Filter out event of some items in own log file
  • Platform information:
    • openHAB version: 4.0.0.M3
I want to filter out all StateChangeEvents of SurveillanceStation items with .DynamicsnapshotURI. and write them to an extra log. The filtering out works, the events are no longer in the Event.log, the new log file is also created, but nothing is written to the new log file.
Where is the error here?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Configuration monitorInterval="10">
	<Appenders>
		<!-- Console appender not used by default (see Root logger AppenderRefs) -->
		<Console name="STDOUT">
			<PatternLayout pattern="%d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
		</Console>
		<!-- Synology Surveillance Station Binding Event log appender -->
		<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events_surveillance_station.log" filePattern="${sys:openhab.logdir}/events_surveillance_station.log.%i.gz" name="SurveillanceStation">
			<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
			<RegexFilter regex=".*DynamicsnapshotURI.*" onMatch="ACCEPT" onMismatch="DENY"/>
			<Policies>
				<OnStartupTriggeringPolicy/>
				<SizeBasedTriggeringPolicy size="8 MB"/>
			</Policies>
			<DefaultRolloverStrategy max="2"/>
		</RollingRandomAccessFile>
		<!-- Rolling file appender -->
		<RollingFile fileName="${sys:openhab.logdir}/openhab.log" filePattern="${sys:openhab.logdir}/openhab.log.%i.gz" name="LOGFILE">
			<Policies>
			</Policies>
			<DefaultRolloverStrategy max="7"/>
		</RollingFile>
		<!-- Event log appender -->
		<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events.log" filePattern="${sys:openhab.logdir}/events.log.%i.gz" name="EVENT">
			<RegexFilter regex=".*DynamicsnapshotURI.*" onMatch="DENY" onMismatch="ACCEPT"/>
			<Policies>
			</Policies>
		<!-- Audit file appender -->
		<RollingRandomAccessFile fileName="${sys:openhab.logdir}/audit.log" filePattern="${sys:openhab.logdir}/audit.log.%i.gz" name="AUDIT">
			<Policies>
			</Policies>
		<!-- OSGi appender -->
		<PaxOsgi filter="*" name="OSGI"/>
	</Appenders>
	<Loggers>
		<!-- Root logger configuration -->
		<Root level="WARN">
			<AppenderRef ref="LOGFILE"/>
			<AppenderRef ref="OSGI"/>
		</Root>
		<!-- Synology Surveillance Station Binding logger -->
		<Logger additivity="false" level="WARN" name="org.openhab.binding.synologysurveillancestation">
			<AppenderRef ref="SurveillanceStation"/>
		</Logger>
		<Logger additivity="false" level="INFO" name="openhab.event">
		</Logger>
		<!-- Karaf Shell logger -->
		<Logger level="OFF" name="org.apache.karaf.shell.support">
			<AppenderRef ref="STDOUT"/>
		</Logger>
		<!-- Security audit logger -->
		<Logger additivity="false" level="INFO" name="org.apache.karaf.jaas.modules.audit">
			<AppenderRef ref="AUDIT"/>
		</Logger>
		<!-- openHAB specific logger configuration -->
		<Logger level="INFO" name="org.openhab"/>
		<Logger level="ERROR" name="openhab.event.ItemStateEvent"/>
		<Logger level="ERROR" name="openhab.event.ItemAddedEvent"/>
		<Logger level="ERROR" name="openhab.event.ItemRemovedEvent"/>
		<Logger level="ERROR" name="openhab.event.ItemChannelLinkAddedEvent"/>
		<Logger level="ERROR" name="openhab.event.ItemChannelLinkRemovedEvent"/>
		<Logger level="ERROR" name="openhab.event.ChannelDescriptionChangedEvent"/>
		<Logger level="ERROR" name="openhab.event.ThingStatusInfoEvent"/>
		<Logger level="ERROR" name="openhab.event.ThingAddedEvent"/>
		<Logger level="ERROR" name="openhab.event.ThingUpdatedEvent"/>
		<Logger level="ERROR" name="openhab.event.ThingRemovedEvent"/>
		<Logger level="ERROR" name="openhab.event.InboxUpdatedEvent"/>
		<Logger level="ERROR" name="openhab.event.RuleStatusInfoEvent"/>
		<Logger level="ERROR" name="openhab.event.RuleAddedEvent"/>
		<Logger level="ERROR" name="openhab.event.RuleRemovedEvent"/>
		<Logger level="ERROR" name="openhab.event.StartlevelEvent"/>
		<Logger level="ERROR" name="openhab.event.AddonEvent"/>
			<AppenderRef ref="EVENT"/>
		</Logger>
		<!-- openHAB user based script logger configuration -->
		<Logger level="TRACE" name="org.openhab.automation.script" />
		<Logger level="ERROR" name="javax.jmdns"/>
		<Logger level="ERROR" name="org.jupnp"/>
		<!-- This suppresses all Maven download issues from the log when doing feature installations -->
		<!-- as we are logging errors ourselves in a nicer way anyhow. -->
		<Logger level="ERROR" name="org.ops4j.pax.url.mvn.internal.AetherBasedResolver"/>
		<!-- Filters known issues of pax-web (issue link to be added here). -->
		<!-- Can be removed once the issues are resolved in an upcoming version. -->
		<Logger level="OFF" name="org.ops4j.pax.web.pax-web-runtime"/>
		<!-- Filters known issues of lsp4j, see -->
		<!-- https://github.com/eclipse/smarthome/issues/4639 -->
		<!-- https://github.com/eclipse/smarthome/issues/4629 -->
		<!-- https://github.com/eclipse/smarthome/issues/4643 -->
		<Logger level="OFF" name="org.eclipse.lsp4j"/>
		<!-- Filters warnings for events that could not be delivered to a disconnected client. -->
		<Logger level="ERROR" name="org.apache.cxf.jaxrs.sse.SseEventSinkImpl"/>
		<!-- Filters known issues of KarServiceImpl, see -->
		<!-- https://github.com/openhab/openhab-distro/issues/519#issuecomment-351944506 -->
		<Logger level="ERROR" name="org.apache.karaf.kar.internal.KarServiceImpl"/>
		<!-- Filters warnings about unavailable ciphers when JCE is not installed, see -->
		<!-- https://github.com/openhab/openhab-distro/issues/999 -->
		<Logger level="ERROR" name="org.apache.karaf.shell.ssh.SshUtils"/>
		<!-- Filters known issues of javax.mail, see -->
		<!-- https://github.com/openhab/openhab-addons/issues/5530 -->
		<Logger level="ERROR" name="javax.mail"/>
		<!-- Filters disconnection warnings of the ChromeCast Java API, see -->
		<!-- https://github.com/openhab/openhab-addons/issues/3770 -->
		<Logger level="ERROR" name="su.litvak.chromecast.api.v2.Channel"/>
		<!-- Added by Karaf to prevent debug logging loops, see -->
		<!-- https://issues.apache.org/jira/browse/KARAF-5559 -->
		<Logger level="WARN" name="org.apache.sshd"/>
	</Loggers>
</Configuration>
Hello, maybe someone still has suggested solution? :face_with_peeking_eye: :wink:
