Sorry.
Unfiltered and in friendly format for the post.
2017-07-03 22:12:09.496 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Command received zwave:device:15cf518cecd:node6:switch_binary --> OFF
2017-07-03 22:12:09.498 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 6: Creating new message for application command SWITCH_BINARY_SET
2017-07-03 22:12:09.500 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-07-03 22:12:09.500 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-07-03 22:12:09.503 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 06 03 25 01 00 25 2B C9
2017-07-03 22:12:09.505 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 0A 00 13 06 03 25 01 00 25 2B C9
2017-07-03 22:12:09.506 [ItemCommandEvent ] - Item 'WallPlugSwitch1_Switch' received command OFF
2017-07-03 22:12:09.517 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-07-03 22:12:09.522 [ItemStateChangedEvent ] - WallPlugSwitch1_Switch changed from ON to OFF
2017-07-03 22:12:09.523 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-07-03 22:12:09.525 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-07-03 22:12:09.527 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-07-03 22:12:09.530 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-07-03 22:12:09.532 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: Sent Data successfully placed on stack.
2017-07-03 22:12:09.731 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 2B 00 00 16 D6
2017-07-03 22:12:09.735 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-07-03 22:12:09.738 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 2B 00 00 16 00 00 D8
2017-07-03 22:12:09.740 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 2B 00 00 16 00 00 D8
2017-07-03 22:12:09.742 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=2B 00 00 16
2017-07-03 22:12:09.744 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: SendData Request. CallBack ID = 43, Status = Transmission complete and ACK received(0)
2017-07-03 22:12:09.746 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
2017-07-03 22:12:09.748 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@75c27b already registered
2017-07-03 22:12:09.750 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=6, callback=43, payload=06 03 25 01 00
2017-07-03 22:12:09.753 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=2B 00 00 16
2017-07-03 22:12:09.754 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=43, expected=SendData, cancelled=false transaction complete!
2017-07-03 22:12:09.756 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-07-03 22:12:09.758 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-07-03 22:12:09.760 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Response processed after 249ms/4864ms.
2017-07-03 22:12:10.157 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 06 07 60 0D 00 B8 25 03 00 04
2017-07-03 22:12:10.162 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-07-03 22:12:10.165 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 04 00 06 07 60 0D 00 B8 25 03 00 04
2017-07-03 22:12:10.169 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0D 00 04 00 06 07 60 0D 00 B8 25 03 00 04
2017-07-03 22:12:10.172 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 07 60 0D 00 B8 25 03 00
2017-07-03 22:12:10.175 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Application Command Request (ALIVE:DONE)
2017-07-03 22:12:10.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
2017-07-03 22:12:10.181 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@75c27b already registered
2017-07-03 22:12:10.184 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Incoming command class MULTI_INSTANCE
2017-07-03 22:12:10.187 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Received MULTI_INSTANCE command V0
2017-07-03 22:12:10.190 [INFO ] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Received a multi instance encapsulation with a destination endpoint = 184.
2017-07-03 22:12:10.192 [WARN ] [class.ZWaveMultiInstanceCommandClass] - NODE 6: The originating endpoint is 0. Please notify author.
2017-07-03 22:12:10.195 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Requested Command Class = SWITCH_BINARY (0x25)
2017-07-03 22:12:10.198 [WARN ] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Originating Command Class SWITCH_BINARY (0x25) was on the root node.
2017-07-03 22:12:10.201 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Endpoint = 0, calling handleApplicationCommandRequest.
2017-07-03 22:12:10.204 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - Received Switch Binary Request for Node ID = 6
2017-07-03 22:12:10.206 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 6: Switch Binary report, value = 0
2017-07-03 22:12:10.209 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-07-03 22:12:10.212 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-07-03 22:12:10.215 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_BINARY, value = 0
2017-07-03 22:12:10.219 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Updating channel state zwave:device:15cf518cecd:node6:switch_binary to OFF [OnOffType]
2017-07-03 22:12:10.225 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=6, callback=43, payload=06 03 25 01 00
2017-07-03 22:12:10.230 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 07 60 0D 00 B8 25 03 00
2017-07-03 22:12:10.232 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=43, expected=SendData, cancelled=false MISMATCH
2017-07-03 22:12:10.587 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 06 0A 60 0D 00 B8 31 05 04 22 00 00 20
2017-07-03 22:12:10.591 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-07-03 22:12:10.594 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 06 0A 60 0D 00 B8 31 05 04 22 00 00 20
2017-07-03 22:12:10.597 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 06 0A 60 0D 00 B8 31 05 04 22 00 00 20
2017-07-03 22:12:10.600 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 0A 60 0D 00 B8 31 05 04 22 00 00
2017-07-03 22:12:10.602 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Application Command Request (ALIVE:DONE)
2017-07-03 22:12:10.604 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
2017-07-03 22:12:10.606 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@75c27b already registered
2017-07-03 22:12:10.608 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Incoming command class MULTI_INSTANCE
2017-07-03 22:12:10.609 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Received MULTI_INSTANCE command V0
2017-07-03 22:12:10.611 [INFO ] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Received a multi instance encapsulation with a destination endpoint = 184.
2017-07-03 22:12:10.613 [WARN ] [class.ZWaveMultiInstanceCommandClass] - NODE 6: The originating endpoint is 0. Please notify author.
2017-07-03 22:12:10.615 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Requested Command Class = SENSOR_MULTILEVEL (0x31)
2017-07-03 22:12:10.617 [WARN ] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Originating Command Class SENSOR_MULTILEVEL (0x31) was on the root node.
2017-07-03 22:12:10.618 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Endpoint = 0, calling handleApplicationCommandRequest.
2017-07-03 22:12:10.620 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 6: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5
2017-07-03 22:12:10.622 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 6: Sensor Multi Level REPORT received
2017-07-03 22:12:10.623 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 6: Sensor Type = Power(4), Scale = 0
2017-07-03 22:12:10.625 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 6: Sensor Value = 0E+1
2017-07-03 22:12:10.627 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2017-07-03 22:12:10.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2017-07-03 22:12:10.630 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 0E+1
2017-07-03 22:12:10.633 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Updating channel state zwave:device:15cf518cecd:node6:sensor_power to 0 [DecimalType]
2017-07-03 22:12:10.635 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=6, callback=43, payload=06 03 25 01 00
2017-07-03 22:12:10.639 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 0A 60 0D 00 B8 31 05 04 22 00 00
2017-07-03 22:12:10.641 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=43, expected=SendData, cancelled=false MISMATCH
