Hi all,
currently I’m trying to make my first OH2 experiences using z wave. I was running an OH1.8 instance in our previous appartment not using z wave.
For practising an testing OH2 (2.1.0-SNAPSHOT Build #785) on my MacBook Pro using an AEON Z-Stick GEN5 (ZW090-C) with a FGMS-001 (v.3.2 build Oct. 2016). Once i know how to setup the single devices I will move the system to an RPI3.
After hundreds of trial and error and constantly reading this forum I’m still unable to communicate with FGMS-001. it I managed to connect it to my z wave network as node 2 but being displayed as unknown device:
As written above I tried various method described here in the forum but unfortunately OH is still unable to recognize the Motion Sensor properly. Also by clicking the Thing configuration, tool or any other option I cannot influence the node 2. I already tried to remove node 2 and add it again but doesn’t help either.
below please find the log file displayed right after system restart:
openhab> log:tail
15:41:17.456 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Wohnwand_Brightness-milight:rgbLed:ACCF23506326:8:ledbrightness' has been added.
15:41:17.512 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'zwave:serial_zstick:Z-Stick' has been added.
15:41:17.514 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'milight:rgbLed:ACCF23506326:9' has been added.
15:41:17.516 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'milight:bridge:ACCF23506326' has been added.
15:41:17.518 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'milight:rgbLed:ACCF23506326:8' has been added.
15:41:17.520 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'zwave:device:Z-Stick:node2' has been added.
15:41:18.044 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
15:41:18.327 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
15:41:18.423 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
15:41:18.630 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
15:41:18.734 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
15:41:18.810 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
15:41:18.872 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'milight:rgbLed:ACCF23506326:9' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
15:41:18.872 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'milight:rgbLed:ACCF23506326:8' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
15:41:18.892 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'milight:bridge:ACCF23506326' changed from UNINITIALIZED to INITIALIZING
15:41:18.973 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:Z-Stick:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
15:41:20.192 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:Z-Stick' changed from UNINITIALIZED to INITIALIZING
15:41:20.195 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:Z-Stick' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
15:41:20.196 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/cu.usbmodem1421'
15:41:20.213 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:Z-Stick:node2' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
15:41:20.214 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:Z-Stick:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
15:41:20.255 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
15:41:20.260 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
15:41:20.269 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
15:41:20.269 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
15:41:21.904 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'milight:bridge:ACCF23506326' changed from INITIALIZING to OFFLINE
15:41:21.909 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'milight:rgbLed:ACCF23506326:8' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
15:41:21.909 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'milight:rgbLed:ACCF23506326:9' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
15:41:21.910 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'milight:rgbLed:ACCF23506326:8' changed from INITIALIZING to OFFLINE
15:41:21.911 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'milight:rgbLed:ACCF23506326:9' changed from INITIALIZING to OFFLINE
15:41:23.416 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
15:41:23.416 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
15:41:23.417 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
15:41:23.417 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
15:41:23.417 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
15:41:23.417 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
15:41:23.417 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
15:41:23.590 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Restore from config: Error. Data invalid, ignoring config.
15:41:23.594 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:Z-Stick' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
15:41:23.598 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:Z-Stick:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
I read about the problems due to new software in FGMS but I also see many other guy making this sensor work. I’m really desperate and after researching forum and web since days I cannot find even a single solution that I’m able to understand.
Is there anybody out there who can help me managing the configuration that FGMS is at least recognised as Fibaro Motion sensor?
Thanks in advance
Ben
Edit: Milight is currently offline since I’m on business trip but of course I brought Z-Wave Stick and FGMS with me. At home Milight works perfectly fine.
