Some more users (see post above, thx):
@donutVillain
@mackemot
@randomname872634
@martindk
@throbin
@volvotoket
@tomm
@bernd_d
@tjarvstrand
@helmar74
@donutVillain
@mackemot
@randomname872634
@martindk
@throbin
@volvotoket
@tomm
@bernd_d
@tjarvstrand
@helmar74
Again some more users:
@normen
@Nerdletics
@mstormi
@Woutch
@rtvb
@PerA
@michel53
@Stripe68
@Gargam3L0
I had to switch from @randomname872634 to @randomname
My habmin is broken, so I got my data from the xml’s in the userdata/zwave folder.
| Data | Value |
| Device name | FGWP102 |
| Device Type | 0602 |
| Device Id | 1001 |
| Version | 3.2 |
Thanks!
It’s in the COMMAND_CLASS_VERSION, subentry applicationVersion
<entry>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<COMMAND__CLASS__VERSION>
<version>1</version>
<instances>1</instances>
<versionSupported>1</versionSupported>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>3.52</protocolVersion>
<applicationVersion>25.25</applicationVersion>
</COMMAND__CLASS__VERSION>
</entry>
Thx, I’ve edited my previous post with the applicationVersion
FGWP102
<manufacturer>0x10f</manufacturer>
<deviceId>0x1001</deviceId>
<deviceType>0x602</deviceType>
<entry>
<commandClass>VERSION</commandClass>
<versionCommandClass>
<version>2</version>
<versionSupported>2</versionSupported>
<protocolVersion>4.5</protocolVersion>
<applicationVersion>3.2</applicationVersion>
<hardwareVersion>2</hardwareVersion>
</versionCommandClass>
</entry>
FGWP101
<deviceId>0x1000</deviceId>
<deviceType>0x600</deviceType>
<entry>
</entry>
Hi
added 2 replys ![]()
Here you go
Device name FGWP102
Device Type 0602
Device Id 1001
Version 3.2
here are my values:
Device name FGWP101
Device Type 0600
Device Id 1000
Version 25.25
I have five of these devices. All of them have the following information:
| Data | Value |
| Device name | FGWP101 |
| Device Type | 0600 |
| Device Id | 1000 |
| Version | 25.25 |
7 Devices, all the same:
| Data | Value |
| Device Id | 1001 |
| Version | 3.2 |
I still had it on my harddisk
I experienced that it is from time to time quite helpful to have some older versions from OH software components.
I uploaded it for you to
https://filebin.ca/3noBzPXkUfGg
ok, I have
| Data | Value |
| Device Id | 1001 |
| Version | 3.2 |
and also
| Data | Value |
| Device Id | 1000 |
| Version | 25.25 |
my values
| Data | Value |
| Device Id | 1001 |
| Version | 3.2 |
sure, if it helps!
Let my give a first summary of the data:
6 devices with
| Data | Value |
| Device Id | 1000 |
| Version | 2.5 |
Users: sihui, QNimbus, helmar24, Andreh_T, KjetilA, vossivossi
6 devices with
| Data | Value |
| Device Id | 1001 |
| Version | 3.2 |
Users: randomname, helmar24, bernd_d, michel53, vossivossi, Dibbler42
1 device with
| Data | Value |
| Device Id | 1001 |
| Version | 4 |
User: NCO
I will update this summary when more data is coming in …
@vossivossi Thank you very much! Very helpful!
Slightly off-topic, but I would like to express my appreciation for this community and the way everyone pools together to help resolve issues (like this one). This is exactly why I’m an active promoter for OpenHAB. I’ve just talked a friend and colleague into switching from Fibaro HC to OpenHab using Chris’s ZWave binding!
Thanks @sihui - I’ll take a look at this this afternoon and try and update the binding.
hi…
i have 2 of my 5 switches already included again - of course without success. here the information.
Devices should all be FW101.
010f…manu
0600:1000…type/id
25.25…firmware
010f…manu
0600:1000…type id
24.24…firmware
btw. is there any “whatever hack is needed” way to upgrade especially Fibaro nodes with new firmware…if not the original controller is available…(beside the bricking that may happen …)
