Fibaro FGR-223: How to activate scenes correctly?
Dear all,
I’m trying to get scenes working with one of my FGR-223, but it doesn’t work:
  • I added a new Item linked to scene_number, type number
  • Under Thing: Configuration I set 40 and 41 to 15 to get any scenes possible by the controller; then I clicked Save
  • In events.log I get a line: ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_41_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
But it doesn’t work, my scene item stays NULL if I press the buttons (S1, S2, long, short, all the same…).
I wonder if there is a problem with setting the parameter 40/41, because this line (see above) reads as type=PENDING - how can I find out, if the settings are applied on the controller?
Thanks.
Best,
Bernd
I don’t have any specific insight, but use the ZW binding Debug setting while setting the parameter or trying to activate the scene. I could look at the log or you can use the Zwave viewer to diagnose what is going on. Z-Wave Log Viewer (opensmarthouse.org)
Hello Bob
Thank you for the idea with the debug setting, I didn’t think of it. Well, I had a look at it and it seems to be without an error, but honestly I’m unsure, it’s quite a lot of logging output…
After changing 40 and 41 from 2 to 15, I get this in openhab.log:
2024-04-27 20:21:57.916 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update received
2024-04-27 20:21:57.924 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_32_4_0000FF00 to 0 (BigDecimal)
2024-04-27 20:21:57.926 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_30_4_000000FF to 0 (BigDecimal)
2024-04-27 20:21:57.929 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored group_1 to [controller] (ArrayList)
2024-04-27 20:21:57.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_30_4_00FF0000 to 0 (BigDecimal)
2024-04-27 20:21:57.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_32_4_7F000000 to 1 (BigDecimal)
2024-04-27 20:21:57.937 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_32_4_00FF0000 to 255 (BigDecimal)
2024-04-27 20:21:57.939 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored group_3 to [] (ListN)
2024-04-27 20:21:57.941 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored group_2 to [] (ListN)
2024-04-27 20:21:57.944 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_153_1 to 1 (BigDecimal)
2024-04-27 20:21:57.945 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_152_4 to 150 (BigDecimal)
2024-04-27 20:21:57.947 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_154_2 to 10 (BigDecimal)
2024-04-27 20:21:57.948 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored action_reinit to false (Boolean)
2024-04-27 20:21:57.950 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_155_2 to 10 (BigDecimal)
2024-04-27 20:21:57.953 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_150_1 to 0 (BigDecimal)
2024-04-27 20:21:57.955 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_151_1 to 1 (BigDecimal)
2024-04-27 20:21:57.956 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_33_4_0000FF00 to 0 (BigDecimal)
2024-04-27 20:21:57.957 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_33_4_000000FF to 0 (BigDecimal)
2024-04-27 20:21:57.958 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_33_4_00FF0000 to 255 (BigDecimal)
2024-04-27 20:21:57.959 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_156_4 to 6000 (BigDecimal)
2024-04-27 20:21:57.960 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_157_4 to 6000 (BigDecimal)
2024-04-27 20:21:57.961 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_20_1 to 0 (BigDecimal)
2024-04-27 20:21:57.962 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_31_4_000000FF to 0 (BigDecimal)
2024-04-27 20:21:57.963 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_31_4_00FF0000 to 255 (BigDecimal)
2024-04-27 20:21:57.964 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_31_4_7F000000 to 5 (BigDecimal)
2024-04-27 20:21:57.965 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_34_4_0000FF00 to 0 (BigDecimal)
2024-04-27 20:21:57.966 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update set config_41_1 to 15 (BigDecimal)
2024-04-27 20:21:57.967 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATION_SET
2024-04-27 20:21:57.968 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: SECURITY NOT required on COMMAND_CLASS_CONFIGURATION
2024-04-27 20:21:57.969 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2024-04-27 20:21:57.971 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Adding to device queue
2024-04-27 20:21:57.972 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Added 19911 to queue - size 1
2024-04-27 20:21:57.973 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2024-04-27 20:21:57.974 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 13 0A 05 70 04 29 01 0F 25 38 A1
2024-04-27 20:21:57.975 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0C 00 13 0A 05 70 04 29 01 0F 25 38 A1
2024-04-27 20:21:57.977 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2024-04-27 20:21:57.978 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 19911: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 56
2024-04-27 20:21:57.978 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2024-04-27 20:21:57.979 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:21:57.979 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATIONCMD_GET
2024-04-27 20:21:57.980 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:21:57.981 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: SECURITY NOT required on COMMAND_CLASS_CONFIGURATION
2024-04-27 20:21:57.981 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19911: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 56
2024-04-27 20:21:57.981 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2024-04-27 20:21:57.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2024-04-27 20:21:57.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Adding to device queue
