OH 4.1.0
Raspberry Pi 4
My FIBARO Motion sensor stopped working. At least it does not sends updates to the controller.
I tried to reinitialise the system and the controller (reboot) unfortunately it did not help.
Information in the console is a little wired to me. Pressing wake-up button of the sensor seams not working.- no information on the console.
Z-Wave Network range is OK. (Cheking it by entering the sensor menu)
Is the sensor broken or there is sth wrong with the system updates I made?
2024-03-26 21:08:56.902 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:zwavestick:node5' changed from ONLINE to UNINITIALIZED
2024-03-26 21:08:56.927 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:zwavestick:node5' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2024-03-26 21:08:59.446 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Cpu_Load1' changed from 0.0 to 0.2
2024-03-26 21:08:59.448 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_SystemUptime' changed from 15.3 to 16.3
2024-03-26 21:09:00.188 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SystemUptimeFormated' changed from 15min to 16min
2024-03-26 21:09:03.947 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_CPUTemperature' changed from 48.2 to 47.7
2024-03-26 21:09:15.623 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:zwavestick:node5.
2024-03-26 21:09:15.625 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller status changed to ONLINE.
2024-03-26 21:09:15.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is ONLINE. Starting device initialisation.
2024-03-26 21:09:15.631 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating node properties.
2024-03-26 21:09:15.632 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating node properties. MAN=271
2024-03-26 21:09:15.634 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating node properties. MAN=271. SET. Was 271
2024-03-26 21:09:15.635 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Properties synchronised
2024-03-26 21:09:15.637 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_64_2
2024-03-26 21:09:15.638 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_1_2
2024-03-26 21:09:15.639 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_2_1
2024-03-26 21:09:15.640 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_66_2
2024-03-26 21:09:15.641 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_3_1
2024-03-26 21:09:15.642 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_4_1
2024-03-26 21:09:15.643 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_6_2
2024-03-26 21:09:15.643 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_8_1
2024-03-26 21:09:15.644 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_9_2
2024-03-26 21:09:15.645 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_12_1
2024-03-26 21:09:15.646 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_14_2
2024-03-26 21:09:15.647 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_16_2
2024-03-26 21:09:15.648 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_80_1
2024-03-26 21:09:15.648 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_81_1
2024-03-26 21:09:15.649 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_18_1
2024-03-26 21:09:15.650 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_82_2
2024-03-26 21:09:15.651 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_83_2
2024-03-26 21:09:15.652 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_20_1
2024-03-26 21:09:15.653 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_22_2
2024-03-26 21:09:15.654 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_86_2
2024-03-26 21:09:15.654 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_87_2
2024-03-26 21:09:15.655 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_24_1
2024-03-26 21:09:15.656 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_25_1
2024-03-26 21:09:15.657 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_89_1
2024-03-26 21:09:15.658 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_28_1
2024-03-26 21:09:15.659 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_29_1
2024-03-26 21:09:15.660 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_40_2
2024-03-26 21:09:15.661 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_42_2
2024-03-26 21:09:15.662 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_60_2
2024-03-26 21:09:15.663 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration pending removed for config_62_2
2024-03-26 21:09:15.665 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Update ASSOCIATION group_ZWaveAssociationGroup [index=1, name=Lifeline, profile1=0, profile2=1, associations=[node_1]]: Adding Controller (node_1)
2024-03-26 21:09:15.666 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2024-03-26 21:09:15.667 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising Thing Node...
2024-03-26 21:09:15.669 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising cmd channel zwave:device:zwavestick:node5:sensor_binary for OnOffType
2024-03-26 21:09:15.670 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:sensor_binary for OnOffType
2024-03-26 21:09:15.671 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:sensor_binary for OnOffType
2024-03-26 21:09:15.672 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising cmd channel zwave:device:zwavestick:node5:sensor_temperature for QuantityType
2024-03-26 21:09:15.673 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:sensor_temperature for QuantityType
2024-03-26 21:09:15.675 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising cmd channel zwave:device:zwavestick:node5:sensor_seismicintensity for DecimalType
2024-03-26 21:09:15.676 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:sensor_seismicintensity for DecimalType
2024-03-26 21:09:15.677 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising cmd channel zwave:device:zwavestick:node5:sensor_luminance for DecimalType
2024-03-26 21:09:15.678 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:sensor_luminance for DecimalType
2024-03-26 21:09:15.680 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising cmd channel zwave:device:zwavestick:node5:alarm_motion for OnOffType
2024-03-26 21:09:15.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:alarm_motion for OnOffType
2024-03-26 21:09:15.683 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising cmd channel zwave:device:zwavestick:node5:alarm_tamper for OnOffType
2024-03-26 21:09:15.684 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:alarm_tamper for OnOffType
2024-03-26 21:09:15.685 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising cmd channel zwave:device:zwavestick:node5:battery-level for PercentType
2024-03-26 21:09:15.686 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:battery-level for PercentType
2024-03-26 21:09:15.687 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising cmd channel zwave:device:zwavestick:node5:alarm_general for OnOffType
2024-03-26 21:09:15.688 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising state channel zwave:device:zwavestick:node5:alarm_general for OnOffType
2024-03-26 21:09:15.689 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling initialised at 86400 seconds - start in 7430400 milliseconds.
2024-03-26 21:09:15.690 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Device initialisation complete.
