Hi again Chris,
Sorry but even on snapshot 2.1.0~20170203040910-1 the zwave node is named “Z-Wave Node 55 (010F:0701:3001:3.2)”.
Please help!
Hi again Chris,
Please help!
It looks like it should be included -:
I suspect there might be an issue where versions are equal - I’ll take a look…
Thank you! When will it build so I can update my snapshot and test?
Shortly - the build is in progress… Give it a go in an hour or two (or tomorrow morning if you’re in Europe).
I’ve just looked in my debug logs and it has:
2017-02-04 12:48:13.740 [DEBUG] [inding.zwave.internal.ZWaveActivator] - Z-Wave binding started. Version 2.1.0.201701231811
I’ve been updating from the Ubuntu repo on bintray, though, so I’m not sure why it’s saying that. Is there a cache of addons I need to remove when I install the new package?
EDIT: I’ve managed to install the correct version of the addon by installing additionally the openhab2-addons package.
Subsequently, I’m now using v2.1.0.201702020955 of the addon, and it’s now recognized the Fibaro sensor.
2017-02-04 13:07:39.781 [DEBUG] [inding.zwave.internal.ZWaveActivator] - Z-Wave binding started. Version 2.1.0.201702020955
2017-02-04 13:08:34.583 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 56: Device discovery resolved to thingType zwave:fibaro_fgk101_03_002
I’m not sure if this means the commit you just made isn’t needed, but a sincere thanks for your help with this.
just received my Fibaro FGK-10x and can not bring it to work properly. The initialisation seems ok for me. I created an item for sensor_door and one for sensor_binary and linked it again the Thing.
‘sensor_door’ stays everytime on ‘CLOSED’ state.
In the log I can see the following error:
[ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 11: Endpoint 0 not found. Cannot set command classes.
I attached the xml file node11.xml (19.6 KB) and the debug log looks like this (where I open and close the sensor):
2017-03-08 14:58:52.377 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 0B 0D 60 0D 00 00 71 05 00 00 00 FF 06 17 00 19
2017-03-08 14:58:52.393 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-03-08 14:58:52.404 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 13 00 04 00 0B 0D 60 0D 00 00 71 05 00 00 00 FF 06 17 00 19
2017-03-08 14:58:52.410 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 13 00 04 00 0B 0D 60 0D 00 00 71 05 00 00 00 FF 06 17 00 19
2017-03-08 14:58:52.416 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0B 0D 60 0D 00 00 71 05 00 00 00 FF 06 17 00
2017-03-08 14:58:52.422 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
2017-03-08 14:58:52.425 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1d6894d already registered
2017-03-08 14:58:52.431 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 11: Received MULTI_INSTANCE command V0
2017-03-08 14:58:52.434 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 11: Requested Command Class = ALARM (0x71)
2017-03-08 14:58:52.437 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 11: Endpoint 0 not found. Cannot set command classes.
2017-03-08 14:58:52.459 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 08 0B 03 30 03 00 C1
2017-03-08 14:58:52.464 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-03-08 14:58:52.469 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 08 0B 03 30 03 00 C1
2017-03-08 14:58:52.473 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 08 0B 03 30 03 00 C1
2017-03-08 14:58:52.478 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=08 0B 03 30 03 00
2017-03-08 14:58:52.482 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
2017-03-08 14:58:52.484 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1d6894d already registered
2017-03-08 14:58:52.484 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0B 03 30 03 00 C9
2017-03-08 14:58:52.485 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 11: Received SENSOR_BINARY command V1
2017-03-08 14:58:52.486 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 11: Sensor Binary report, type=Unknown, value=0
2017-03-08 14:58:52.488 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveBinarySensorValueEvent
2017-03-08 14:58:52.489 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2017-03-08 14:58:52.491 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 0
2017-03-08 14:58:52.493 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:ea3e020e:node11:sensor_binary to OFF [OnOffType]
2017-03-08 14:58:52.498 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-03-08 14:58:52.500 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 0B 03 30 03 00 C9
2017-03-08 14:58:52.504 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 0B 03 30 03 00 C9
2017-03-08 14:58:52.509 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0B 03 30 03 00
2017-03-08 14:58:52.515 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
2017-03-08 14:58:52.518 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1d6894d already registered
2017-03-08 14:58:52.524 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 11: Received SENSOR_BINARY command V1
2017-03-08 14:58:52.527 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 11: Sensor Binary report, type=Unknown, value=0
2017-03-08 14:58:52.530 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveBinarySensorValueEvent
2017-03-08 14:58:52.534 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2017-03-08 14:58:52.537 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 0
2017-03-08 14:58:52.540 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:ea3e020e:node11:sensor_binary to OFF [OnOffType]
2017-03-08 14:58:57.311 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 0B 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00 18
2017-03-08 14:58:57.318 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-03-08 14:58:57.323 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 13 00 04 00 0B 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00 18
2017-03-08 14:58:57.327 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 13 00 04 00 0B 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00 18
2017-03-08 14:58:57.331 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0B 0D 60 0D 00 00 71 05 00 00 00 FF 06 16 00
2017-03-08 14:58:57.335 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
2017-03-08 14:58:57.337 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1d6894d already registered
2017-03-08 14:58:57.341 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 11: Received MULTI_INSTANCE command V0
2017-03-08 14:58:57.343 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 11: Requested Command Class = ALARM (0x71)
2017-03-08 14:58:57.345 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 11: Endpoint 0 not found. Cannot set command classes.
2017-03-08 14:58:57.393 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 08 0B 03 30 03 FF 3E
2017-03-08 14:58:57.398 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-03-08 14:58:57.404 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 08 0B 03 30 03 FF 3E
2017-03-08 14:58:57.407 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 08 0B 03 30 03 FF 3E
2017-03-08 14:58:57.411 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=08 0B 03 30 03 FF
2017-03-08 14:58:57.415 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
2017-03-08 14:58:57.416 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1d6894d already registered
2017-03-08 14:58:57.420 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 11: Received SENSOR_BINARY command V1
2017-03-08 14:58:57.422 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 11: Sensor Binary report, type=Unknown, value=255
2017-03-08 14:58:57.424 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveBinarySensorValueEvent
2017-03-08 14:58:57.425 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2017-03-08 14:58:57.427 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 255
2017-03-08 14:58:57.430 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:ea3e020e:node11:sensor_binary to ON [OnOffType]
I just changed the Association Group 1 Lifeline to “openHAB Controller” and wake up the sensor to sync properly.
I’m using openHAB2 Stable (from openHABian) with Binding Version 2.0.0. The Sensor has the Firmware Version 3.2 (as I can see in HABmin)
Hope someone can help me, find the problem…
Kind regards
Julian
Please make sure you are using the latest ZWave binding - it should solve the issue with the endpoint error.
I’ve had the same problems a few weeks ago.
I did like @sihui and @chris suggested and that solved my problem:
Thanks @anfaenger & @chris, I updated to the Snapshot version and now the sensor works as expected.
Now I have some other problems, like some Syntax errors in the Sitemaps and Item files but this is some diligence work…
Thanks again and this community is awesome
Hi, i also have this issue.
After some tips from this post i managed to see the “Closed” status on HABmin.
I removed the ZWAVE Biding and reinstalled it. Now i see “Closed”. But it never changed to open.
I am completly new to openHAB2 an would be thankfull if someone can halp me.
Nils
Did you check, what chris suggested?
To get, the newest version, I had to switch from stable to snapshot.
Sorry but how did i Update to the snapshot? I’m using openHABian in the latest version.
