I use a Fibaro Double Switch 2 with two lights and one momentary switch connected. Is it possible to control the light connected to q2 with s1 (long tap, double tap…)?
thank you!
thank you!
Have you checked the manual? There is a copy of the manual on the page for the zwave database entry.
If not, where have you searched for the answer?
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
thank you for your reply!
If i had found the answer in the manual or elswhere, I wouldn‘t ask ![]()
So, yes I already checked the manual and searched the internet, including oh community.
There look to be many configuration options. Here is our device listing.
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/416
Not directly, both s1 and s2 are hard wired to q1 and q2. You’ll have to catch an double tap with a rule and send the command to q2. But q1 will also react to the command. Check the manual for scene control and double tap function.
As already mentioned: yes, with scenes.
You will get
Switch 1: 1xclick=1.0 ,2xclick=1.3,3xclick=1.4,press and hold=1.1
Switch 2: 1xclick=2.0 ,2xclick=2.3,3xclick=2.4,press and hold=2.1
https://manuals.fibaro.com/switch-2/
Additional features
Activating scenes
The Switch 2 can activate scenes in the Z-Wave controller by sending scene ID and attribute of a specific action using Central Scene Command Class.
By default scenes are not activated, set parameters 28 and 29 to enable scene activation for selected actions.
Switch Action Scene ID Attribute Switch connected to S1 terminal Switch clicked once 1 Key Pressed 1 time Switch clicked twice 1 Key Pressed 2 times Switch clicked thrice 1 Key Pressed 3 times Switch held 1 Key Held Down Switch released 1 Key Released Switch connected to S2 terminal Switch clicked once 2 Key Pressed 1 time Switch clicked twice 2 Key Pressed 2 times Switch clicked thrice 2 Key Pressed 3 times Switch held 2 Key Held Down Switch released 2 Key Released
Works great! Thanks!
