Hi, i’m pretty new to this and im setting up a new system based on OH2 and a bunch of FGDW-002 door/window sensors.
I cant get the door sensor to report if its open or closed.
After some browsing it appears that this device is brand new (i noticed that it got added to the database just 2 weeks ago).
I using the latest snapshot of OH2.1, as OH2 stable would not recognize the device.
When open and closing the door (moving the magnet close to the device an then away) i get this in the logs :
Open
2017-06-12 23:54:52.331 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 02 09 71 05 00 00 00 FF 06 17 00 65
2017-06-12 23:54:52.336 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-06-12 23:54:52.339 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0F 00 04 00 02 09 71 05 00 00 00 FF 06 17 00 65
2017-06-12 23:54:52.342 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0F 00 04 00 02 09 71 05 00 00 00 FF 06 17 00 65
2017-06-12 23:54:52.344 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 02 09 71 05 00 00 00 FF 06 17 00
2017-06-12 23:54:52.346 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Application Command Request (ALIVE:DONE)
2017-06-12 23:54:52.347 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Starting initialisation from DONE
2017-06-12 23:54:52.349 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@fa0c72 already registered
2017-06-12 23:54:52.350 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Incoming command class ALARM
2017-06-12 23:54:52.351 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Received ALARM command V5
2017-06-12 23:54:52.352 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Process NOTIFICATION_REPORT V5
2017-06-12 23:54:52.354 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: NOTIFICATION report - 0 = 0, event=23, status=255
2017-06-12 23:54:52.355 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Alarm Type = ACCESS_CONTROL (0)
2017-06-12 23:54:52.356 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-06-12 23:54:52.358 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-06-12 23:54:52.359 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-06-12 23:54:52.361 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-06-12 23:54:52.362 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-06-12 23:54:52.363 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 23, type OnOffType
2017-06-12 23:54:52.365 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:02c877b5:node2:alarm_access to ON [OnOffType]
2017-06-12 23:54:52.369 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-06-12 23:54:52.371 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-06-12 23:54:52.373 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Message has Ack Pending: Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=2, callback=119, payload=02 02 30 02
Close
2017-06-12 23:55:03.555 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 02 09 71 05 00 00 00 FF 06 16 00 64
2017-06-12 23:55:03.566 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-06-12 23:55:03.569 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0F 00 04 00 02 09 71 05 00 00 00 FF 06 16 00 64
2017-06-12 23:55:03.572 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0F 00 04 00 02 09 71 05 00 00 00 FF 06 16 00 64
2017-06-12 23:55:03.575 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 02 09 71 05 00 00 00 FF 06 16 00
2017-06-12 23:55:03.577 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Application Command Request (ALIVE:DONE)
2017-06-12 23:55:03.578 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Starting initialisation from DONE
2017-06-12 23:55:03.580 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@fa0c72 already registered
2017-06-12 23:55:03.582 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Incoming command class ALARM
2017-06-12 23:55:03.583 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Received ALARM command V5
2017-06-12 23:55:03.585 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Process NOTIFICATION_REPORT V5
2017-06-12 23:55:03.586 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: NOTIFICATION report - 0 = 0, event=22, status=255
2017-06-12 23:55:03.588 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Alarm Type = ACCESS_CONTROL (0)
2017-06-12 23:55:03.589 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-06-12 23:55:03.591 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-06-12 23:55:03.593 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-06-12 23:55:03.595 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-06-12 23:55:03.596 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-06-12 23:55:03.598 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 22, type OnOffType
2017-06-12 23:55:03.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:02c877b5:node2:alarm_access to ON [OnOffType]
2017-06-12 23:55:03.603 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-06-12 23:55:03.604 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-06-12 23:55:03.606 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Message has Ack Pending: Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=2, callback=119, payload=02 02 30 02
It looks like it triggers the node2:alarm_access to ON in both cases.
I’ve read some other posts about the Z-Wave binding triggering the wrong channel(s) but no reports on FGDW-002 yet.
I think that these to notifications should go to the Door Sensor channel instead of the Alarm (access) channel.
Anyone got this device working?
Any clues on where to dig to find a solution?
This is how the device got discovered in paper-UI :
