False alarms from Fibaro smoke sensor FGSD-002
I’m having trouble configuring my three z-wave Fibaro smoke alarms (FGSD-002).
They all apear to be included and everything successfully into the network but they randomly show alarms as triggered.
The sensors have multiple channels such as Smoke alarm, Heat alarm, Low battery alarm and more. These all seem to randomly trigger.
However they trigger without any siren luckily.
I’ve tested the actual smoke detection with real smoke and that set off the siren just as it should.
If I look into the Basic UI for one of the smoke detectors it can look like this:
Some times only 1 or 2 alarms are triggered, it seems to be at random. All three of the smoke detectors are acting in the same wierd way.
So I’m not sure that it’s that I’ve not set the parameters correctly. I haven’t changed any of the parameters. I’ve found that I rarely have to do that with any of my other devices that I’ve installed thus far.
Down below is the current parameters that are set for the device(s).
Lifeline is set to my openhab controller.
And this is the z-wave XML file for one of the devices.
<node>
  <deviceClass>
    <basicDeviceClass>ROUTING_SLAVE</basicDeviceClass>
    <genericDeviceClass>SENSOR_NOTIFICATION</genericDeviceClass>
    <specificDeviceClass>NOTIFICATION_SENSOR</specificDeviceClass>
  </deviceClass>
  <homeId>0xf2e219e5</homeId>
  <nodeId>11</nodeId>
  <version>4</version>
  <manufacturer>0x10f</manufacturer>
  <deviceId>0x1002</deviceId>
  <deviceType>0xc02</deviceType>
  <listening>false</listening>
  <frequentlyListening>false</frequentlyListening>
  <routing>true</routing>
  <security>false</security>
  <beaming>true</beaming>
  <maxBaudRate>40000</maxBaudRate>
  <nodeInformationFrame>
    <commandClass>ZWAVE_PLUS_INFO</commandClass>
    <commandClass>BASIC</commandClass>
    <commandClass>VERSION</commandClass>
    <commandClass>MANUFACTURER_SPECIFIC</commandClass>
    <commandClass>DEVICE_RESET_LOCALLY</commandClass>
    <commandClass>ASSOCIATION_GROUP_INFO</commandClass>
    <commandClass>ASSOCIATION</commandClass>
    <commandClass>POWERLEVEL</commandClass>
    <commandClass>WAKE_UP</commandClass>
    <commandClass>BATTERY</commandClass>
    <commandClass>ALARM</commandClass>
    <commandClass>CRC_16_ENCAP</commandClass>
    <commandClass>CONFIGURATION</commandClass>
    <commandClass>SENSOR_MULTILEVEL</commandClass>
    <commandClass>MULTI_INSTANCE_ASSOCIATION</commandClass>
    <commandClass>APPLICATION_STATUS</commandClass>
    <commandClass>SENSOR_ALARM</commandClass>
    <commandClass>SECURITY</commandClass>
    <commandClass>FIRMWARE_UPDATE_MD</commandClass>
  </nodeInformationFrame>
  <supportedCommandClasses>
    <entry>
      <zwavePlusCommandClass>
        <version>1</version>
        <instances>1</instances>
        <versionSupported>2</versionSupported>
        <zwPlusVersion>1</zwPlusVersion>
        <zwPlusRole>6</zwPlusRole>
        <zwPlusNodeType>0</zwPlusNodeType>
        <zwPlusDeviceType>0xc01</zwPlusDeviceType>
        <zwPlusInstallerIcon>0xc01</zwPlusInstallerIcon>
        <isGetSupported>true</isGetSupported>
      </zwavePlusCommandClass>
    </entry>
    <entry>
      <manufacturerSpecificCommandClass>
        <initSerialNumber>false</initSerialNumber>
        <deviceManufacturer>271</deviceManufacturer>
        <deviceType>3074</deviceType>
        <deviceId>4098</deviceId>
      </manufacturerSpecificCommandClass>
    </entry>
    <entry>
      <alarmCommandClass>
        <version>5</version>
        <versionSupported>5</versionSupported>
        <alarms>
          <entry>
            <alarmType>SMOKE</alarmType>
            <alarmState>
              <reportedEvents>
                <int>2</int>
                <int>3</int>
              </reportedEvents>
              <outer-class reference="../../../.."/>
            </alarmState>
          </entry>
          <entry>
            <alarmType>POWER_MANAGEMENT</alarmType>
            <alarmState>
              <reportedEvents>
                <int>10</int>
              </reportedEvents>
            </alarmState>
          </entry>
          <entry>
            <alarmType>HEAT</alarmType>
            <alarmState>
              <reportedEvents>
                <int>2</int>
              </reportedEvents>
            </alarmState>
