Last login: Tue Oct 11 20:16:56 on ttys000
LaSpencias-MacBook-Air:~ laspencia$ /opt/openhab/runtime/start_debug.sh ; exit;
Launching the openHAB runtime in debug mode…
Listening for transport dt_socket at address: 8001
osgi> 20:20:33.296 [DEBUG] [.s.internal.SchedulerActivator:36 ] - Scheduler has been started.
20:20:33.342 [INFO ] [uartz.impl.StdSchedulerFactory:1175 ] - Using default implementation for ThreadExecutor
20:20:33.365 [INFO ] [rtz.core.SchedulerSignalerImpl:61 ] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
20:20:33.366 [INFO ] [rg.quartz.core.QuartzScheduler:243 ] - Quartz Scheduler v.2.1.7 created.
20:20:33.368 [INFO ] [org.quartz.simpl.RAMJobStore :154 ] - RAMJobStore initialized.
20:20:33.370 [INFO ] [rg.quartz.core.QuartzScheduler:268 ] - Scheduler meta-data: Quartz Scheduler (v2.1.7) ‘openHAB-job-scheduler’ with instanceId ‘NON_CLUSTERED’
Scheduler class: ‘org.quartz.core.QuartzScheduler’ - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool ‘org.quartz.simpl.SimpleThreadPool’ - with 2 threads.
Using job-store ‘org.quartz.simpl.RAMJobStore’ - which does not support persistence. and is not clustered.
20:20:33.371 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler ‘openHAB-job-scheduler’ initialized from specified file: ‘./etc/quartz.properties’
20:20:33.372 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7
20:20:33.372 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$NONCLUSTERED started.
20:20:33.376 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file ‘/opt/openhab/runtime/configurations/openhab_default.cfg’.
20:20:33.438 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file ‘/opt/openhab/runtime/configurations/openhab.cfg’.
20:20:33.464 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at ‘/opt/openhab/runtime/webapps/static/uuid’ with content ‘2045263c-1f04-489e-9dfe-53693766ffb8’
20:20:33.466 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file ‘/opt/openhab/runtime/webapps/static/version’ with content ‘1.8.3’
20:20:33.466 [INFO ] [.o.core.internal.CoreActivator:61 ] - openHAB runtime has been started (v1.8.3).
20:20:33.507 [DEBUG] [a.internal.AutoUpdateActivator:31 ] - AutoUpdate binding has been started.
20:20:35.013 [DEBUG] [.p.i.PersistenceModelActivator:23 ] - Registered ‘persistence’ configuration parser
20:20:35.041 [DEBUG] [.c.t.i.TransformationActivator:38 ] - Transformation Service has been started.
20:20:35.096 [DEBUG] [m.internal.MultimediaActivator:34 ] - Multimedia I/O bundle has been started.
20:20:35.123 [DEBUG] [.s.i.DiscoveryServiceActivator:27 ] - Discovery service has been started.
20:20:35.128 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:93 ] - mDNS service has been started
20:20:35.147 [DEBUG] [.io.transport.mqtt.MqttService:123 ] - Starting MQTT Service…
20:20:35.171 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:53 ] - Service Discovery initialization completed.
20:20:35.298 [DEBUG] [.i.internal.ItemModelActivator:24 ] - Registered ‘item’ configuration parser
20:20:35.414 [DEBUG] [o.o.c.i.items.ItemRegistryImpl:137 ] - Item provider ‘GenericItemProvider’ has been added.
20:20:36.388 [DEBUG] [.o.m.s.i.SitemapModelActivator:23 ] - Registered ‘sitemap’ configuration parser
20:20:36.489 [DEBUG] [io.rest.internal.RESTActivator:33 ] - REST API has been started.
20:20:36.550 [INFO ] [org.atmosphere.util.IOUtils :370 ] - META-INF/services/org.atmosphere.cpr.AtmosphereFramework not found in class loader
20:20:36.573 [INFO ] [sphere.cpr.AtmosphereFramework:2601 ] - Atmosphere is using org.atmosphere.cpr.DefaultAnnotationProcessor for processing annotation
20:20:36.575 [INFO ] [cpr.DefaultAnnotationProcessor:138 ] - AnnotationProcessor class org.atmosphere.cpr.DefaultAnnotationProcessor$BytecodeBasedAnnotationProcessor being used
20:20:36.586 [WARN ] [cpr.DefaultAnnotationProcessor:178 ] - Unable to detect annotations. Application may fail to deploy.
