You need to use a persistence system to save/restore item states on startup.
Thanks @chris! Iām actually persisting the alarm states.
However, the problem is that upon restarting openHAB (or the Z-Wave binding) I have no clue about the current state of the alarm.
Should I assume that the alarm is always OFF
unless it is turned ON
? In other words, the Z-Wave sensor wonāt report any alarm upon system restart unless an alarm is currently active? In yet other words, NULL
state is always equivalent to OFF
state for the alarm?
Unfortunately itās impossible to tell as itās not possible to poll āNotificationsā in ZWave - they are real time reports only. So if the state changes while the binding is offline, then itās not possible to find out what the state is and the binding cannot, and does not update it for this reason.
I see. And probably:
- the notifications are sent only once
- thereās no way to reset any notifications to force the sensor to re-fire notifications for active alarms
Would there be a way to use the ALARM command class and to query the alarm states through ALARM GET?
Correct.
There is no such thing. There is only the NOTIFICATION command class - the binding (for historical reasons) call this ALARM, but it changed names a long time ago.
I was looking into the Z-Wave documentation.
Although marked as DEPRECATED, the ALARM_SENSOR command class (which is supported by my smoke sensors) seems to do what I need: according to the documentation it can be used to query the alarm state of a given sensor node.
In the NOTIFICATIONS command class I see that there are 2 (3) basic operation modes: PUSH (1 mode) and PULL (2 modes):
- A Push node sends unsolicited Notifications. It is not possible to subsequently retrieve Notifications issued by a Push node.
- A Pull sensor collects events and state changes in a queue of pending Notifications. Notifications are retrieved one by one from the Pull sensor queue via the Notification Get Command.
- A persistent Pull Notification is not removed from the Pull sensor queue until it is actively cleared by a controlling node.
And I suppose that this is what youāre referring to. Only in the 3rd case could the binding query the notifications.
Iām aware of the different modes defined in the documentation, but that doesnāt really help. I discussed this issue with the ZWave Alliance a couple of years back and it was stated that this was not possible and not planned to be added. Iāve not checked all the changes, so maybe this has changed and if you want to investigate further and provide a PR that would be great.
In general, I try to use the modern functionality supported by ZWave where possible. There are hundreds of different options and if I try and support everything then Iām forever trying to add things to work around obscure issues like this. I agree that the protocol is lacking here, and thatās unfortunate.
Iāve not checked this specific device - if you find a better approach for polling, then please feel free to provide a PR and Iāll be happy to take a look at it.