          </entry>
          <entry>
            <alarmType>BURGLAR</alarmType>
            <alarmState>
              <reportedEvents>
                <int>3</int>
              </reportedEvents>
            </alarmState>
          </entry>
          <entry>
            <alarmType>SYSTEM</alarmType>
            <alarmState>
              <reportedEvents>
                <int>1</int>
              </reportedEvents>
            </alarmState>
          </entry>
        </alarms>
        <v1Supported>true</v1Supported>
      </alarmCommandClass>
    </entry>
    <entry>
      <crc16EncapsulationCommandClass>
        <versionSupported>1</versionSupported>
      </crc16EncapsulationCommandClass>
    </entry>
    <entry>
      <versionCommandClass>
        <version>2</version>
        <libraryType>LIB_SLAVE_ENHANCED</libraryType>
        <protocolVersion>4.5</protocolVersion>
        <applicationVersion>3.3</applicationVersion>
        <hardwareVersion>2</hardwareVersion>
      </versionCommandClass>
    </entry>
    <entry>
      <multiLevelSensorCommandClass>
        <version>8</version>
        <versionSupported>8</versionSupported>
        <sensors>
          <entry>
            <multilevelSensorType>TEMPERATURE</multilevelSensorType>
            <multilevelSensor>
              <sensorType>TEMPERATURE</sensorType>
              <initialised>true</initialised>
            </multilevelSensor>
          </entry>
        </sensors>
      </multiLevelSensorCommandClass>
    </entry>
    <entry>
      <ZWaveApplicationStatusClass>
      </ZWaveApplicationStatusClass>
    </entry>
    <entry>
      <basicCommandClass>
      </basicCommandClass>
    </entry>
    <entry>
      <multiAssociationCommandClass>
        <maxGroups>5</maxGroups>
      </multiAssociationCommandClass>
    </entry>
    <entry>
      <commandClass>SENSOR_BINARY</commandClass>
      <binarySensorCommandClass>
        <version>0</version>
        <instances>0</instances>
        <versionSupported>0</versionSupported>
        <types/>
      </binarySensorCommandClass>
    </entry>
    <entry>
      <batteryCommandClass>
        <batteryLevel>100</batteryLevel>
        <batteryLow>false</batteryLow>
      </batteryCommandClass>
    </entry>
    <entry>
      <associationCommandClass>
      </associationCommandClass>
    </entry>
    <entry>
      <securityCommandClassWithInit>
        <disableEncapNonceGet>false</disableEncapNonceGet>
        <securePairingComplete>false</securePairingComplete>
      </securityCommandClassWithInit>
    </entry>
    <entry>
      <alarmSensorCommandClass>
        <alarms>
          <entry>
            <alarmSensorType>SMOKE</alarmSensorType>
            <alarmSensor>
            </alarmSensor>
          </entry>
          <entry>
            <alarmSensorType>GENERAL</alarmSensorType>
            <alarmSensor>
              <alarmType>GENERAL</alarmType>
            </alarmSensor>
          </entry>
          <entry>
            <alarmSensorType>HEAT</alarmSensorType>
            <alarmSensor>
            </alarmSensor>
          </entry>
        </alarms>
        <isSupportedGetSupported>true</isSupportedGetSupported>
      </alarmSensorCommandClass>
    </entry>
    <entry>
      <firmwareUpdateCommandClass>
        <versionSupported>3</versionSupported>
      </firmwareUpdateCommandClass>
    </entry>
    <entry>
      <powerLevelCommandClass>
        <powerLevel>0</powerLevel>
        <powerTimeout>0</powerTimeout>
      </powerLevelCommandClass>
    </entry>
    <entry>
      <configurationCommandClass>
        <configParameters>
          <entry>
            <int>32</int>
            <configurationParameter>
              <index>32</index>
              <size>2</size>
              <value>180</value>
              <readOnly>false</readOnly>
              <writeOnly>false</writeOnly>
            </configurationParameter>
          </entry>
          <entry>
            <int>1</int>
              <index>1</index>
              <size>1</size>
              <value>2</value>
          </entry>
          <entry>
            <int>2</int>
              <index>2</index>
              <size>1</size>
              <value>0</value>
          </entry>
          <entry>
            <int>3</int>
              <index>3</index>
              <size>1</size>