20:20:36.612 [INFO ] [sphere.cpr.AtmosphereFramework:1891 ] - Auto detecting atmosphere handlers /WEB-INF/classes/
20:20:36.628 [INFO ] [sphere.cpr.AtmosphereFramework:639 ] - Installed AtmosphereHandler org.atmosphere.handler.ReflectorServletProcessor mapped to context-path /* and Broadcaster Class org.atmosphere.jersey.JerseyBroadcaster
20:20:36.628 [INFO ] [sphere.cpr.AtmosphereFramework:1945 ] - Auto detecting WebSocketHandler in /WEB-INF/classes/
20:20:36.629 [INFO ] [sphere.cpr.AtmosphereFramework:1602 ] - Installed WebSocketProtocol org.atmosphere.websocket.protocol.SimpleHttpProtocol
20:20:36.657 [INFO ] [.a.h.ReflectorServletProcessor:103 ] - Installing Servlet com.sun.jersey.spi.container.servlet.ServletContainer
20:20:36.763 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:815 ] - Initiating Jersey application, version ‘Jersey: 1.18.1 02/19/2014 03:28 AM’
20:20:36.766 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:826 ] - Adding the following classes declared in META-INF/services/jersey-server-components to the resource configuration:
class org.atmosphere.jersey.AtmosphereResourceConfigurator
20:20:36.818 [INFO ] [j.s.i.a.DeferredResourceConfig:101 ] - Instantiated the Application class org.openhab.io.rest.RESTApplication
20:20:37.569 [INFO ] [sphere.cpr.AtmosphereFramework:2435 ] - AtmosphereInterceptor CORS Interceptor Support will always be executed first
20:20:37.572 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor CORS Interceptor Support with priority FIRST_BEFORE_DEFAULT
20:20:37.573 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Default Response’s Headers Interceptor with priority AFTER_DEFAULT
20:20:37.575 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Android Interceptor Support with priority AFTER_DEFAULT
20:20:37.576 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor SSE Interceptor Support with priority AFTER_DEFAULT
20:20:37.577 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor JSONP Interceptor Support with priority AFTER_DEFAULT
20:20:37.580 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Atmosphere JavaScript Protocol with priority AFTER_DEFAULT
20:20:37.581 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Browser disconnection detection with priority AFTER_DEFAULT
20:20:37.587 [INFO ] [sphere.cpr.AtmosphereFramework:935 ] - Using EndpointMapper class org.atmosphere.util.DefaultEndpointMapper
20:20:37.589 [WARN ] [sphere.cpr.AtmosphereFramework:941 ] - No BroadcasterCache configured. Broadcasted message between client reconnection will be LOST. It is recommended to configure the org.atmosphere.cache.UUIDBroadcasterCache
20:20:37.589 [INFO ] [sphere.cpr.AtmosphereFramework:949 ] - Default Broadcaster Class: org.atmosphere.jersey.JerseyBroadcaster
20:20:37.590 [INFO ] [sphere.cpr.AtmosphereFramework:950 ] - Broadcaster Polling Wait Time 100
20:20:37.590 [INFO ] [sphere.cpr.AtmosphereFramework:951 ] - Shared ExecutorService supported: true
20:20:37.593 [INFO ] [sphere.cpr.AtmosphereFramework:958 ] - Messaging Thread Pool Size: 10
20:20:37.594 [INFO ] [sphere.cpr.AtmosphereFramework:968 ] - Async I/O Thread Pool Size: 10
20:20:37.595 [INFO ] [sphere.cpr.AtmosphereFramework:979 ] - Using BroadcasterFactory: org.atmosphere.cpr.DefaultBroadcasterFactory
20:20:37.595 [INFO ] [sphere.cpr.AtmosphereFramework:980 ] - Using WebSocketProcessor: org.atmosphere.websocket.DefaultWebSocketProcessor
20:20:37.595 [INFO ] [sphere.cpr.AtmosphereFramework:990 ] - Invoke AtmosphereInterceptor on WebSocket message true
20:20:37.596 [INFO ] [sphere.cpr.AtmosphereFramework:991 ] - HttpSession supported: false
20:20:37.597 [INFO ] [sphere.cpr.AtmosphereFramework:993 ] - Atmosphere is using DefaultAtmosphereObjectFactory for dependency injection and object creation
20:20:37.597 [INFO ] [sphere.cpr.AtmosphereFramework:994 ] - Atmosphere is using async support: org.atmosphere.container.JettyAsyncSupportWithWebSocket running under container: jetty/8.1.3.v20120522 with WebSocket enabled.
20:20:37.599 [INFO ] [sphere.cpr.AtmosphereFramework:996 ] - Atmosphere Framework 2.2.5 started.
20:20:37.599 [INFO ] [sphere.cpr.AtmosphereFramework:998 ] -
For Atmosphere Framework Commercial Support, visit
http://www.async-io.org/ or send an email to support@async-io.org
20:20:37.603 [INFO ] [penhab.io.rest.RESTApplication:144 ] - Started REST API at /rest
20:20:37.605 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service openhab-server.tcp.local. at port 8080
20:20:42.914 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service openhab-server-ssl.tcp.local. at port 8443
20:20:44.336 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘demo.sitemap’
20:20:44.563 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘demo.script’
20:20:44.660 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘db4o.persist’
20:20:44.678 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘exec.persist’
20:20:44.684 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘logging.persist’
20:20:44.689 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘rrd4j.persist’
20:20:44.720 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘demo.items’
20:20:44.735 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model ‘demo.items’
20:20:44.737 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model ‘demo.items’
20:20:45.577 [INFO ] [.o.u.w.i.servlet.WebAppServlet:80 ] - Started Classic UI at /classicui/openhab.app
20:20:46.003 [DEBUG] [.r.internal.RuleModelActivator:42 ] - Registered ‘rules’ configuration parser
20:20:46.019 [DEBUG] [m.r.internal.engine.RuleEngine:77 ] - Started rule engine
20:20:50.096 [DEBUG] [.a.mqtt.internal.MqttActivator:34 ] - Mqtt action has been started.
