I just received my new fenecon inverter (20kW solar [east, south and west] and 25kWh battery). So far, everything seems to be working. I have the default query interval of 30 seconds.
What’s bothering me is that I keep getting the following message at rare, irregular intervals.
2025-09-03 11:13:30.171 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fenecon:home-device:local' changed from OFFLINE (COMMUNICATION_ERROR): Communication error: java.io.EOFException: @28ee27c5::SocketChannelEndPoint@278b70a6{l=/192.168.0.50:52910,r=/192.168.0.68:8084,ISHUT,fill=-,flush=-,to=0/0}{io=0/0,kio=0,kro=1}->@28ee27c5(l:/192.168.0.50:52910 <-> r:/192.168.0.68:8084,closed=false)=>@1b9a606f(exchange=HttpExchange@47d18c63{req=HttpRequest[GET /rest/channel/_sum/(ConsumptionActivePower%7CConsumptionActivePowerL1%7CConsumptionActivePowerL2%7CConsumptionActivePowerL3%7CConsumptionMaxActivePower%7CEssDischargePower%7CEssSoc%7CGridActivePower%7CGridBuyActiveEnergy%7CGridMode%7CGridSellActiveEnergy%7CProductionActivePower%7CProductionMaxActivePower%7CState) HTTP/1.1]@1e585b53[TERMINATED/null] res=HttpResponse[null 0 null]@622a167e[PENDING/null]})[send=HttpSenderOverHTTP@2afb9b4c(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@6182b8e4{s=START}],recv=CustomHttpReceiverOverHTTP@3ddce544(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]] with FENECON system on channel: _sum/(ConsumptionActivePower%7CConsumptionActivePowerL1%7CConsumptionActivePowerL2%7CConsumptionActivePowerL3%7CConsumptionMaxActivePower%7CEssDischargePower%7CEssSoc%7CGridActivePower%7CGridBuyActiveEnergy%7CGridMode%7CGridSellActiveEnergy%7CProductionActivePower%7CProductionMaxActivePower%7CState) to ONLINE
The inverter is connected via ethernet and not via wifi.
Has anyone an idea, what could be the reason?
The logs on the inverter side looks good without any hints for the reason.
