my 1-wire-sensors are quity unreliable. I use them via the onewiregpio binding.
Is there any simple possibility to filter the values between a min and a max value? A temperatue of -1000°C is not possible, so I would like such a value to be deleted such that openhab doesn’t see this value.
I could write a rule to filter the values but I think there must be a shorter way. Perhaps map or transform?
(of course the best way is to have reliable sensors but this is not possible at the moment)
Which one would apply in this case? The default ones do’t seem to apply. Perhaps the JS Transform profile ? Or is there something I’m missing. I’ve not used profiles yet.
I cannot understand this. How can I get “no value” if the current value is outside a predifined range? I don’t want to set the value to zero, but I want to ignore the bad value; so no (new) value.