20:20:50.101 [DEBUG] [.o.b.ntp.internal.NtpActivator:31 ] - NTP binding has been started.
20:20:50.114 [INFO ] [.service.AbstractActiveService:169 ] - NTP Refresh Service has been started
20:20:50.115 [DEBUG] [inding.ntp.internal.NtpBinding:78 ] - There is no existing NTP binding configuration => refresh cycle aborted!
20:20:50.117 [DEBUG] [xecPersistenceServiceActivator:33 ] - Exec persistence bundle has been started.
20:20:50.126 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing exec persistence service.
20:20:50.151 [DEBUG] [.p.internal.PersistenceManager:428 ] - Scheduled strategy exec.everyMinute with cron expression 0 * * * * ?
20:20:50.167 [DEBUG] [.rrd4j.internal.RRD4jActivator:31 ] - RRD4j persistence bundle has been started.
20:20:50.180 [DEBUG] [.p.rrd4j.internal.RRD4jService:395 ] - Unknown property name : org.openhab.persistence.rrd4j
20:20:50.180 [DEBUG] [.p.rrd4j.internal.RRD4jService:364 ] - config ‘objectClass’ should have the format ‘name.configkey’
20:20:50.181 [DEBUG] [.p.rrd4j.internal.RRD4jService:405 ] - Created default_numeric = GAUGE heartbeat = 60 min/max = NaN/NaN step = 60 6 archives(s) = [ AVERAGE xff = 0.5 steps = 1 rows = 480 AVERAGE xff = 0.5 steps = 4 rows = 360 AVERAGE xff = 0.5 steps = 14 rows = 644 AVERAGE xff = 0.5 steps = 60 rows = 720 AVERAGE xff = 0.5 steps = 720 rows = 730 AVERAGE xff = 0.5 steps = 10080 rows = 520] 0 items(s) = []
20:20:50.182 [DEBUG] [.p.rrd4j.internal.RRD4jService:405 ] - Created default_other = GAUGE heartbeat = 3600 min/max = NaN/NaN step = 1 6 archives(s) = [ MAX xff = 0.999 steps = 1 rows = 3600 MAX xff = 0.999 steps = 10 rows = 1440 MAX xff = 0.999 steps = 60 rows = 1440 MAX xff = 0.999 steps = 900 rows = 2880 MAX xff = 0.999 steps = 21600 rows = 1460 MAX xff = 0.999 steps = 86400 rows = 3650] 0 items(s) = []
20:20:50.182 [INFO ] [.p.rrd4j.internal.RRD4jService:407 ] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
20:20:50.185 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing rrd4j persistence service.
20:20:50.211 [DEBUG] [.p.internal.PersistenceManager:315 ] - Item ‘DemoSwitch’ does not exist.
20:20:50.212 [DEBUG] [.p.internal.PersistenceManager:315 ] - Item ‘NoOfLights’ does not exist.
20:20:50.213 [DEBUG] [.p.internal.PersistenceManager:315 ] - Item ‘Window_GF_Toilet’ does not exist.
20:20:50.213 [DEBUG] [.p.internal.PersistenceManager:328 ] - Item group ‘Heating’ does not exist.
20:20:50.214 [DEBUG] [.p.internal.PersistenceManager:328 ] - Item group ‘Temperature’ does not exist.
20:20:50.215 [DEBUG] [.p.internal.PersistenceManager:328 ] - Item group ‘Weather_Chart’ does not exist.
20:20:50.217 [DEBUG] [.p.internal.PersistenceManager:428 ] - Scheduled strategy rrd4j.everyMinute with cron expression 0 * * * * ?
20:20:50.222 [DEBUG] [p.r.i.charts.RRD4jChartServlet:118 ] - Starting up rrd chart servlet at /rrdchart.png
20:20:50.224 [DEBUG] [.i.LoggingPersistenceActivator:31 ] - Logging persistence bundle has been started.
20:20:50.231 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing logging persistence service.
20:20:50.234 [DEBUG] [.b.http.internal.HttpActivator:34 ] - HTTP binding has been started.
20:20:50.246 [INFO ] [.service.AbstractActiveService:169 ] - HTTP Refresh Service has been started
20:20:50.248 [DEBUG] [.b.mqtt.internal.MqttActivator:34 ] - MQTT binding has been started.
20:20:50.262 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘itm_garage_dist (Type=NumberItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
20:20:50.264 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ] - Loaded MQTT config for item ‘itm_garage_dist’ : 1 subscribers, 0 publishers
20:20:50.271 [DEBUG] [m.internal.MqttEventBusBinding:68 ] - MQTT: Activating event bus binding.
20:20:54.869 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘demo.rules’
