Platform information:
- OS: Linux - Ubuntu
- openHAB version: 2
Issue of the topic:
I’m working on OpenHAB and I’m looking to save all items values for each value change. I have already followed a tutorial (openHAB2 & MySQL persistence setup): MySQL is well installed on the PC, the database is well created. Nevertheless, it remains completely empty. Does anyone have a solution? -
Configurations:
ADD-ONS:
MySQL Persistence
JDBC Persistence MySQL
mysql.cfg
# the database url like 'jdbc:mysql://<host>:<port>/<database>' (without quotes)
#mysql:url=jdbc:mysql://192.168.0.102/OpenHAB
#:3306
url=jdbc:mysql://147.252.237.45:3306/OpenHAB
# the database user
user=openhab
# the database password
password=YOURPASSWORD
# the reconnection counter
reconnectCnt=1
# the connection timeout (in seconds)
#waitTimeout=
# Use MySQL Server time to store item values (=false) or use openHAB Server time (=true).
# For new installations, its recommend to set "localtime=true".
# (optional, defaults to false)
localtime=true
# CODE DU SITE: https://community.openhab.org/t/cant-get-persistence-with-mysql-up-help/13273/5
#persistence:default=jdbc
# for Migration from MYSQL-Bundle set to 'Item'.
tableNamePrefix=Item
# for Migration from MYSQL-Bundle do not use real names.
tableUseRealItemNames=true
# for Migration from MYSQL-Bundle set to 0.
tableIdDigitCount=0
mysql.persist
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
//everyMinute : "0 * * * * ?"
//every5Minutes : "0 */5 * * * ?"
//everyHour : "0 0 * * * ?"
//everyDay : "0 0 0 * * ?"
default = everyChange
* Each line in this section defines for which item(s) which strategy(ies) should be applied.
* You can list single items, use "*" for all items or "groupitem*" for all members of a group
* item (excl. the group item itself).
//Items {
// persist all items once a day and on every change and restore them from the db at startup
//* : strategy = everyChange, everyDay, restoreOnStartup
// additionally, persist all temperature and weather values every hour
// gTemperatur* : strategy = every5Minutes, restoreOnStartup
- Errors:
Error: Could not get valid data from REST API
at Request.request [as _callback] (/root/.vscode/extensions/openhab.openhab-0.5.1/serverJS/src/ItemCompletion/ItemCompletionProvider.js:168:18)
at Request.self.callback (/root/.vscode/extensions/openhab.openhab-0.5.1/serverJS/node_modules/request/request.js:185:22)
at Request.emit (events.js:182:13)
at Request. (/root/.vscode/extensions/openhab.openhab-0.5.1/serverJS/node_modules/request/request.js:1161:10)
at IncomingMessage. (/root/.vscode/extensions/openhab.openhab-0.5.1/serverJS/node_modules/request/request.js:1083:12)
at Object.onceWrapper (events.js:273:13)
at IncomingMessage.emit (events.js:187:15)
at endReadableNT (_stream_readable.js:1090:12)
at process._tickCallback (internal/process/next_tick.js:63:19)