2024-04-27 20:21:57.984 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:57.984 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2024-04-27 20:21:57.985 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Added 19912 to queue - size 1
2024-04-27 20:21:57.985 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:57.986 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:57.987 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration pending added for config_41_1
2024-04-27 20:21:57.987 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:57.988 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_65_2 to 10 (BigDecimal)
2024-04-27 20:21:57.988 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:57.989 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_62_2 to 3600 (BigDecimal)
2024-04-27 20:21:57.990 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19911: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 56
2024-04-27 20:21:57.991 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_61_2 to 15 (BigDecimal)
2024-04-27 20:21:57.991 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2024-04-27 20:21:57.992 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update set config_40_1 to 15 (BigDecimal)
2024-04-27 20:21:57.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 19911: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 56
2024-04-27 20:21:57.993 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATION_SET
2024-04-27 20:21:57.993 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:57.994 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: sentData successfully placed on stack.
2024-04-27 20:21:57.994 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: SECURITY NOT required on COMMAND_CLASS_CONFIGURATION
2024-04-27 20:21:57.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 19911: Advanced to WAIT_REQUEST
2024-04-27 20:21:57.995 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2024-04-27 20:21:57.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: TID 19911: Transaction not completed
2024-04-27 20:21:57.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:57.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Adding to device queue
2024-04-27 20:21:57.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Added 19913 to queue - size 2
2024-04-27 20:21:57.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.000 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATIONCMD_GET
2024-04-27 20:21:58.001 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: SECURITY NOT required on COMMAND_CLASS_CONFIGURATION
2024-04-27 20:21:58.002 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2024-04-27 20:21:58.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Adding to device queue
2024-04-27 20:21:58.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Added 19914 to queue - size 3
2024-04-27 20:21:58.004 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 38 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 05
2024-04-27 20:21:58.005 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.006 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=56, payload=38 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.006 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration pending added for config_40_1
2024-04-27 20:21:58.008 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=56, payload=38 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.008 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_60_1 to 0 (BigDecimal)
2024-04-27 20:21:58.009 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19911: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 56
2024-04-27 20:21:58.009 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2024-04-27 20:21:58.009 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_34_4_000000FF to 0 (BigDecimal)
2024-04-27 20:21:58.010 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_34_4_00FF0000 to 255 (BigDecimal)
2024-04-27 20:21:58.011 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 19911: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 56
2024-04-27 20:21:58.012 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_34_4_7F000000 to 4 (BigDecimal)
2024-04-27 20:21:58.012 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 19911: (Callback 56)
2024-04-27 20:21:58.013 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored action_heal to false (Boolean)
2024-04-27 20:21:58.013 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2024-04-27 20:21:58.014 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_32_4_000000FF to 0 (BigDecimal)
2024-04-27 20:21:58.014 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 19911: callback 56
2024-04-27 20:21:58.015 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_30_4_7F000000 to 0 (BigDecimal)
2024-04-27 20:21:58.016 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=56, payload=38 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.017 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_30_4_0000FF00 to 0 (BigDecimal)
2024-04-27 20:21:58.017 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 56, Status = Transmission complete and ACK received(0)
2024-04-27 20:21:58.018 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_33_4_7F000000_wo to 2 (BigDecimal)
2024-04-27 20:21:58.018 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: resetResendCount initComplete=true isDead=false
2024-04-27 20:21:58.019 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 19911: Transaction COMPLETED
2024-04-27 20:21:58.019 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_31_4_0000FF00 to 0 (BigDecimal)
2024-04-27 20:21:58.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Response processed after 43ms
2024-04-27 20:21:58.021 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_24_1 to 0 (BigDecimal)
2024-04-27 20:21:58.021 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: TID 19911: Transaction completed
