when adding these nodes , wake them up more then once by pushing the button 3 times every 15 min so they get included correctly.
kindest regards
also when posting here , always post your items file to.
kindest regards
Did you solve the “not awake” problem, I have a FGMS001 sensor who was working fine and suddenly stopped working. I am now getting the “node not awake!” message in my logs.
Thanks for any help
Check your association group or maybe change the battery ![]()
You are aware that this thread is an openHAB version 1 thread?
Thanks, sorry, I didn’t realize the thread was V1. I Will try your suggestion but I’m not sure I can set associations if not awake. I have tried changing the battery but that’s not it.
You should be able to wake it up manually. Open the cover and push the button.
I’ve tried to manually wake it many times but nothing happens. The sensor indicates it is waking (blue pulsing light) but on the logs I only get the:
listening == false, frequentlyListening == false, awake == false
node not awake!
message.
Flat battery? Too far away from the controller?
Are your other devices working?
This device fell at some point and something feels loose inside (but it worked liked that for over 6 months) but I wonder if it fell again…
PS: it’s a fibaro PIR (FGMS001)
Time to buy a new one. ![]()
it’s on its way ![]()
Got the new one, working fine! So I guess someone who remains silent knocked off the old one…
Don’t blame someone else ![]()
