Maybe it would help to ex-/include the device to get a new node.xml? In the node.xml of sihui there is a SWITCH_MULTILEVEL command
You could try just deleting the XML and restarting, or click on the “reinitialise device” option. I’m just a bit surprised as the class doesn’t seem to be in the NIF even, and that’s unlikely to change by reinitialising.
Hello @chris
I have now checked some details. First of all in my old node.xml (before updating anything) the SWITCH_MULTILEVEL entry was there. Like on the node.xml of sihui.
If I have a look in the ESH-INF declartion it says:
<channel id="blinds_control" typeId="blinds_control">
<label>Blinds control</label>
<properties>
<property name="binding:*:PercentType">COMMAND_CLASS_SWITCH_MULTILEVEL</property>
<property name="binding:Command:StopMoveType">COMMAND_CLASS_SWITCH_MULTILEVEL</property>
<property name="binding:Command:UpDownType">COMMAND_CLASS_SWITCH_MULTILEVEL</property>
</properties>
</channel>
But after updating to the latest version the entry for SWITCH_MULTILEVEL is no longer in the node.xml and therefore it is not working. Is it not possible to “fake” this entry or it seems, that there is a problem initialisiing it cause it worked before and the entry was there. And even more it works before, so the device definitely supports this command.
I’m not sure what your point is? The database information is not directly related to what the device supports.[quote=“RobZe89, post:111, topic:9396”]
[/quote]
The node.xml is not related to the database. The node.xml comes from what the device states it supports - not the other way around.
Yes - we can force it by adding an option to the database, but I’m not sure why it was previously there, and now it’s not.
What’s strange is that it’s not listed in the NIF. This is where the device tells us what command classes it supports - the device should be totally self descriptive so the fact that it’s not showing this is strange. Maybe I’ve screwed up somewhere and dropped the multilevel switch out of the list of command classes in the binding (although then no-ones dimmers would work, so I doubt that).
Can you provide a logfile during initialisation of the device (delete the XML first).
Thank you for your explanation. I see the problem now.
Here you find a log of the initialisation. Hope this helps you.
2017-06-13 09:16:33.472 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:78d06d54:node10.
2017-06-13 09:16:33.510 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Controller status changed to ONLINE.
2017-06-13 09:16:33.511 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Controller is ONLINE. Starting device initialisation.
2017-06-13 09:16:33.515 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties.
2017-06-13 09:16:33.516 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties. MAN=271
2017-06-13 09:16:33.517 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties. MAN=271. SET. Was 271
2017-06-13 09:16:33.519 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Properties synchronised
2017-06-13 09:16:33.527 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Update ASSOCIATION group_org.openhab.binding.zwave.internal.protocol.ZWaveAssociationGroup@1eb1c9d: Adding node_1_0
2017-06-13 09:16:33.529 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration synchronised
2017-06-13 09:16:33.611 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2017-06-13 09:16:33.612 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising Thing Node...
2017-06-13 09:16:33.614 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:switch_binary for OnOffType
2017-06-13 09:16:33.615 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:switch_binary for OnOffType
2017-06-13 09:16:33.618 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_control for UpDownType
2017-06-13 09:16:33.623 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_control for StopMoveType
2017-06-13 09:16:33.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_control for PercentType
2017-06-13 09:16:33.637 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:blinds_control for PercentType
2017-06-13 09:16:33.642 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:scene_number for DecimalType
2017-06-13 09:16:33.645 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:scene_number for DecimalType
2017-06-13 09:16:33.650 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:sensor_power for DecimalType
2017-06-13 09:16:33.653 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:sensor_power for DecimalType
2017-06-13 09:16:33.657 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:meter_watts for DecimalType
2017-06-13 09:16:33.661 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:meter_watts for DecimalType
2017-06-13 09:16:33.665 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:meter_kwh for DecimalType
2017-06-13 09:16:33.669 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:meter_kwh for DecimalType
2017-06-13 09:16:33.673 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_lamella for PercentType
2017-06-13 09:16:33.677 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:blinds_lamella for PercentType
2017-06-13 09:16:33.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_shutter for PercentType
2017-06-13 09:16:33.685 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:blinds_shutter for PercentType
2017-06-13 09:16:33.689 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
2017-06-13 09:16:33.692 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Device initialisation complete.
