In console I type items, got 163 lines, but not all items will update frequently,
I got around 20 items will have update every 5 minutes, and around 20 items will update every 2 minutes,
then I found few items (usually around 1-2 items) status is not stored in influx (it will change to another items from time to time), I have tried drop that measurements with same result until I restart openhab/RPI3 (I am not sure which one get works), but I am pretty sure not all the items status get saved in influxDB, but in console, I confirms the items status get updated just not saved in influxDB.
as not saved items usually happens to 2 minutes update items, does openhab got limit when items updated too frequently? anyone got same issue as mine?
Hardware: RPI 3B,
OS: openhabian, openhab 2.0 with the most update by openhabian-config
Thanks for your explain, I do understand value will save only when value is changed,
issue were I confirm value was changed but data not output to influx.
I have tried to output only part of the item to influx and it make much better,
so is there a limit of items for output to influx?
