabian avahi-daemon[591]: New relevant interface lo.IPv4 for mDNS.
Sep 21 10:23:15 openhabian avahi-daemon[591]: Network interface enumeration completed.
Sep 21 10:23:15 openhabian avahi-daemon[591]: Registering new address record for ::1 on lo.*.
Sep 21 10:23:15 openhabian avahi-daemon[591]: Registering new address record for 127.0.0.1 on lo.IPv4.
Sep 21 10:23:15 openhabian bluetoothd[595]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Sep 21 10:23:15 openhabian bluetoothd[595]: src/plugin.c:plugin_init() Failed to init vcp plugin
Sep 21 10:23:15 openhabian bluetoothd[595]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Sep 21 10:23:15 openhabian bluetoothd[595]: src/plugin.c:plugin_init() Failed to init mcp plugin
Sep 21 10:23:15 openhabian bluetoothd[595]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Sep 21 10:23:15 openhabian bluetoothd[595]: src/plugin.c:plugin_init() Failed to init bap plugin
Sep 21 10:23:15 openhabian systemd[1]: Starting wpa_supplicant.service - WPA supplicant...
Sep 21 10:23:15 openhabian systemd[1]: Started systemd-logind.service - User Login Management.
Sep 21 10:23:15 openhabian systemd[1]: Started avahi-daemon.service - Avahi mDNS/DNS-SD Stack.
Sep 21 10:23:15 openhabian systemd[1]: Started bluetooth.service - Bluetooth service.
Sep 21 10:23:15 openhabian systemd[1]: Reached target bluetooth.target - Bluetooth Support.
Sep 21 10:23:15 openhabian dbus-daemon[597]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.4' (uid=0 pid=5>
Sep 21 10:23:15 openhabian bluetoothd[595]: Bluetooth management interface 1.22 initialized
Sep 21 10:23:15 openhabian kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Sep 21 10:23:15 openhabian kernel: Bluetooth: BNEP filters: protocol multicast
Sep 21 10:23:15 openhabian kernel: Bluetooth: BNEP socket layer initialized
Sep 21 10:23:15 openhabian kernel: Bluetooth: MGMT ver 1.22
Sep 21 10:23:15 openhabian systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
Sep 21 10:23:15 openhabian kernel: NET: Registered PF_ALG protocol family
Sep 21 10:23:15 openhabian systemd-journald[268]: Runtime Journal (/run/log/journal/988c9294753246e58bef44052d5155db) is 8.0M, max 80.5M, 72.5M free.
Sep 21 10:23:15 openhabian systemd-journald[268]: Received client request to flush runtime journal.
Sep 21 10:23:15 openhabian systemd-journald[268]: Journal stopped
Sep 21 10:23:18 openhabian systemd-journald[268]: Received SIGTERM from PID 1 (systemd).
Sep 21 10:23:18 openhabian systemd[1]: Stopping systemd-journald.service - Journal Service...
Sep 21 10:23:18 openhabian systemd[1]: systemd-journald.service: Deactivated successfully.
Sep 21 10:23:18 openhabian systemd[1]: Stopped systemd-journald.service - Journal Service.
Sep 21 10:23:18 openhabian systemd[1]: systemd-journald-audit.socket: Deactivated successfully.
Sep 21 10:23:18 openhabian systemd[1]: Closed systemd-journald-audit.socket - Journal Audit Socket.
Sep 21 10:23:18 openhabian systemd[1]: systemd-journald.socket: Deactivated successfully.
Sep 21 10:23:18 openhabian systemd[1]: Closed systemd-journald.socket - Journal Socket.
Sep 21 10:23:18 openhabian systemd[1]: systemd-journald-dev-log.socket: Deactivated successfully.
Sep 21 10:23:18 openhabian systemd[1]: Closed systemd-journald-dev-log.socket - Journal Socket (/dev/log).