              <value>0</value>
          </entry>
          <entry>
            <int>4</int>
              <index>4</index>
              <size>1</size>
              <value>0</value>
          </entry>
          <entry>
            <int>10</int>
              <index>10</index>
              <size>1</size>
              <value>0</value>
          </entry>
          <entry>
            <int>11</int>
              <index>11</index>
              <size>2</size>
              <value>255</value>
          </entry>
          <entry>
            <int>12</int>
              <index>12</index>
              <size>2</size>
              <value>0</value>
          </entry>
          <entry>
            <int>13</int>
              <index>13</index>
              <size>1</size>
              <value>0</value>
          </entry>
          <entry>
            <int>20</int>
              <index>20</index>
              <size>2</size>
              <value>1</value>
          </entry>
          <entry>
            <int>21</int>
              <index>21</index>
              <size>1</size>
              <value>10</value>
          </entry>
          <entry>
            <int>30</int>
              <index>30</index>
              <size>1</size>
              <value>55</value>
          </entry>
          <entry>
            <int>31</int>
              <index>31</index>
              <size>2</size>
              <value>1</value>
          </entry>
        </configParameters>
      </configurationCommandClass>
    </entry>
    <entry>
      <commandClass>NO_OPERATION</commandClass>
      <noOperationCommandClass>
      </noOperationCommandClass>
    </entry>
    <entry>
      <WakeUpCommandClass>
        <targetNodeId>1</targetNodeId>
        <interval>21600</interval>
        <minInterval>4200</minInterval>
        <maxInterval>65535</maxInterval>
        <defaultInterval>21600</defaultInterval>
        <intervalStep>1</intervalStep>
        <lastWakeup>2017-01-21 16:13:46.788 UTC</lastWakeup>
      </WakeUpCommandClass>
    </entry>
    <entry>
      <deviceResetLocallyCommandClass>
      </deviceResetLocallyCommandClass>
    </entry>
    <entry>
      <associationGroupInfoCommandClass>
        <autoSubscribeGroups>
          <int>1</int>
          <int>3</int>
          <int>4</int>
          <int>5</int>
        </autoSubscribeGroups>
      </associationGroupInfoCommandClass>
    </entry>
  </supportedCommandClasses>
  <securedCommandClasses/>
  <associationGroups>
    <entry>
      <int>1</int>
      <associationGroup>
        <index>1</index>
        <name>Lifeline</name>
        <profile1>0x0</profile1>
        <profile2>0x1</profile2>
        <commands>
        </commands>
        <associations>
          <associationMember>
            <node>1</node>
            <endpoint>0</endpoint>
          </associationMember>
        </associations>
      </associationGroup>
    </entry>
    <entry>
      <int>2</int>
      <associationGroup>
        <index>2</index>
        <name>Smoke Alarm</name>
        <profile1>0x71</profile1>
        <commands>
        </commands>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>3</int>
      <associationGroup>
        <index>3</index>
        <name>Tamper</name>
        <profile2>0x7</profile2>
        <commands>
        </commands>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>4</int>
      <associationGroup>
        <index>4</index>
        <commands>
        </commands>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>5</int>
      <associationGroup>
        <index>5</index>
        <name>Tamper</name>
        <commands>
        </commands>
        <associations/>
      </associationGroup>
    </entry>
  </associationGroups>
  <nodeNeighbors>
    <int>1</int>
    <int>4</int>
    <int>7</int>
    <int>8</int>
  </nodeNeighbors>
  <lastSent>2017-01-21 17:43:52.824 UTC</lastSent>
  <lastReceived>2017-01-21 16:13:52.721 UTC</lastReceived>
</node>
Any advice is appriciated! :slight_smile:
Maybe related to:
Thanks sihui! I’ll explore that thread! :slight_smile:
Come to think of it I think they actually were working a while back! I have only had them for maybe 3 weeks or so and I thought they did work to begin with. But I wasn’t really sure any longer if it was just a sensor ghost in my brain that thoght so. hehe