2024-04-27 20:21:58.022 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: notifyTransactionResponse TID:19911 DONE
2024-04-27 20:21:58.022 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_25_1 to 0 (BigDecimal)
2024-04-27 20:21:58.023 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored config_66_2 to 3600 (BigDecimal)
2024-04-27 20:21:58.023 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-04-27 20:21:58.024 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.024 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update ignored node_id to 10 (BigDecimal)
2024-04-27 20:21:58.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2024-04-27 20:21:58.026 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0A 03 70 05 29 25 39 AF
2024-04-27 20:21:58.027 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0A 00 13 0A 03 70 05 29 25 39 AF
2024-04-27 20:21:58.028 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2024-04-27 20:21:58.029 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2024-04-27 20:21:58.030 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:21:58.031 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 19912: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 57
2024-04-27 20:21:58.032 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:21:58.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19912: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 57
2024-04-27 20:21:58.034 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2024-04-27 20:21:58.035 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.036 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2024-04-27 20:21:58.036 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.040 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.042 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19912: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 57
2024-04-27 20:21:58.043 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2024-04-27 20:21:58.043 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 19912: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 57
2024-04-27 20:21:58.044 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.045 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: sentData successfully placed on stack.
2024-04-27 20:21:58.046 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 19912: Advanced to WAIT_REQUEST
2024-04-27 20:21:58.046 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: TID 19912: Transaction not completed
2024-04-27 20:21:58.047 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.048 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.055 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 39 00 00 03 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 05
2024-04-27 20:21:58.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=57, payload=39 00 00 03 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.063 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=57, payload=39 00 00 03 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.064 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19912: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 57
2024-04-27 20:21:58.064 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2024-04-27 20:21:58.065 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 19912: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 57
2024-04-27 20:21:58.065 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 19912: (Callback 57)
2024-04-27 20:21:58.066 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2024-04-27 20:21:58.066 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 19912: callback 57
2024-04-27 20:21:58.067 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=57, payload=39 00 00 03 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.068 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 57, Status = Transmission complete and ACK received(0)
2024-04-27 20:21:58.068 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: resetResendCount initComplete=true isDead=false
2024-04-27 20:21:58.069 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 19912: Advanced to WAIT_DATA
2024-04-27 20:21:58.069 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: TID 19912: Transaction not completed
2024-04-27 20:21:58.070 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.070 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.072 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 0A 05 70 06 29 01 0F CA 00 62
2024-04-27 20:21:58.073 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=10, callback=0, payload=00 0A 05 70 06 29 01 0F CA 00
2024-04-27 20:21:58.074 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=10, callback=0, payload=00 0A 05 70 06 29 01 0F CA 00
2024-04-27 20:21:58.074 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2024-04-27 20:21:58.075 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Application Command Request (ALIVE:DONE)
2024-04-27 20:21:58.075 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: resetResendCount initComplete=true isDead=false
2024-04-27 20:21:58.076 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2024-04-27 20:21:58.076 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: SECURITY NOT required on COMMAND_CLASS_CONFIGURATION
2024-04-27 20:21:58.077 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2024-04-27 20:21:58.078 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Node configuration report, parameter = 41, value = 15, size = 1
2024-04-27 20:21:58.078 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2024-04-27 20:21:58.079 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CONFIGURATION, value=org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@1302b1d
2024-04-27 20:21:58.079 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Update CONFIGURATION 41/1 to 15
2024-04-27 20:21:58.080 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration pending removed for config_41_1
2024-04-27 20:21:58.081 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Commands processed 1.
