Feeling rusty... compare two times?
Shame on me, but I need to refresh my rule ability… let’s say I have something like this
How do compare two times so I know how many seconds is between those?
Do I need convert DateTime states to something to be able to substract them? cos this is not working :wink:
Things
DateTime myTime_on
DateTime myTime_off
Text myPeriod
Rule
rule "compare times"
  myItem received update
  val lastON  = myTime_on.state
  val lastOFF = myTime_off.state
  val diff = lastOFF - lastON
  postUpdate(myPeriod, diff)
Thanks, my brain is not working … :frowning:
Yes. You need to get epoch (milliseconds since 1970-01-01T00:00:00.000). Textual Rules | openHAB has a good reference for working with DateTimeTypes in Rules.
    val lastOn = (myTime_on.state as DateTimeType).zonedDateTime.timeInMillis
    val lastOff = (myTime_off.state as DateTimeType).zonedDateTime.timeInMillis
    val diff = (lastOff - lastOn) / 1000
as always, thank you @rlkoshak you are lifesaver :wink:
edit:
The method or field timeInMillis is undefined for the type ZonedDateTime(org.eclipse.xtext.diagnostics.Diagnostic.Linking
Is there a need to include something at the begining of the rules?
Z should be lower case? zonedDateTime
it is
Maybe this from this post
val lastOn = (myTime_on.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli
that worked, thanks :wink:
Hmmm, it would appear the docs are wrong. I copied and pasted from those.
It depends on what you’ve written your rule in. With scripted automation, Jython and the helper libraries, you can use the core.date.seconds_between function…
from core.log import logging, LOG_PREFIX#, log_traceback
from core.date import seconds_between
LOG = logging.getLogger("{}.TEST".format(LOG_PREFIX))
LOG.warn(seconds_between(items["Virtual_DateTime_1"], items["Virtual_DateTime_2"]))
However, java.time.temporal.ChonoUnit provides something similar…
from java.time.temporal.ChronoUnit import SECONDS
LOG.warn(SECONDS.between(items["Virtual_DateTime_1"].zonedDateTime, items["Virtual_DateTime_2"].zonedDateTime))
This can also be used in the rules DSL…
import java.time.temporal.ChronoUnit
rule "Test DSL rule"
    System started
    logWarn("Rules", "Test: Start")
    logWarn("Rules", "{}", ChronoUnit.SECONDS.between((Virtual_DateTime_1.state as DateTimeType).zonedDateTime, (Virtual_DateTime_2.state as DateTimeType).zonedDateTime))
    logWarn("Rules", "Test: End")
well this is getting quite interesting :wink:
2020-01-23 21:56:47.882 [INFO ] [lipse.smarthome.model.script.->> one] - -25
2020-01-23 21:56:47.883 [INFO ] [lipse.smarthome.model.script.->> two] - -53
val lastOn = (ItemON.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli
    val lastOff = (itemOFF.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli
    logInfo("->> one", diff.toString)
    logInfo("->> two", "{}", ChronoUnit.SECONDS.between((itemOFF.state as DateTimeType).zonedDateTime, (itemON.state as DateTimeType).zonedDateTime))
and physical device console
21:55:55 MQT: home/test/sensor/PIR = ON
21:56:48 MQT: home/test/sensor/PIR = OFF
so, If I did not missed math in school that’s exactly 53s. That means second approach calculates it correctly, but first is somehow calculating only 25s?
few moments later I’ve got this
22:01:45 MQT: home/test/sensor/PIR = ON
22:02:39 MQT: home/test/sensor/PIR = OFF
which is 56s
but log
2020-01-23 22:02:37.972 [INFO ] [lipse.smarthome.model.script.->> one] - -296
2020-01-23 22:02:37.973 [INFO ] [lipse.smarthome.model.script.->> two] - 296
Am I overlooking something?
You probably want to log out the timestamps the rule is working with.
Guessing you are triggering the rule from something that is only vaguely linked to those getting updated, you might be looking at a race condition.
nope, it’s inside one rule so everything is triggered at same time
at least for point of view of code.
A great resource for understanding this better is the awesome time conversion thread by rud @anfaenger found here
thanks, solving similar things it seems :wink:
anyway looks like OH is having difficulties to work with changed times inside single rule.
Splitted into two and seems to be behaving better.
Both your failing and successful rules are secret, this makes it difficult to comment constructively.
In the skeleton example at the top, the rule is triggered by one Item updating, but the timestamps are derived from other Items which we have no way of knowing how or when they get updated.
In the later snippet you posted with two methods, each method fetches its ‘data’ independently from Items. There is no guarantee that these Items do not changed inbetween. It’s not a fair test.
