I have a GE / Jasco12730 (ZW4002) Fan Control with z-wave binding. Lately I’ve noticed that if I set the fan speed at anything lower than 40%, the speed does change, I hear the motor adjust, but then the fan stops after just a few seconds. Reviewing the OH logs, I see that it does take the command to change the speed, but nothing to indicate it has stopped. I’ve checked several times that the speed set by the pull cord directly on the fan is set to the highest setting so that the Fan Control can take over from there. I’m not sure what can be causing this. It seems anything above 40% makes it work fine.
Here’s an example of the log:
2021-06-28 18:52:19.145 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘BedroomFan’ received command 30
2021-06-28 18:52:19.184 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘BedroomFan’ predicted to become 30
2021-06-28 18:52:19.198 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘BedroomFan’ changed from 50 to 30
2021-06-28 18:53:30.944 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘BedroomFan’ received command 50
2021-06-28 18:53:30.956 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘BedroomFan’ predicted to become 50
2021-06-28 18:53:30.962 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘BedroomFan’ changed from 30 to 50
The fan turns off shortly after “changed from 50 to 30”.
Does anybody have any ideas what may be going on? What should I check for?
I am using OH3.0.1 on openabian.
Thanks!
