Fibaro motion , flood sensor not working
Dear all,
I am new to OH2 and zwave, I started using OH2 because of my 1wire sensors and the persitence and grafana graphs.
So this I got to work and then I found ok zwave would be nice as well:
my setup is as follows:
raspi 3
OH2
Influx
grafana
1wire
aeon stick gen 5
fibaro wall plug working
hank smart plug working
fibaro motion sensor failing after lots of attempts
fibaro flood sensor failing after lots of attempts
I found the fibaro flood and motion in the database even with my eu id .
but somehow it is not getting setup.
I attache the debug files only of the two nodes.
A hint would be nice what else I could to do get in working. I read a lot about the process even it is described in oh2 last wake up time.
I received them on Friday and till now they are not working.
So there was enough time to get it initialised.
In the properties of OH2 things they are described as they are.
it seems I cannot attache a txt file …?? thinking how I can show the log file …??
Blockquote
thank you very much,
Roman
Copy and paste the relevant part of the log file between block quotes:
``` log1 log2 log3 ```
2018-10-15 04:07:28.177 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Application Command Request (ALIVE:DONE)
2018-10-15 04:07:28.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Starting initialisation from DONE
2018-10-15 04:07:28.180 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Incoming command class WAKE_UP
2018-10-15 04:07:28.180 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 13: Received Wake Up Request
2018-10-15 04:07:28.181 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 13: Received WAKE_UP_NOTIFICATION
2018-10-15 04:07:28.182 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 13: Is awake with 0 messages in the wake-up queue.
2018-10-15 04:07:28.184 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Got an event from Z-Wave network: ZWaveWakeUpEvent
2018-10-15 04:07:29.197 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 13: No more messages, go back to sleep
2018-10-15 04:07:29.199 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 13: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2018-10-15 04:07:29.212 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 13: Sending REQUEST Message = 01 09 00 13 0D 02 84 08 25 FF BC
2018-10-15 04:07:29.242 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 13: Sent Data successfully placed on stack.
2018-10-15 04:07:29.262 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 13: SendData Request. CallBack ID = 255, Status = Transmission complete and ACK received(0)
2018-10-15 04:07:29.264 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Starting initialisation from DONE
2018-10-15 04:07:29.285 [DEBUG] [curityCommandClassWithInitialization] - NODE 13: updating lastSentMessageTimestamp
2018-10-15 04:07:29.287 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 13: Went to sleep
2018-10-15 04:07:29.290 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 13: Is sleeping
2018-10-15 04:07:29.292 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-10-15 04:07:29.295 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Response processed after 80ms/1083ms.
2018-10-15 04:07:42.005 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent.  lastSent=13, incoming=255
2018-10-15 04:08:12.018 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent.  lastSent=13, incoming=255
2018-10-15 04:08:42.004 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent.  lastSent=13, incoming=255
seems it’s discovered:
2018-10-14 22:26:37.304 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 13: Adding slave.
2018-10-14 22:26:37.309 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Including node.
2018-10-14 22:26:37.310 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class ZWAVE_PLUS_INFO
2018-10-14 22:26:37.311 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class ZWAVE_PLUS_INFO, endpoint null created
2018-10-14 22:26:37.312 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class ZWAVE_PLUS_INFO.
2018-10-14 22:26:37.313 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class ZWAVE_PLUS_INFO to the list of supported command classes.
2018-10-14 22:26:37.314 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class APPLICATION_STATUS
2018-10-14 22:26:37.315 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class APPLICATION_STATUS, endpoint null created
2018-10-14 22:26:37.316 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class APPLICATION_STATUS.
2018-10-14 22:26:37.317 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class APPLICATION_STATUS to the list of supported command classes.
2018-10-14 22:26:37.317 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class ASSOCIATION
2018-10-14 22:26:37.318 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class ASSOCIATION, endpoint null created
2018-10-14 22:26:37.319 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class ASSOCIATION.
2018-10-14 22:26:37.319 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class ASSOCIATION to the list of supported command classes.
2018-10-14 22:26:37.320 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class ASSOCIATION_GROUP_INFO
2018-10-14 22:26:37.321 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class ASSOCIATION_GROUP_INFO, endpoint null created
2018-10-14 22:26:37.322 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class ASSOCIATION_GROUP_INFO.
2018-10-14 22:26:37.323 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class ASSOCIATION_GROUP_INFO to the list of supported command classes.
