OK cool, thanks for the help.
@chris, I’m not sure where to go from here… It looks like there should be a third channel when adding the Swipe but I only get the two. Is there any way to manually add this or add it to the database?
What is the channel you want? We can add it to the database, but unless it’s linked to a command class, it’s not going to work.
Please let me know the command class you are expecting - really it should have been in the XML, but maybe it was missed…
@pa1 do you know the command class KeyAttribute uses?
Can you provide the XML from a recent OH2 binding? Possibly delete the current one and restart - just so we know it’s updated…
OK I’ll try and get that now or this evening more likely… I’ll post it here when I’ve got it.
OK I updated the zwave binding just now and deleted the existing XML and let it regenerate. Here’s the new XML:
<node> <deviceClass> <basicDeviceClass>ROUTING_SLAVE</basicDeviceClass> <genericDeviceClass>REMOTE_SWITCH_2</genericDeviceClass> <specificDeviceClass>SWITCH_REMOTE2_MULTILEVEL</specificDeviceClass> </deviceClass> <homeId>0xec3d88f9</homeId> <nodeId>12</nodeId> <version>4</version> <manufacturer>0x10f</manufacturer> <deviceId>0x1000</deviceId> <deviceType>0xd01</deviceType> <listening>false</listening> <frequentlyListening>false</frequentlyListening> <routing>true</routing> <security>false</security> <beaming>true</beaming> <maxBaudRate>40000</maxBaudRate> <nodeInformationFrame> <commandClass>ZWAVE_PLUS_INFO</commandClass> <commandClass>ASSOCIATION</commandClass> <commandClass>ASSOCIATION_GROUP_INFO</commandClass> <commandClass>BATTERY</commandClass> <commandClass>CENTRAL_SCENE</commandClass> <commandClass>CONFIGURATION</commandClass> <commandClass>CRC_16_ENCAP</commandClass> <commandClass>DEVICE_RESET_LOCALLY</commandClass> <commandClass>FIRMWARE_UPDATE_MD</commandClass> <commandClass>MANUFACTURER_SPECIFIC</commandClass> <commandClass>MULTI_INSTANCE_ASSOCIATION</commandClass> <commandClass>POWERLEVEL</commandClass> <commandClass>SECURITY</commandClass> <commandClass>VERSION</commandClass> <commandClass>WAKE_UP</commandClass> </nodeInformationFrame> <supportedCommandClasses> <entry> <commandClass>FIRMWARE_UPDATE_MD</commandClass> <firmwareUpdateCommandClass> <version>3</version> <instances>1</instances> <versionSupported>3</versionSupported> </firmwareUpdateCommandClass> </entry> <entry> <commandClass>BASIC</commandClass> <basicCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <isGetSupported>true</isGetSupported> </basicCommandClass> </entry> <entry> <commandClass>ASSOCIATION_GROUP_INFO</commandClass> <associationGroupInfoCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <autoSubscribeGroups> <int>1</int> </autoSubscribeGroups> <groups> <entry> <int>1</int> <associationGroupInfo> <name>Lifeline</name> <profile>1</profile> <commands> <commandClass>BATTERY</commandClass> <commandClass>DEVICE_RESET_LOCALLY</commandClass> <commandClass>CENTRAL_SCENE</commandClass> </commands> <outer-class reference="../../../.."/> </associationGroupInfo> </entry> <entry> <int>2</int> <associationGroupInfo> <name>Flick UP</name> <profile>8193</profile> <commands> <commandClass>BASIC</commandClass> </commands> <outer-class reference="../../../.."/> </associationGroupInfo> </entry> <entry> <int>3</int> <associationGroupInfo> <name>Flick DOWN</name> <profile>8194</profile> <commands> <commandClass>BASIC</commandClass> </commands> <outer-class reference="../../../.."/> </associationGroupInfo> </entry> <entry> <int>4</int> <associationGroupInfo> <name>Flick LEFT</name> <profile>8195</profile> <commands> <commandClass>BASIC</commandClass> </commands> <outer-class reference="../../../.."/> </associationGroupInfo> </entry> <entry> <int>5</int> <associationGroupInfo> <name>Flick RIGHT</name> <profile>8196</profile> <commands> <commandClass>BASIC</commandClass> </commands> <outer-class reference="../../../.."/> </associationGroupInfo> </entry> <entry> <int>6</int> <associationGroupInfo> <name>Circular AirWheel</name> <profile>8197</profile> <commands/> <outer-class reference="../../../.."/> </associationGroupInfo> </entry> </groups> </associationGroupInfoCommandClass> </entry> <entry> <commandClass>WAKE_UP</commandClass> <WakeUpCommandClass> <version>2</version> <instances>1</instances> <versionSupported>2</versionSupported> <targetNodeId>1</targetNodeId> <interval>60</interval> <minInterval>60</minInterval> <maxInterval>64800</maxInterval> <defaultInterval>21600</defaultInterval> <intervalStep>1</intervalStep> <lastWakeup>2016-05-16 16:08:25.710 UTC</lastWakeup> <isGetSupported>true</isGetSupported> </WakeUpCommandClass> </entry> <entry> <commandClass>NO_OPERATION</commandClass> <noOperationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </noOperationCommandClass> </entry> <entry> <commandClass>VERSION</commandClass> <versionCommandClass> <version>2</version> <instances>1</instances> <versionSupported>2</versionSupported> <libraryType>LIB_SLAVE_ENHANCED</libraryType> <protocolVersion>4.5</protocolVersion> <applicationVersion>3.2</applicationVersion> </versionCommandClass> </entry> <entry> <commandClass>CRC_16_ENCAP</commandClass> <crc16EncapsulationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </crc16EncapsulationCommandClass> </entry> <entry> <commandClass>BATTERY</commandClass> <batteryCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <batteryLevel>100</batteryLevel> <batteryLow>false</batteryLow> <isGetSupported>true</isGetSupported> </batteryCommandClass> </entry> <entry> <commandClass>CONFIGURATION</commandClass> <configurationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <