Feature Request: Configurable Sorting for oh-repeater
Component: oh-repeater
Description:
The oh-repeater should support configurable sorting when using sourceType: itemsInGroup.
Currently, items are sorted alphabetically by ItemName by default. It would be useful to have an additional option to preserve the original definition order of items.
Proposed configuration:
yaml
- component: oh-repeater
    for: item
    groupItem: gPV
    sortBy: definition
  slots:
    default:
      - component: oh-label-item
          item: =loop.item.name
          title: =loop.item.label
Requested sorting options:
  • name: Alphabetical sorting by ItemName (current behavior).
  • definition: Preserve the order in which items are defined in the openHAB item configuration.
Goal:
Provide more control over the display order of items in MainUI, especially for groups where items have been deliberately defined in a specific order.
The current default sorting behavior should remain unchanged for backward compatibility.
This can already be achieved by using:
fetchMetadata: widgetOrder
If the widgetOrder is set in MainUI, it will be used for sorting.
As an example, you can check the floors menu in semanticHomeMenu.
Thanks! Regarding a related issue, I was just about to give up and look for a JS-based solution when @hr3’s post appeared … immediately I’ve given it a like.
Lets say that it wasn’t easy to find the right way to achieve what one wants…
This is everything the documentation says about fetchMetadata:
Really hard to understand to me :sweat_smile:
Following your suggestion, I looked for the metadata:
where the “alexa” example is like a ray of light in the darkness.:joy:
In the end, this is what I added to the item channels:
And it works for me. Still, I agree with the author of the post: default automate sorting even by position could be an idea. And, ideally, it should be documented. :wink:
Thank you
