If installed a FGS211, switching works perfectly from openhab.
According to the docs, the switch should provide energy values (power consumption of the attached device).
I tried the following binding, but do not get energy value:
Switch Light_OG_Flur_Treppe "Flur Treppenlicht" (All) {zwave="2:command=switch_binary"}
Number Power_OG_Flur_Treppe "Treppenlicht - aktuell [%.1f W]" { zwave="2:command=sensor_multilevel"}
Number Energy_OG_Flur_Treppe "Treppenlicht - total [%.2f KWh]" { zwave="2:command=meter" }
I do not have an FGS-211 installed, but I do have several FGWPE’s (Fibaro Wall Plug). These devices also provide power consumption and energy measurements, and one could hope that since they are both Fibaro devices, the setup is similar/identical.
My working setup is as follows:
Number S01D004_nPower { zwave="9:command=sensor_multilevel, sensor_type=4" }
Number S01D004_nEnergy { zwave="9:command=meter, meter_scale=E_KWh" }
Are these the standard Fibaro 2x1.5kW relays? I don’t think they do report energy usage, at least I have never seen one doing so. Unless this is a new model of their relay model I haven’t seen yet?
You are right, I double checked the documentation. They will not report. I had a look and a third party zwave database which said those device support the meter command classes. My fault sorry.
