I’ve recently bought a few Fibaro motion sensors which are running the 3.2 firmware. I’m having varing degrees of success setting them up. Some of them will only report ALARM with a value of 0 on motion, and the same when motion is ‘cancelled’. Others are reporting both BASIC and ALARM for motion, although the BASIC classes report as 0 and 255. Does anyone know why these sensors are doing this?
2016-09-03 18:52:45.538 [DEBUG] [eController$ZWaveReceiveThread:1530]- Receive Message = 01 0F 00 04 00 1C 09 71 05 00 00 00 FF 07 08 00 65
2016-09-03 18:52:45.539 [DEBUG] [eController$ZWaveReceiveThread:1446]- Receive queue ADD: Length=1
2016-09-03 18:52:45.539 [DEBUG] [b.z.i.protocol.ZWaveController:1194]- Receive queue TAKE: Length=0
2016-09-03 18:52:45.540 [DEBUG] [o.b.z.i.protocol.SerialMessage:243 ]- Assembled message buffer = 01 0F 00 04 00 1C 09 71 05 00 00 00 FF 07 08 00 65
2016-09-03 18:52:45.540 [DEBUG] [b.z.i.protocol.ZWaveController:1195]- Process Message = 01 0F 00 04 00 1C 09 71 05 00 00 00 FF 07 08 00 65
2016-09-03 18:52:45.540 [DEBUG] [b.z.i.protocol.ZWaveController:194 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 1C 09 71 05 00 00 00 FF 07 08 00
2016-09-03 18:52:45.540 [DEBUG] [ApplicationCommandMessageClass:40 ]- NODE 28: Application Command Request (ALIVE:DONE)
2016-09-03 18:52:45.541 [DEBUG] [ApplicationCommandMessageClass:58 ]- NODE 28: Incoming command class ALARM
2016-09-03 18:52:45.541 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 28: Received Alarm Request
2016-09-03 18:52:45.541 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 28: Alarm report - Value = 0
2016-09-03 18:52:45.541 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:113 ]- NODE 28: Alarm Type = General (0)
2016-09-03 18:52:45.541 [DEBUG] [b.z.i.protocol.ZWaveController:648 ]- Notifying event listeners: ZWaveAlarmValueEvent
2016-09-03 18:52:45.541 [DEBUG] [.z.internal.ZWaveActiveBinding:449 ]- ZwaveIncomingEvent
2016-09-03 18:52:45.541 [DEBUG] [.z.internal.ZWaveActiveBinding:466 ]- NODE 28: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2016-09-03 18:52:45.542 [DEBUG] [ApplicationCommandMessageClass:89 ]- Transaction not completed: node address inconsistent.
Thanks for the help