So you can add this to the database? Would be great to come to an end and have a working solution. If you can make it work soon I will do of course a donation for your work. I’m sure there are other people in this thread who will do too.
If possible I would like to understand what is happening first.
Can I ask you to try 2 things.
I’d like to get a log of the device initialisation, and I’d like to see what happens if you manually adjust the blinds…
So, can you try the following…
Stop the binding, delete the XML, and restart. Wait till the device is initialised, then manually change the blinds. I assume when the blinds change it will send an update to the binding (is that true?) and it’s possible that this will then add the multilevel switch class.
I’d like to specifically look at what the device sends in the NIF, and also see what happens when this manual move is done…
@sihui can you also try this on the master version that I think you are using?
What a pitty, I migrated to the development binding this morning (btw, without any major problems).
But because I am on a manual install I can easily revert back to yesterdays version, will do that tomorrow and report …
Ok, no worries. If you get the chance it would be interesting, if not then the dev branch will be fine.
Thanks.
Hello Chris
Sure we can have a look at it. Here you’ll find the data. I hope I got the right data, I’ve cutted out some other nodes.
2017-06-14 20:53:09.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:78d06d54:node10.
2017-06-14 20:53:09.632 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Controller status changed to ONLINE.
2017-06-14 20:53:09.634 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Controller is ONLINE. Starting device initialisation.
2017-06-14 20:53:09.638 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties.
2017-06-14 20:53:09.640 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties. MAN=271
2017-06-14 20:53:09.643 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties. MAN=271. SET. Was 271
2017-06-14 20:53:09.648 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Properties synchronised
2017-06-14 20:53:09.653 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Update ASSOCIATION group_org.openhab.binding.zwave.internal.protocol.ZWaveAssociationGroup@70d1b1: Adding node_1_0
2017-06-14 20:53:09.657 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration synchronised
2017-06-14 20:53:09.734 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2017-06-14 20:53:09.735 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising Thing Node...
2017-06-14 20:53:09.737 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:switch_binary for OnOffType
2017-06-14 20:53:09.739 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:switch_binary for OnOffType
2017-06-14 20:53:09.741 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_control for UpDownType
2017-06-14 20:53:09.745 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_control for StopMoveType
2017-06-14 20:53:09.748 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_control for PercentType
2017-06-14 20:53:09.751 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:blinds_control for PercentType
2017-06-14 20:53:09.755 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:scene_number for DecimalType
2017-06-14 20:53:09.758 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:scene_number for DecimalType
2017-06-14 20:53:09.761 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:sensor_power for DecimalType
2017-06-14 20:53:09.764 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:sensor_power for DecimalType
2017-06-14 20:53:09.768 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:meter_watts for DecimalType
2017-06-14 20:53:09.771 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:meter_watts for DecimalType
2017-06-14 20:53:09.774 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:meter_kwh for DecimalType
2017-06-14 20:53:09.777 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:meter_kwh for DecimalType
2017-06-14 20:53:09.780 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_lamella for PercentType
2017-06-14 20:53:09.783 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:blinds_lamella for PercentType
2017-06-14 20:53:09.786 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:78d06d54:node10:blinds_shutter for PercentType
2017-06-14 20:53:09.787 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:78d06d54:node10:blinds_shutter for PercentType
2017-06-14 20:53:09.790 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
2017-06-14 20:53:09.793 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Device initialisation complete.
2017-06-14 20:54:03.544 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Jun 14 20:54:07 CEST 2017 - 3644ms
2017-06-14 20:54:05.136 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 0A 08 91 01 0F 26 03 03 4D 2F 2C
2017-06-14 20:54:05.169 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-06-14 20:54:05.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 08 91 01 0F 26 03 03 4D 2F
2017-06-14 20:54:05.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 08 91 01 0F 26 03 03 4D 2F
2017-06-14 20:54:05.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 08 91 01 0F 26 03 03 4D 2F
2017-06-14 20:54:05.185 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-06-14 20:54:05.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Application Command Request (ALIVE:GET_CONFIGURATION)
2017-06-14 20:54:05.187 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Incoming command class COMMAND_CLASS_MANUFACTURER_PROPRIETARY, endpoint 0
2017-06-14 20:54:05.188 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Command class COMMAND_CLASS_MANUFACTURER_PROPRIETARY not found, trying to add it.
