Feature Request: Scene-Editor
I am very much missing real scenes.
In a scene I want to define different items with different states and the scene should reflect its actual status.
Status of a scene:
  • If all items of the scene have there defined state the status of the scene should be ON
  • If one or more items have a different state then the state of the scene should be OFF
Funktion of a scene:
  • One should be able to switch a scene ON and OFF (also from HomeKit or Alexa …)
  • When switched to ON all items should switch to there defined state (like a rule)
  • When switched to OFF either nothing should happen or you should be able to define different states for the items.
  • When an item of the scene gets changed manually or by any other scene or event the status of the scene should reflect that but should not execute the scene.