configParameters> <entry> <int>1</int> <configurationParameter> <index>1</index> <size>1</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>2</int> <configurationParameter> <index>2</index> <size>1</size> <value>1</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>3</int> <configurationParameter> <index>3</index> <size>1</size> <value>1</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>4</int> <configurationParameter> <index>4</index> <size>1</size> <value>3</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>5</int> <configurationParameter> <index>5</index> <size>2</size> <value>4</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>6</int> <configurationParameter> <index>6</index> <size>1</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>7</int> <configurationParameter> <index>7</index> <size>1</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>10</int> <configurationParameter> <index>10</index> <size>1</size> <value>15</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>11</int> <configurationParameter> <index>11</index> <size>1</size> <value>31</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>12</int> <configurationParameter> <index>12</index> <size>1</size> <value>15</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>13</int> <configurationParameter> <index>13</index> <size>2</size> <value>255</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>20</int> <configurationParameter> <index>20</index> <size>2</size> <value>255</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>21</int> <configurationParameter> <index>21</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>22</int> <configurationParameter> <index>22</index> <size>2</size> <value>255</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>23</int> <configurationParameter> <index>23</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>24</int> <configurationParameter> <index>24</index> <size>2</size> <value>255</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>25</int> <configurationParameter> <index>25</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>26</int> <configurationParameter> <index>26</index> <size>2</size> <value>255</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>27</int> <configurationParameter> <index>27</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>30</int> <configurationParameter> <index>30</index> <size>1</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>31</int> <configurationParameter> <index>31</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>32</int> <configurationParameter> <index>32</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>33</int> <configurationParameter> <index>33</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>34</int> <configurationParameter> <index>34</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>35</int> <configurationParameter> <index>35</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>36</int> <configurationParameter> <index>36</index> <size>2</size> <value>0</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> </configParameters> </configurationCommandClass> </entry> <entry> <commandClass>MANUFACTURER_SPECIFIC</commandClass> <manufacturerSpecificCommandClass> <version>2</version> <instances>1</instances> <versionSupported>2</versionSupported> </manufacturerSpecificCommandClass> </entry> <entry> <commandClass>DEVICE_RESET_LOCALLY</commandClass> <deviceResetLocallyCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </deviceResetLocallyCommandClass> </entry> <entry> <commandClass>ASSOCIATION</commandClass> <associationCommandClass> <version>2</version> <instances>1</instances> <versionSupported>2</versionSupported> <configAssociations> <entry> <int>1</int> <associationGroup> <index>1</index> <associations> <associationMember> <node>1</node> <endpoint>0</endpoint> </associationMember> </associations> </associationGroup> </entry> <entry> <int>2</int> <associationGroup> <index>2</index> <associations/> </associationGroup> </entry> <entry> <int>3</int> <associationGroup> <index>3</index> <associations/> </associationGroup> </entry> <entry> <int>4</int> <associationGroup> <index>4</index> <associations/> </associationGroup> </entry> <entry> <int>5</int> <associationGroup> <index>5</index> <associations/> </associationGroup> </entry> <entry> <int>6</int> <associationGroup> <index>6</index> <associations/> </associationGroup> </entry> </configAssociations> <maxGroups>6</maxGroups> </associationCommandClass> </entry> <entry> <commandClass>CENTRAL_SCENE</commandClass> <centralSceneCommandClass> <version>2</version> <instances>1</instances> <versionSupported>2</versionSupported> <sceneCount>12</sceneCount> </centralSceneCommandClass> </entry> <entry> <commandClass>ZWAVE_PLUS_INFO</commandClass> <zwavePlusCommandClass> <version>2</version> <instances>1</instances> <versionSupported>2</versionSupported> <zwPlusVersion>1</zwPlusVersion> <zwPlusRole>4</zwPlusRole> <zwPlusNodeType>0</zwPlusNodeType> <zwPlusDeviceType>0x1600</zwPlusDeviceType> <zwPlusInstallerIcon>0x1600</zwPlusInstallerIcon> <isGetSupported>true</isGetSupported> </zwavePlusCommandClass> </entry> <entry> <commandClass>POWERLEVEL</commandClass> <powerLevelCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <powerLevel>0</powerLevel> <powerTimeout>0</powerTimeout> </powerLevelCommandClass> </entry> </supportedCommandClasses> <securedCommandClasses/> <nodeNeighbors> <int>1</int> </nodeNeighbors> <lastSent>2016-05-16 16:08:31.542 UTC</lastSent> <lastReceived>2016-05-16 16:08:31.589 UTC</lastReceived> </node>
Looks ok - or at least consistent with the database.
