And here is a raw log (unfortunately, not ‘debug’ - but this is what I have now) of using “BC” groups:
2016-08-15 09:39:31.875 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:39:32.097 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:39:32.316 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 32, ignoring.
2016-08-15 09:39:32.479 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 29.7, ignoring.
2016-08-15 09:39:37.179 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:39:37.457 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:39:40.335 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class ZWAVE_PLUS_INFO
2016-08-15 09:39:40.337 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class DEVICE_RESET_LOCALLY
2016-08-15 09:39:40.338 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class ASSOCIATION_GROUP_INFO
2016-08-15 09:39:40.340 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class POWERLEVEL
2016-08-15 09:39:40.343 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2016-08-15 09:39:40.346 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class SECURITY
2016-08-15 09:39:40.347 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class FIRMWARE_UPDATE_MD
2016-08-15 09:39:40.376 [WARN ] [b.z.i.p.s.SendDataMessageClass] - NODE 5: Already processed another send data request for this callback Id, ignoring.
2016-08-15 09:39:45.353 [ERROR] [WaveController$ZWaveSendThread] - NODE 5: Timeout while sending message. Requeueing - 0 attempts left!
2016-08-15 09:39:53.444 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:40:11.972 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@a21797, ignoring.
2016-08-15 09:40:12.012 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1076319, ignoring.
2016-08-15 09:40:12.054 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@d70123, ignoring.
2016-08-15 09:40:12.095 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1d0ab99, ignoring.
2016-08-15 09:40:12.136 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@a0d60b, ignoring.
2016-08-15 09:40:12.175 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1f8485e, ignoring.
2016-08-15 09:40:12.216 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1614655, ignoring.
2016-08-15 09:40:12.257 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@585306, ignoring.
2016-08-15 09:40:12.296 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@5fff58, ignoring.
2016-08-15 09:40:12.336 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@199c910, ignoring.
2016-08-15 09:40:12.379 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1b581d9, ignoring.
2016-08-15 09:40:12.419 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@74e7b7, ignoring.
2016-08-15 09:40:12.458 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1d8855f, ignoring.
2016-08-15 09:40:12.504 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@ec3881, ignoring.
2016-08-15 09:40:12.548 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@ec3651, ignoring.
2016-08-15 09:40:12.592 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@101b097, ignoring.
2016-08-15 09:40:12.638 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@273342, ignoring.
2016-08-15 09:40:12.683 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1f643ed, ignoring.
2016-08-15 09:40:12.727 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1031013, ignoring.
2016-08-15 09:40:12.773 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1330a6a, ignoring.
2016-08-15 09:40:12.818 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@ab2e5a, ignoring.
2016-08-15 09:40:12.863 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@166251b, ignoring.
2016-08-15 09:40:12.908 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@f666fc, ignoring.
2016-08-15 09:40:12.954 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@ec1142, ignoring.
2016-08-15 09:40:12.997 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@4880f, ignoring.
2016-08-15 09:40:13.044 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1b63600, ignoring.
2016-08-15 09:40:13.092 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@ad0592, ignoring.
2016-08-15 09:40:13.139 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@15d1164, ignoring.
2016-08-15 09:40:13.186 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@2d3149, ignoring.
2016-08-15 09:40:13.232 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@138c689, ignoring.
2016-08-15 09:40:13.346 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.385 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.425 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.464 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = BATTERY, value = 100, ignoring.
2016-08-15 09:40:13.504 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 0, ignoring.
2016-08-15 09:40:13.544 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:40:13.584 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 0, ignoring.
2016-08-15 09:40:13.624 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.664 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.704 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.745 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.785 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.824 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.862 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.902 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.940 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.980 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9, ignoring.
2016-08-15 09:40:13.981 [ERROR] [z.i.p.i.ZWaveNodeStageAdvancer] - NODE 5: Node advancer: Retries exceeded at DYNAMIC_VALUES
2016-08-15 09:40:15.853 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:40:16.080 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:40:16.298 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 1E+1, ignoring.
2016-08-15 09:40:16.458 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 29.9, ignoring.
2016-08-15 09:40:28.448 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:41:03.454 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:41:08.996 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:41:09.515 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:41:38.461 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:41:39.414 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:41:39.691 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:41:53.069 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:41:53.338 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:42:13.468 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:42:48.474 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:42:49.744 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-08-15 09:42:50.605 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:42:50.710 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 255, ignoring.
2016-08-15 09:42:50.726 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 255, ignoring.
2016-08-15 09:42:50.903 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 65, ignoring.
2016-08-15 09:42:51.069 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 29.9, ignoring.
2016-08-15 09:42:54.774 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-08-15 09:42:55.038 [ERROR] [.DeleteReturnRouteMessageClass] - NODE 5: Delete return routes failed with error 0x1.
2016-08-15 09:42:59.777 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-08-15 09:42:59.934 [ERROR] [.DeleteReturnRouteMessageClass] - NODE 5: Delete return routes failed with error 0x1.
2016-08-15 09:43:04.780 [WARN ] [WaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class = DeleteReturnRoute (0x47), type = Request (0x00), payload = 05
2016-08-15 09:43:04.912 [ERROR] [.AssignReturnRouteMessageClass] - NODE 5: Assign return routes failed.
2016-08-15 09:43:15.229 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:43:15.357 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 0, ignoring.
2016-08-15 09:43:15.398 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 0, ignoring.
2016-08-15 09:43:23.481 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:43:35.973 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:43:36.103 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 255, ignoring.
2016-08-15 09:43:36.144 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 255, ignoring.
2016-08-15 09:43:39.169 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 55, ignoring.
2016-08-15 09:43:58.488 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:44:05.105 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:44:05.186 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 0, ignoring.
2016-08-15 09:44:05.224 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 0, ignoring.
2016-08-15 09:44:06.110 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:44:06.235 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 0, ignoring.
2016-08-15 09:44:06.274 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 0, ignoring.
2016-08-15 09:44:15.675 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:44:15.757 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 255, ignoring.
2016-08-15 09:44:15.795 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 255, ignoring.
2016-08-15 09:44:33.495 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead
2016-08-15 09:44:41.529 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = ALARM, value = 0, ignoring.
2016-08-15 09:44:41.656 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 255, ignoring.
2016-08-15 09:44:41.696 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 255, ignoring.