2017-06-14 20:54:05.190 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Unknown command class 0x91
2017-06-14 20:54:05.191 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Unsupported zwave command class COMMAND_CLASS_MANUFACTURER_PROPRIETARY (0x91)
2017-06-14 20:54:05.192 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Commands processed 1.
2017-06-14 20:54:05.192 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1738266.
2017-06-14 20:54:05.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction 253 ApplicationCommandHandler.
2017-06-14 20:54:05.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : state >> WAIT_DATA
2017-06-14 20:54:05.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : node >> 10
2017-06-14 20:54:05.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : class >> 145 == 112.
2017-06-14 20:54:05.196 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : commd >> 1 == 6.
2017-06-14 20:54:05.197 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Command NOT verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1738266.
2017-06-14 20:54:05.197 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2017-06-14 20:54:05.198 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2017-06-14 20:54:05.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-06-14 20:54:05.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2017-06-14 20:54:05.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-06-14 20:54:05.201 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-06-14 20:54:05.276 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Jun 14 20:54:07 CEST 2017 - 1912ms
2017-06-14 20:54:06.288 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 0A 06 31 05 04 22 03 3C D6
2017-06-14 20:54:06.319 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-06-14 20:54:06.323 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 06 31 05 04 22 03 3C
2017-06-14 20:54:06.326 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 06 31 05 04 22 03 3C
2017-06-14 20:54:06.329 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 06 31 05 04 22 03 3C
2017-06-14 20:54:06.330 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-06-14 20:54:06.331 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Application Command Request (ALIVE:GET_CONFIGURATION)
2017-06-14 20:54:06.332 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2017-06-14 20:54:06.333 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: SECURITY not supported
2017-06-14 20:54:06.334 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Received COMMAND_CLASS_SENSOR_MULTILEVEL V2 SENSOR_MULTILEVEL_REPORT
2017-06-14 20:54:06.335 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 10: Sensor Type = Power(4), Scale = 0
2017-06-14 20:54:06.336 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 10: Sensor Value = 82.8
2017-06-14 20:54:06.336 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2017-06-14 20:54:06.337 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2017-06-14 20:54:06.338 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 82.8
2017-06-14 20:54:06.339 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating channel state zwave:device:78d06d54:node10:sensor_power to 82.8 [DecimalType]
2017-06-14 20:54:06.341 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Commands processed 1.
2017-06-14 20:54:06.342 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@a0660a.
2017-06-14 20:54:06.343 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction 253 ApplicationCommandHandler.
2017-06-14 20:54:06.343 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : state >> WAIT_DATA
2017-06-14 20:54:06.344 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : node >> 10
2017-06-14 20:54:06.344 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : class >> 49 == 112.
2017-06-14 20:54:06.345 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : commd >> 5 == 6.
2017-06-14 20:54:06.346 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Command NOT verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@a0660a.
2017-06-14 20:54:06.346 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2017-06-14 20:54:06.347 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2017-06-14 20:54:06.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-06-14 20:54:06.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2017-06-14 20:54:06.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-06-14 20:54:06.350 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-06-14 20:54:11.985 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Jun 14 20:54:14 CEST 2017 - 2544ms
2017-06-14 20:54:12.020 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 0A 06 31 05 04 22 00 00 E9
2017-06-14 20:54:12.049 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-06-14 20:54:12.053 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 06 31 05 04 22 00 00
2017-06-14 20:54:12.055 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 06 31 05 04 22 00 00
2017-06-14 20:54:12.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=10, callback=0, payload=00 0A 06 31 05 04 22 00 00
2017-06-14 20:54:12.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-06-14 20:54:12.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Application Command Request (ALIVE:GET_CONFIGURATION)
2017-06-14 20:54:12.060 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2017-06-14 20:54:12.061 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: SECURITY not supported
2017-06-14 20:54:12.062 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Received COMMAND_CLASS_SENSOR_MULTILEVEL V2 SENSOR_MULTILEVEL_REPORT
2017-06-14 20:54:12.070 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 10: Sensor Type = Power(4), Scale = 0
2017-06-14 20:54:12.071 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 10: Sensor Value = 0E+1
2017-06-14 20:54:12.072 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2017-06-14 20:54:12.073 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2017-06-14 20:54:12.075 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 0E+1
2017-06-14 20:54:12.077 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating channel state zwave:device:78d06d54:node10:sensor_power to 0 [DecimalType]
2017-06-14 20:54:12.079 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Commands processed 1.