I guess the next step is to understand what the device sends under for this condition - if you can get a log, and say exactly what you were doing at what time so we can correlate the received data with the action, then I’ll take a look…
I’ve not been able to test this as I can’t enable the command gestures via config parameters from within Habmin. I’ve still got the issue with parameters which have a drop down list not working with free text input as well.
For now I’ve updated the config in the zwave database with an option which I was trying to enable using free text so I can use this when the binding is updated until the issue is resolved.
What log data do you need from me once I’ve got the above working?
I’m looking at this at the moment, along with tagging and a couple of other issues with HABmin. Hopefully there will be an update tonight that will solve this issue (I hope! ).
Just a Z-Wave debug log - but I need to be able to tie what you’re doing to the incoming messages, so either you need to annotate the logs, or, provide a list that says "at 3:01 I did X"such that the times align with the log (this is probably best).
Right, I will update with that when I can - will the zwave binding be updated tonight?
I know there are a bunch of database updates pending, and I’ll update these - is that what you mean, or are you after a change for something?
Nope, that’s what I’m after
I’ve updated a config parameter for this device which I need to enable the commands I want to be able to use. Basically the device has 6 commands, swipe up, down, left, right, and both clockwise and counter-clockwise circular gestures (for dimming etc).
By default the circular gestures aren’t enabled so I updated the parameter with an option to enable all commands as the free text entry wasn’t working.
@krish I’ve pushed a snapshot of HABmin2 that will hopefully fix this issue - please let me know if it’s ok and I’ll make a release version.
@feens this should also support tagging on items.
What did you update?
If I do a diff on the XML, it shows nothing changed, so whatever you changed in the database didn’t have a resulting impact on the XML.
I added a new option value for parameter 10. Option value 63 - all commands enabled.
The bottom of the page shows it was last updated by me 3 hours ago so it looks like it’s definitely saved…
Ok - I missed that - it’s ok, thanks.
How do I update habmin? I assumed I just put the new .jar file in the addons folder and restart openhab but that doesn’t seem to have done the job…
You should normally just be able to delete the old JAR and add the new one. If that doesn’t work, then you need to look at the Karaf console and check out what bundles are running, and stop the one you don’t want.
OK all good with the new version, I was able to change the parameter properly this time. Thanks for fixing that
OK here is what I get in the log when I perform a circular anti-clockwise gesture on the swipe (scene 6). I started performing the gesture at 21:09:41 and kept it going for 20 seconds until 21:20:10.