2024-04-27 20:21:58.081 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1c4850d.
2024-04-27 20:21:58.082 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1c4850d.
2024-04-27 20:21:58.082 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: notifyTransactionResponse TID:19912 DONE
2024-04-27 20:21:58.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-04-27 20:21:58.084 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2024-04-27 20:21:58.084 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2024-04-27 20:21:58.085 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.085 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2024-04-27 20:21:58.086 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 13 0A 05 70 04 28 01 0F 25 3A A2
2024-04-27 20:21:58.087 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0C 00 13 0A 05 70 04 28 01 0F 25 3A A2
2024-04-27 20:21:58.087 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2024-04-27 20:21:58.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 19913: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 58
2024-04-27 20:21:58.089 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2024-04-27 20:21:58.089 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:21:58.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:21:58.091 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19913: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 58
2024-04-27 20:21:58.091 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2024-04-27 20:21:58.092 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.092 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.095 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2024-04-27 20:21:58.098 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19913: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 58
2024-04-27 20:21:58.100 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2024-04-27 20:21:58.100 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 19913: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 58
2024-04-27 20:21:58.101 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.102 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: sentData successfully placed on stack.
2024-04-27 20:21:58.102 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 19913: Advanced to WAIT_REQUEST
2024-04-27 20:21:58.103 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: TID 19913: Transaction not completed
2024-04-27 20:21:58.104 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.104 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.116 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 3A 00 00 03 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 06
2024-04-27 20:21:58.118 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=58, payload=3A 00 00 03 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.119 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=58, payload=3A 00 00 03 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.120 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19913: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 58
2024-04-27 20:21:58.120 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2024-04-27 20:21:58.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 19913: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 58
2024-04-27 20:21:58.122 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 19913: (Callback 58)
2024-04-27 20:21:58.123 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2024-04-27 20:21:58.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 19913: callback 58
2024-04-27 20:21:58.125 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=58, payload=3A 00 00 03 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.126 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 58, Status = Transmission complete and ACK received(0)
2024-04-27 20:21:58.127 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: resetResendCount initComplete=true isDead=false
2024-04-27 20:21:58.127 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 19913: Transaction COMPLETED
2024-04-27 20:21:58.128 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Response processed after 40ms
2024-04-27 20:21:58.129 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: TID 19913: Transaction completed
2024-04-27 20:21:58.129 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: notifyTransactionResponse TID:19913 DONE
2024-04-27 20:21:58.131 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-04-27 20:21:58.131 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2024-04-27 20:21:58.133 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0A 03 70 05 28 25 3B AC
2024-04-27 20:21:58.133 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0A 00 13 0A 03 70 05 28 25 3B AC
2024-04-27 20:21:58.134 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2024-04-27 20:21:58.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 19914: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 59
2024-04-27 20:21:58.135 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2024-04-27 20:21:58.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:21:58.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:21:58.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19914: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 59
2024-04-27 20:21:58.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2024-04-27 20:21:58.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.141 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2024-04-27 20:21:58.142 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.143 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19914: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 59
2024-04-27 20:21:58.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2024-04-27 20:21:58.145 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 19914: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 59
2024-04-27 20:21:58.146 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2024-04-27 20:21:58.146 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: sentData successfully placed on stack.