2017-06-14 20:54:12.080 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@b21b56.
2017-06-14 20:54:12.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction 254 ApplicationCommandHandler.
2017-06-14 20:54:12.103 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : state >> WAIT_DATA
2017-06-14 20:54:12.109 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : node >> 10
2017-06-14 20:54:12.114 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : class >> 49 == 112.
2017-06-14 20:54:12.118 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Checking transaction : commd >> 5 == 6.
2017-06-14 20:54:12.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Command NOT verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@b21b56.
2017-06-14 20:54:12.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2017-06-14 20:54:12.126 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2017-06-14 20:54:12.127 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-06-14 20:54:12.127 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2017-06-14 20:54:12.128 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-06-14 20:54:12.128 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
Little delay, no time today, son’s car broke down, will provide the results tomorrow.
That’s fine, thanks - I’m tied up with a work thin today anyway - customers in the building so gotta take 'em out for dinner!
Here are my results:
openHAB2 Snapshot build #945, zwave snapshot binding 2.1.0.201706100753, node 11 (Fibaro FGRM222 Rollershutter, firmware version 25.25) is the testnode:
Debug logs:
zwave1.zip.xml (622.9 KB)
zwave2.zip.xml (539.9 KB)
zwave3.zip.xml (459.4 KB)
zwave4.zip.xml (439.9 KB)
zwave5.zip.xml (211.0 KB)
newly created xml after initialization:
<node>
<deviceClass>
<basicDeviceClass>ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>MULTILEVEL_SWITCH</genericDeviceClass>
<specificDeviceClass>MOTOR_CONTROL_CLASS_B</specificDeviceClass>
</deviceClass>
<homeId>0xc239030a</homeId>
<nodeId>11</nodeId>
<version>4</version>
<manufacturer>0x10f</manufacturer>
<deviceId>0x1000</deviceId>
<deviceType>0x302</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<nodeInformationFrame>
<commandClass>MULTI_INSTANCE_ASSOCIATION</commandClass>
<commandClass>MANUFACTURER_SPECIFIC</commandClass>
<commandClass>VERSION</commandClass>
<commandClass>CONFIGURATION</commandClass>
<commandClass>ASSOCIATION</commandClass>
<commandClass>POWERLEVEL</commandClass>
<commandClass>METER</commandClass>
<commandClass>SWITCH_MULTILEVEL</commandClass>
<commandClass>SENSOR_MULTILEVEL</commandClass>
<commandClass>SWITCH_BINARY</commandClass>
<commandClass>MANUFACTURER_PROPRIETARY</commandClass>
<commandClass>PROTECTION</commandClass>
</nodeInformationFrame>
<supportedCommandClasses>
<entry>
<multiLevelSwitchCommandClass>
<version>3</version>
<instances>1</instances>
<versionSupported>3</versionSupported>
<switchTypePrimary>CLOSE_OPEN</switchTypePrimary>
<switchTypeSecondary>CLOSE_OPEN</switchTypeSecondary>
<isGetSupported>true</isGetSupported>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<configurationCommandClass>
<version>1</version>
<versionSupported>1</versionSupported>
<configParameters>
<entry>
<int>32</int>
<configurationParameter>
<index>32</index>
<size>1</size>
<value>1</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>33</int>
<index>33</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>35</int>
<index>35</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>40</int>
<index>40</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>10</int>
<index>10</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>42</int>
<index>42</index>
<size>2</size>
<value>3600</value>
