daunjo
(jonas.daun@gmail.com)
April 10, 2017, 10:24pm
#1
Anyone included this successfully, receiving anything from it?
chris
(Chris Jackson)
April 10, 2017, 10:42pm
#2
The search button on the forum is often a good place to start
Hi
I am struggeling with this keyfob. It will not initialize, and no node.xml get generated. Also I can se a java exception in the logfile. Im using the experimenal z-wave binding (http://www.cd-jackson.com/downloads/openhab2/org.openhab.binding.zwave-2.1.0-SNAPSHOT.jar ).
I do not know where to go from here. If anybody could give me any pointer I'd appreatiate it.
The keyfob is coming in as node5 in the logs, but no xml is appearing in userdata/zwave/
And if I press any keys on the keyfo…
I know the answer is quite late but still it may support others.
Yes, I did. At first it it did not appear as identified. Then I deleted it and initialized/searched it again and it then appeared and was identified as fibaro keyfob.