2018-10-14 22:26:37.323 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class BATTERY
2018-10-14 22:26:37.324 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class BATTERY, endpoint null created
2018-10-14 22:26:37.325 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class BATTERY.
2018-10-14 22:26:37.326 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class BATTERY to the list of supported command classes.
2018-10-14 22:26:37.326 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class CONFIGURATION
2018-10-14 22:26:37.327 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class CONFIGURATION, endpoint null created
2018-10-14 22:26:37.328 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class CONFIGURATION.
2018-10-14 22:26:37.328 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class CONFIGURATION to the list of supported command classes.
2018-10-14 22:26:37.329 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class CRC_16_ENCAP
2018-10-14 22:26:37.330 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class CRC_16_ENCAP, endpoint null created
2018-10-14 22:26:37.331 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class CRC_16_ENCAP.
2018-10-14 22:26:37.331 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class CRC_16_ENCAP to the list of supported command classes.
2018-10-14 22:26:37.332 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class DEVICE_RESET_LOCALLY
2018-10-14 22:26:37.332 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class DEVICE_RESET_LOCALLY, endpoint null created
2018-10-14 22:26:37.333 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class DEVICE_RESET_LOCALLY.
2018-10-14 22:26:37.334 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class DEVICE_RESET_LOCALLY to the list of supported command classes.
2018-10-14 22:26:37.334 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class FIRMWARE_UPDATE_MD
2018-10-14 22:26:37.335 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class FIRMWARE_UPDATE_MD, endpoint null created
2018-10-14 22:26:37.336 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class FIRMWARE_UPDATE_MD.
2018-10-14 22:26:37.336 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class FIRMWARE_UPDATE_MD to the list of supported command classes.
2018-10-14 22:26:37.337 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class MANUFACTURER_SPECIFIC
2018-10-14 22:26:37.338 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class MANUFACTURER_SPECIFIC, endpoint null created
2018-10-14 22:26:37.339 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class MANUFACTURER_SPECIFIC.
2018-10-14 22:26:37.339 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class MANUFACTURER_SPECIFIC to the list of supported command classes.
2018-10-14 22:26:37.340 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class MULTI_INSTANCE_ASSOCIATION
2018-10-14 22:26:37.340 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class MULTI_INSTANCE_ASSOCIATION, endpoint null created
2018-10-14 22:26:37.341 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class MULTI_INSTANCE_ASSOCIATION.
2018-10-14 22:26:37.342 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class MULTI_INSTANCE_ASSOCIATION to the list of supported command classes.
2018-10-14 22:26:37.342 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class ALARM
2018-10-14 22:26:37.343 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class ALARM, endpoint null created
2018-10-14 22:26:37.344 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Inclusion is adding command class ALARM.
I hope that is informative ??
Its a 0b01:1003
and the other one
0801:1002
018-10-14 22:27:17.699 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 14: Adding slave.
2018-10-14 22:27:17.703 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Including node.
2018-10-14 22:27:17.710 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class ZWAVE_PLUS_INFO
2018-10-14 22:27:17.711 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class ZWAVE_PLUS_INFO, endpoint null created
2018-10-14 22:27:17.712 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Inclusion is adding command class ZWAVE_PLUS_INFO.
2018-10-14 22:27:17.713 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Adding command class ZWAVE_PLUS_INFO to the list of supported command classes.
2018-10-14 22:27:17.713 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class VERSION
2018-10-14 22:27:17.714 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class VERSION, endpoint null created
2018-10-14 22:27:17.715 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Inclusion is adding command class VERSION.
2018-10-14 22:27:17.716 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Adding command class VERSION to the list of supported command classes.
2018-10-14 22:27:17.716 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class MANUFACTURER_SPECIFIC
2018-10-14 22:27:17.717 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class MANUFACTURER_SPECIFIC, endpoint null created
2018-10-14 22:27:17.718 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Inclusion is adding command class MANUFACTURER_SPECIFIC.
2018-10-14 22:27:17.718 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Adding command class MANUFACTURER_SPECIFIC to the list of supported command classes.
2018-10-14 22:27:17.719 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class DEVICE_RESET_LOCALLY
2018-10-14 22:27:17.719 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class DEVICE_RESET_LOCALLY, endpoint null created
2018-10-14 22:27:17.720 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Inclusion is adding command class DEVICE_RESET_LOCALLY.
2018-10-14 22:27:17.721 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Adding command class DEVICE_RESET_LOCALLY to the list of supported command classes.