</entry>
<entry>
<int>43</int>
<index>43</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>12</int>
<index>12</index>
<size>2</size>
<value>150</value>
</entry>
<entry>
<int>44</int>
<index>44</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>13</int>
<index>13</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>14</int>
<index>14</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>17</int>
<index>17</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>18</int>
<index>18</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>50</int>
<index>50</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>22</int>
<index>22</index>
<size>2</size>
<value>240</value>
</entry>
<entry>
<int>29</int>
<index>29</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>30</int>
<index>30</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>31</int>
<index>31</index>
<size>1</size>
<value>0</value>
</entry>
</configParameters>
</configurationCommandClass>
</entry>
<entry>
<protectionCommandClass>
<version>2</version>
<versionSupported>2</versionSupported>
<localModes>
<localProtection>UNPROTECTED</localProtection>
<localProtection>PROTECTED</localProtection>
</localModes>
<rfModes>
<rfProtection>UNPROTECTED</rfProtection>
<rfProtection>NORFCONTROL</rfProtection>
</rfModes>
</protectionCommandClass>
</entry>
<entry>
<associationCommandClass>
<maxGroups>3</maxGroups>
</associationCommandClass>
</entry>
<entry>
<versionCommandClass>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>3.52</protocolVersion>
<applicationVersion>25.25</applicationVersion>
</versionCommandClass>
</entry>
<entry>
<commandClass>BASIC</commandClass>
<basicCommandClass>
</basicCommandClass>
</entry>
<entry>
<binarySwitchCommandClass>
</binarySwitchCommandClass>
</entry>
<entry>
<powerLevelCommandClass>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</powerLevelCommandClass>
</entry>
<entry>
<multiLevelSensorCommandClass>
<sensors>
<entry>
<multilevelSensorType>POWER</multilevelSensorType>
<multilevelSensor>
<sensorType>POWER</sensorType>
<initialised>true</initialised>
</multilevelSensor>
</entry>
</sensors>
</multiLevelSensorCommandClass>
</entry>
<entry>
<manufacturerSpecificCommandClass>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>271</deviceManufacturer>
<deviceType>770</deviceType>
<deviceId>4096</deviceId>
</manufacturerSpecificCommandClass>
</entry>
<entry>
<commandClass>NO_OPERATION</commandClass>
<noOperationCommandClass>
</noOperationCommandClass>
</entry>
<entry>
<meterCommandClass>
<meterType>ELECTRIC</meterType>
<meterScales>
<meterScale>E_KWh</meterScale>
<meterScale>E_W</meterScale>
</meterScales>
<canReset>true</canReset>
<isSupportRequestSupported>true</isSupportRequestSupported>
</meterCommandClass>
</entry>
<entry>
<multiAssociationCommandClass>
<maxGroups>2</maxGroups>
</multiAssociationCommandClass>
</entry>
</supportedCommandClasses>
<securedCommandClasses/>
<associationGroups>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<associations>
<associationMember>
<node>1</node>
<endpoint>0</endpoint>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<nodeNeighbors>
<int>1</int>
<int>3</int>
<int>4</int>
<int>8</int>
<int>10</int>
<int>12</int>
<int>13</int>
<int>23</int>
<int>26</int>
<int>28</int>
<int>30</int>
<int>31</int>
<int>32</int>
<int>33</int>
<int>34</int>
<int>35</int>
</nodeNeighbors>
<lastSent>2017-06-16 08:07:52.99 UTC</lastSent>
<lastReceived>2017-06-16 08:07:52.168 UTC</lastReceived>
</node>
Thanks - I’ll take a look tomorrow, but the first thing that I note is that your device shows the SWITCH_MULTILEVEL device class. Are you also able to provide the same thing for the development version (sorry to be a pain).
