I have purchased another fibaro smoke sensor but after receiving it, I realised it’s actually a new, different version of the product!
I am using following config:
Contact ZWave_Fire_IND_ServerRoom_Smoke "Server room fire detected" (IND_ServerRoom) { zwave="15:command=sensor_alarm,alarm_type=1" }
Contact ZWave_Fire_IND_ServerRoom_Tamper "Smoke detector tampered" (IND_ServerRoom) { zwave="15:command=sensor_alarm,alarm_type=0" }
Number ZWave_Fire_IND_ServerRoom_Battery "Smoke detector batt Level [%d %%]" (IND_ServerRoom, LocalPersist, gZwaveBatteries) { zwave="15:command=battery" }
Number ZWave_Fire_IND_ServerRoom_Temperature "Smoke detector temperature [%.1f °C]" (IND_ServerRoom, LocalPersist) { zwave="15:command=sensor_multilevel,sensor_type=1" }
I am receiving temperature updates, however, the item with battery is not updated (I have not tested the alarms yet).
When I look through HABmin, I can see the battery under “power”.
Also, the Generic Device Class is GARAGE_DOOR - is this correct?