2018-10-14 22:27:17.721 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class ASSOCIATION_GROUP_INFO
2018-10-14 22:27:17.722 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class ASSOCIATION_GROUP_INFO, endpoint null created
2018-10-14 22:27:17.723 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Inclusion is adding command class ASSOCIATION_GROUP_INFO.
2018-10-14 22:27:17.723 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Adding command class ASSOCIATION_GROUP_INFO to the list of supported command classes.
2018-10-14 22:27:17.724 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class ASSOCIATION
2018-10-14 22:27:17.724 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class ASSOCIATION, endpoint null created
2018-10-14 22:27:17.725 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Inclusion is adding command class ASSOCIATION.
the same issue it seems..
2018-10-14 22:27:17.818 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Starting initialisation from INCLUSION_START
2018-10-14 22:27:17.820 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - INCLUSION_START: queue length(0), free to send(true)
2018-10-14 22:27:17.821 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: loop - INCLUSION_START try 1: stageAdvanced(false)
2018-10-14 22:27:17.823 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: Unknown node state INCLUSION_START encountered.
2018-10-14 22:27:17.824 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - advancing to IDENTIFY_NODE
2018-10-14 22:27:17.828 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: loop - IDENTIFY_NODE try 0: stageAdvanced(true)
2018-10-14 22:27:17.829 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: PROTOINFO - send IdentifyNode
2018-10-14 22:27:17.831 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - queued packet. Queue length is 1
2018-10-14 22:27:17.882 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: ProtocolInfo
2018-10-14 22:27:17.883 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Listening = false
2018-10-14 22:27:17.884 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Routing = true
2018-10-14 22:27:17.885 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Beaming = true
2018-10-14 22:27:17.886 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Version = 4
2018-10-14 22:27:17.887 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: FLIRS = false
2018-10-14 22:27:17.888 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Security = false
2018-10-14 22:27:17.889 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Max Baud = 40000
2018-10-14 22:27:17.890 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Basic = Routing Slave
2018-10-14 22:27:17.891 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Generic = Sensor Notification
2018-10-14 22:27:17.892 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Specific = Notification Sensor
2018-10-14 22:27:17.893 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class NO_OPERATION
2018-10-14 22:27:17.894 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class NO_OPERATION, endpoint null created
2018-10-14 22:27:17.895 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Version = 1, version set. Enabling extra functionality.
2018-10-14 22:27:17.896 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Adding command class NO_OPERATION to the list of supported command classes.
2018-10-14 22:27:17.898 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class BASIC
2018-10-14 22:27:17.899 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class BASIC, endpoint null created
2018-10-14 22:27:17.900 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Adding command class BASIC to the list of supported command classes.
2018-10-14 22:27:17.906 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - IDENTIFY_NODE: Transaction complete (IdentifyNode:Request) success(true)
2018-10-14 22:27:17.907 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - checking initialisation queue. Queue size 1.
2018-10-14 22:27:17.908 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - message removed from queue. Queue size 0.
2018-10-14 22:27:17.909 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - IDENTIFY_NODE: queue length(0), free to send(true)
2018-10-14 22:27:17.911 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: loop - IDENTIFY_NODE try 1: stageAdvanced(false)
2018-10-14 22:27:17.912 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - advancing to MANUFACTURER
2018-10-14 22:27:17.914 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: loop - MANUFACTURER try 0: stageAdvanced(true)
2018-10-14 22:27:17.915 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: MANUFACTURER - send ManufacturerSpecific
2018-10-14 22:27:17.916 [DEBUG] [WaveManufacturerSpecificCommandClass] - NODE 14: Creating new message for command MANUFACTURER_SPECIFIC_GET
2018-10-14 22:27:17.918 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - queued packet. Queue length is 1
2018-10-14 22:27:17.919 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 14: Putting message SendData in wakeup queue.
2018-10-14 22:27:30.757 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: MANUFACTURER not set
2018-10-14 22:27:30.759 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Controller status changed to ONLINE.
2018-10-14 22:27:30.761 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Controller is ONLINE. Starting device initialisation.
2018-10-14 22:27:30.786 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating node properties.
2018-10-14 22:27:30.787 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating node properties. MAN=2147483647
2018-10-14 22:27:30.789 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Properties synchronised
2018-10-14 22:27:30.797 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Property to update: wakeup_node, 0, null
2018-10-14 22:27:30.803 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Properties synchronised
2018-10-14 22:27:30.810 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Initialising Thing Node...