Sure, no problem at all (and no pain ):
Same prerequisites than above, except zwave binding is dev 201706122347, again node 11:
Debug log:
zwave.zip.xml (282.1 KB)
new xml:
<node>
<nodeId>11</nodeId>
<sleepDelay>1000</sleepDelay>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_METER</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_PROPRIETARY</commandClass>
<commandClass>COMMAND_CLASS_PROTECTION</commandClass>
<associationGroups>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations/>
</associationGroup>
</entry>
<endpoints>
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_MULTILEVEL</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_CLASS_B_MOTOR_CONTROL</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<entry>
<COMMAND__CLASS__PROTECTION>
<localModes>
</localModes>
<rfModes>
</rfModes>
</COMMAND__CLASS__PROTECTION>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__BINARY>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
<entry>
<COMMAND__CLASS__METER>
<meterScales>
</meterScales>
</COMMAND__CLASS__METER>
</entry>
<entry>
<switchTypeSecondary>DOWN_UP</switchTypeSecondary>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__MULTILEVEL>
<sensors>
<entry>
<multilevelSensor>
</multilevelSensor>
</entry>
</sensors>
</COMMAND__CLASS__SENSOR__MULTILEVEL>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters>
<entry>
<int>32</int>
<index>32</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>33</int>
<index>33</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>35</int>
<index>35</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>40</int>
<index>40</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>10</int>
<index>10</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>42</int>
<index>42</index>
<size>2</size>
<value>3600</value>
</entry>
<entry>
<int>43</int>
<index>43</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>12</int>
<index>12</index>
<size>2</size>
<value>150</value>
</entry>
<entry>
<int>44</int>
<index>44</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>13</int>
<index>13</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>14</int>
<index>14</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>17</int>
<index>17</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>18</int>
<index>18</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>50</int>
<index>50</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>22</int>
<index>22</index>
<size>2</size>
<value>240</value>
</entry>
<entry>
<int>29</int>
<index>29</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>30</int>
<index>30</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>31</int>
<index>31</index>
<size>1</size>
<value>0</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>3</int>
<int>4</int>
<int>8</int>
<int>10</int>
<int>12</int>
<int>13</int>
<int>23</int>
<int>26</int>
<int>28</int>
<int>30</int>
<int>31</int>
<int>32</int>
<int>33</int>
<int>34</int>
<int>35</int>
</nodeNeighbors>
<lastReceived>2017-06-16 15:21:37.163 UTC</lastReceived>
</node>
Just as a sidenote while surfing the net about Fibaro rollershutters:
I found a (German language) zway blog entry where it’s stated that the FGRM222 with firmware version 22.22 (like @RobZe89 one) first needs to be enabled for SWITCH_MULTILEVEL, because on default it is set to false. Unfortunately the blog does not tell which parameter number:
This is the command they are sending to the device to enable it:
http://<raspberrypi-ip>:8083/JS/Run/zway.devices[X].SwitchMultilevel.data.supported=true
#Response im Browser: true
http://<raspberrypi-ip>:8083/JS/Run/zway.devices.SaveData()
#Response im Browser: null
[20.09.2015] – kleiner Nachtrag: . Diese Codeausführung ist nur notwendig wenn die RollladenSchalter die Firmware Version 22.22 noch aufgespielt haben. Ab Firmware Version 24.24 ist dies nicht mehr nötig, die Schalter werden korrekt erkannt und eingebunden !
freely translated: enabling is only necessary for firmware versions 22.22. Beginning with firmware version 24.24 that is not necessary anymore.
So the issue is maybe just a wrong config parameter???
Interesting that you get the COMMAND_CLASS_SWITCH_MULTILEVEL. So you can control the blinds with up /down/stop?
Yes.
Line 27004: 2017-06-16 17:21:27.936 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 11: Creating new message for command SWITCH_MULTILEVEL_SUPPORTED_GET
Line 31319: 2017-06-16 17:21:36.898 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 11: Creating new message for command SWITCH_MULTILEVEL_GET
Line 32313: 2017-06-16 17:22:03.834 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 11: Creating new message for command SWITCH_MULTILEVEL_START_LEVEL_CHANGE
Line 32435: 2017-06-16 17:22:10.478 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 11: Creating new message for command SWITCH_MULTILEVEL_STOP_LEVEL_CHANGE
Line 32440: 2017-06-16 17:22:10.480 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 11: Creating new message for command SWITCH_MULTILEVEL_GET
Line 32699: 2017-06-16 17:22:15.011 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 11: Creating new message for command SWITCH_MULTILEVEL_START_LEVEL_CHANGE
My though is, that with OH1 there was a function to enable SWITCH_MULTILEVEL, because it defenetly worked fine on OH1. After updating to OH2 the SWITCH_MULTILEVEL was still enabled. After deleting the node xml the SWITCH_MULTILEVEL got lost and came not back to the node xml. So we have to force SWITCH_MULTILEVEL on this device on OH2. That would be great!
I don’t think so. Certainly there was nothing automatic in OH1 to enable this. OH1 had a very similar initialisation as OH2.
I guess the question is how to enable this? It seems a pretty strange thing for Fibaro to remove it.
I’ll also look to add this to the database to force this class - I’ll probably add that tomorrow when I’m home.
@sihui so everything is working ok for you or are there still some issues?
