- Platform information:
- Hardware: Raspi 4 with 8 gigs of RAM
- OS: Openhabian version 1.6.3
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 3
I’ve recently upgraded to openhab 3 and so far I haven’t had any issues recreating my old rules, but I’ve run into an issue with one of the simpler ones.
In openhab 2 I had a simple rule created inside visual studio code that never had any issues.
rule “light switch”
Item LightSwitch changed to ON
executeCommandLine(“iono@@o1@@close”)
as far as I can tell Blockly isn’t adequate for this rule so I’ve been trying to run it using a script in the Rule DSL format. From all of the other threads that I’ve read so far it seems like all I have to have in the script is:
executeCommandLine(“iono o1 close”)
Unfortunately the command never runs correctly and my log throws up 50+ lines of issues always starting with:
2021-02-02 03:26:19.494 [WARN ] [rg.openhab.core.io.net.exec.ExecUtil] - Error occurred when executing commandLine ‘[iono o1 close]’
java.io.IOException: Cannot run program “iono o1 close”: error=2, No such file or directory
I’ve logged into the console via SSH and the command runs with no issues at all so I’m hoping someone could point me in the right direction towards what I’m doing wrong
