I got my first rollershutter and got it to work. Puh.
But there is a little thing which does not work correctly
my item config:
Rollershutter RS_RollerShutter_01 “open [%d %%]” { channel=“zwave:device:15a7a49f3a6:node4:blinds_control”}
The position of the rollershutter is from 0 to 100. If the rollershutter stops item RS_RollerShutter_01 shows the correct value. But if the rollershutter is moving, the value changes to 0 or 100 depending on the way (up or down). After it stops, the correct value is shown again.
2017-05-01 18:00:33.305 [ItemCommandEvent ] - Item ‘RS_RollerShutter_01’ received command UP
2017-05-01 18:00:33.315 [ItemStateChangedEvent ] - RS_RollerShutter_01 changed from 60 to 0
2017-05-01 18:00:36.662 [ItemCommandEvent ] - Item ‘RS_RollerShutter_01’ received command STOP
2017-05-01 18:00:36.735 [ItemStateChangedEvent ] - RS_RollerShutter_01 changed from 0 to 74
You will say, doesn’t matter. But I want to show a chart with the position of the roller shutter and it will confuse the chart if the value jumps to 100 or 0 by movement of the rollershutter.
Should I change one of the config parameters?