2018-10-14 22:27:30.813 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
2018-10-14 22:27:43.607 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Device discovered
2018-10-14 22:27:43.618 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveInclusionEvent
2018-10-14 22:27:43.620 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Newly included node already initialising at MANUFACTURER
2018-10-14 22:32:29.186 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 14: Application update request. Node information received.
2018-10-14 22:32:29.187 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Node is ALIVE. Init stage is MANUFACTURER.
2018-10-14 22:32:29.189 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node Status event during initialisation - Node is ALIVE
2018-10-14 22:32:29.190 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - MANUFACTURER: queue length(1), free to send(false)
2018-10-14 22:32:29.192 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - queued packet. Queue length is 1
2018-10-14 22:32:29.193 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 14: Message already on the wake-up queue. Removing original.
2018-10-14 22:32:29.194 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 14: Putting message SendData in wakeup queue.
2018-10-14 22:32:29.195 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2018-10-14 22:32:29.196 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Setting ONLINE
2018-10-14 22:32:29.198 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Node Status event - Node is ALIVE
2018-10-14 22:32:29.200 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 14: Is awake with 1 messages in the wake-up queue.
2018-10-14 22:32:29.203 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Wakeup during initialisation.
2018-10-14 22:32:29.205 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - MANUFACTURER: queue length(1), free to send(false)
2018-10-14 22:32:29.207 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - queued packet. Queue length is 1
2018-10-15 04:34:29.162 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 14: Response processed after 80ms/1083ms.
2018-10-15 04:34:41.992 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Transaction not completed: node address inconsistent.  lastSent=14, incoming=255
2018-10-15 04:35:12.009 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Transaction not completed: node address inconsistent.  lastSent=14, incoming=255
2018-10-15 04:35:39.966 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Transaction not completed: node address inconsistent.  lastSent=14, incoming=255
Hello again,
I hoped somebody could tell me whats wrong, any help very much appreciated.
Or which further steps I can take..
Thx
Roman
Please provide a full debug log - not just small parts like this as there is nothing wrong from this short bit of data.
Chris, thank you for answering..how can I provide the data.to you?
About 1MB txt file.
I used debug and then filtered for the node…is that ok?
Thx
Roman
Either put it somewhere like dropbox, or you can email it to me (chris -at- cd-jackson.com).
No - please don’t filter the data as it will remove the receive data which does not have the node ID on the line.
Ok, got to start from scratch making a log file, is debugging to an extra file ok or does it need to be the openhab.log?
Sorry for all this questions…
Thx,
Roman
The OH file is fine - the log file viewer will filter out all the other stuff…
@Chris, log file sent
Thx
Roman
It looks like the devices are initialising ok as I see ALIVE:DONE in the log when data is received - the DONE part means that the initialisation is complete.
There’s an error in the thing handler configuration. I’m not really sure what is causing this, and it may not be related to the problem as there is some further reconfiguration later.
Can you get another log from a restart of the binding?
I would also suggest to update to the latest binding as well - just in case that has any impact.
With restart of the binding you mean exclude the device from the aeon stick, am I right?
Newest binding I suppose I have to get the jar file?
I will do this tomorrow…thx a lot!!
Roman
No - just stop OH and restart it.
Easiest thing is to change the openHAB version to the milestone version.
Updated as suggested, apt-get repository, interestingly only 2.3 available.
Updated rebooted ..same situation…
I am on the search for the latest binding…somehow it seems all for me a chaseup for info :joy:
Going to look where I can find the latest binding…github has all but zwave …searching…
Thx!
Roman
It depends on what your install is - have a look at the documentation as you will need to change the repository to get the snapshot version.
Built bindings are not available on github - only the source (including zwave) is on github.
Thank you…I installed openhab manually, not openhabian on the raspberry pi…
openhab> bundle:list|grep -i zwave 212 │ Installed │ 80 │ 2.4.0.201809081506 │ ZWave Binding
Karraf info…interesting paperui showed only 2.3 available…still bits and pieces. ..
:wink:
I thought after 2.4 no snapshots anymore​:magnifying_glass_tilted_left:
:red_question_mark::white_question_mark:♔Chris, did my log show something?
Some good NEWS, the flood sensor started to work after update of the binding and a Reboot…
The aeon stick changed to serial usb device..Zwave plus…
:chart_decreasing:the motion sensor still is only node…unknown…
Finally :magnifying_glass_tilted_left::angry: changed to snapshop like Chris suggested and solved all my problems!
Motion sensor is working as well.
One question left​:white_question_mark:, can I remove the manually copied zwave binding​:red_question_mark:
Thanks!