2024-04-27 20:21:58.147 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 19914: Advanced to WAIT_REQUEST
2024-04-27 20:21:58.148 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: TID 19914: Transaction not completed
2024-04-27 20:21:58.149 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.149 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.161 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 3B 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 06
2024-04-27 20:21:58.163 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=59, payload=3B 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=59, payload=3B 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.165 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 19914: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 59
2024-04-27 20:21:58.165 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2024-04-27 20:21:58.166 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 19914: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 59
2024-04-27 20:21:58.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 19914: (Callback 59)
2024-04-27 20:21:58.168 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2024-04-27 20:21:58.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 19914: callback 59
2024-04-27 20:21:58.170 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=59, payload=3B 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2024-04-27 20:21:58.171 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 59, Status = Transmission complete and ACK received(0)
2024-04-27 20:21:58.172 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: resetResendCount initComplete=true isDead=false
2024-04-27 20:21:58.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 19914: Advanced to WAIT_DATA
2024-04-27 20:21:58.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: TID 19914: Transaction not completed
2024-04-27 20:21:58.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2024-04-27 20:21:58.178 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 0A 05 70 06 28 01 0F CA 00 63
2024-04-27 20:21:58.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=10, callback=0, payload=00 0A 05 70 06 28 01 0F CA 00
2024-04-27 20:21:58.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=10, callback=0, payload=00 0A 05 70 06 28 01 0F CA 00
2024-04-27 20:21:58.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2024-04-27 20:21:58.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Application Command Request (ALIVE:DONE)
2024-04-27 20:21:58.183 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: resetResendCount initComplete=true isDead=false
2024-04-27 20:21:58.184 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2024-04-27 20:21:58.184 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: SECURITY NOT required on COMMAND_CLASS_CONFIGURATION
2024-04-27 20:21:58.185 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2024-04-27 20:21:58.186 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Node configuration report, parameter = 40, value = 15, size = 1
2024-04-27 20:21:58.187 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2024-04-27 20:21:58.188 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CONFIGURATION, value=org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@66743e
2024-04-27 20:21:58.188 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Update CONFIGURATION 40/1 to 15
2024-04-27 20:21:58.189 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration pending removed for config_40_1
2024-04-27 20:21:58.190 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Commands processed 1.
2024-04-27 20:21:58.191 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@8c5d18.
2024-04-27 20:21:58.192 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@8c5d18.
2024-04-27 20:21:58.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: notifyTransactionResponse TID:19914 DONE
2024-04-27 20:21:58.194 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-04-27 20:21:58.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2024-04-27 20:21:58.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2024-04-27 20:21:58.196 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:21:58.197 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2024-04-27 20:21:58.391 [WARN ] [al.profiles.MapTransformationProfile] - Could not transform state '1' with function 'config:map:WP_HeatCircuit_OperatingState' and format '%s'
2024-04-27 20:22:00.901 [INFO ] [.automation.script.ui.calc_ratio_sun] - Berechne Einstrahlung zu theoret. Lichtintensität neu:
2024-04-27 20:22:00.907 [INFO ] [.automation.script.ui.calc_ratio_sun] - 199
2024-04-27 20:22:02.362 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@89e91c
2024-04-27 20:22:02.365 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Adding to device queue
2024-04-27 20:22:02.366 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Added 19915 to queue - size 1
2024-04-27 20:22:02.367 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2024-04-27 20:22:02.369 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 51 15 3C 82
2024-04-27 20:22:02.370 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 51 15 3C 82
2024-04-27 20:22:02.370 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2024-04-27 20:22:02.371 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2024-04-27 20:22:02.372 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:22:02.373 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2024-04-27 20:22:02.373 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 19915: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 60
2024-04-27 20:22:02.374 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2024-04-27 20:22:02.374 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2024-04-27 20:22:02.375 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2024-04-27 20:22:02.375 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
Anything catching your eye?
OMG… ok, error completely on my side: by watching the output after pressing a button I noticed, that now the log shows NODE 9 entries, but above I posted NODE 10 entries. I just pressed the buttons of the wrong window - I’m sorry. There are quite a lot of windows and controllers, but nevertheless my fault and shouldn’t happen.
Thanks again…