2016-05-22 21:09:41.627 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 0C 05 5B 03 63 02 06 C6
2016-05-22 21:09:41.628 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-05-22 21:09:41.628 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 0C 05 5B 03 63 02 06 C6
2016-05-22 21:09:41.628 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 0C 05 5B 03 63 02 06 C6
2016-05-22 21:09:41.628 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 05 5B 03 63 02 06
2016-05-22 21:09:41.629 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (ALIVE:DONE)
2016-05-22 21:09:41.629 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
2016-05-22 21:09:41.629 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@79ce6fca already registered
2016-05-22 21:09:41.629 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class CENTRAL_SCENE
2016-05-22 21:09:41.629 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 12: Received CENTRAL_SCENE command V2
2016-05-22 21:09:41.629 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 12: Received scene 6 at time 2
2016-05-22 21:09:41.629 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-05-22 21:09:41.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-05-22 21:09:41.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 6
2016-05-22 21:09:41.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:device:00d10a4d:node12:scene_number to 6
2016-05-22 21:09:41.630 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=23, payload=0C 02 84 08
2016-05-22 21:09:41.630 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 05 5B 03 63 02 06
2016-05-22 21:09:41.630 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=23, expected=SendData, cancelled=false MISMATCH
2016-05-22 21:09:41.631 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_sof changed from 150 to 151
2016-05-22 21:09:41.632 [INFO ] [marthome.event.ItemStateChangedEvent] - swipe_scene changed from 5 to 6
2016-05-22 21:10:00.479 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 0C 05 5B 03 64 01 06 C2
2016-05-22 21:10:00.481 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-05-22 21:10:00.481 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 0C 05 5B 03 64 01 06 C2
2016-05-22 21:10:00.481 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 0C 05 5B 03 64 01 06 C2
2016-05-22 21:10:00.482 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 05 5B 03 64 01 06
2016-05-22 21:10:00.482 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_sof changed from 151 to 152
2016-05-22 21:10:00.482 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (ALIVE:DONE)
2016-05-22 21:10:00.482 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
2016-05-22 21:10:00.482 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@79ce6fca already registered
2016-05-22 21:10:00.482 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class CENTRAL_SCENE
2016-05-22 21:10:00.482 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 12: Received CENTRAL_SCENE command V2
2016-05-22 21:10:00.482 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 12: Received scene 6 at time 1
2016-05-22 21:10:00.482 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-05-22 21:10:00.483 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-05-22 21:10:00.483 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 6
2016-05-22 21:10:00.483 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:device:00d10a4d:node12:scene_number to 6
2016-05-22 21:10:00.483 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=23, payload=0C 02 84 08
2016-05-22 21:10:00.484 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 05 5B 03 64 01 06
2016-05-22 21:10:00.484 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=23, expected=SendData, cancelled=false MISMATCH
And here’s the the clockwise circle gesture performed for 10 seconds:
2016-05-22 21:23:31.959 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 0C 05 5B 03 71 02 05 D7
2016-05-22 21:23:31.959 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_sof changed from 203 to 204
2016-05-22 21:23:31.960 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-05-22 21:23:31.961 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 0C 05 5B 03 71 02 05 D7
2016-05-22 21:23:31.961 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 0C 05 5B 03 71 02 05 D7
2016-05-22 21:23:31.961 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 05 5B 03 71 02 05
2016-05-22 21:23:31.961 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (ALIVE:DONE)
2016-05-22 21:23:31.961 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
2016-05-22 21:23:31.961 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@79ce6fca already registered
2016-05-22 21:23:31.961 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class CENTRAL_SCENE
2016-05-22 21:23:31.962 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 12: Received CENTRAL_SCENE command V2
2016-05-22 21:23:31.962 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 12: Received scene 5 at time 2
2016-05-22 21:23:31.962 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-05-22 21:23:31.962 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-05-22 21:23:31.962 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 5
2016-05-22 21:23:31.962 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:device:00d10a4d:node12:scene_number to 5
2016-05-22 21:23:31.963 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=37, payload=0C 02 84 08
2016-05-22 21:23:31.963 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 05 5B 03 71 02 05
2016-05-22 21:23:31.963 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=37, expected=SendData, cancelled=false MISMATCH
2016-05-22 21:23:40.004 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 0C 05 5B 03 72 01 05 D7
2016-05-22 21:23:40.005 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_sof changed from 204 to 205
2016-05-22 21:23:40.005 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-05-22 21:23:40.005 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 0C 05 5B 03 72 01 05 D7
2016-05-22 21:23:40.005 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 0C 05 5B 03 72 01 05 D7
2016-05-22 21:23:40.006 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 05 5B 03 72 01 05
2016-05-22 21:23:40.006 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (ALIVE:DONE)
2016-05-22 21:23:40.006 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
2016-05-22 21:23:40.006 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@79ce6fca already registered
2016-05-22 21:23:40.006 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class CENTRAL_SCENE
2016-05-22 21:23:40.006 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 12: Received CENTRAL_SCENE command V2
2016-05-22 21:23:40.006 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 12: Received scene 5 at time 1
2016-05-22 21:23:40.006 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-05-22 21:23:40.006 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-05-22 21:23:40.006 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 5
2016-05-22 21:23:40.007 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:device:00d10a4d:node12:scene_number to 5
2016-05-22 21:23:40.007 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=37, payload=0C 02 84 08
2016-05-22 21:23:40.007 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 05 5B 03 72 01 05
2016-05-22 21:23:40.007 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=37, expected=SendData, cancelled=false MISMATCH
It looks like a command is received twice with the scene number, once when it starts and then again when it finishes.
I notice when it starts there’s a line:
And when it finishes:
