Hi! I’d like to make the find my phone function of the iCloud binding available via Amazon Alexa. The Alexa skill supports mobile phones, but only for PowerState, BatteryLevel and NetworkAccess. So, I was thinking of creating a scene that triggers the find-my-phone function. Or are there any better ideas out there?
Isn’t PowerState enough let Alexa turn on the findMyPhone trigger switch to trigger the icloud binding function ?
Yes, you are right, not much other use for that property anyway. It works perfectly fine that way, but I was hoping for a more natural language. Something like “Alexa, find Robert’s iPhone” instead of “Alexa, turn on Robert’s iPhone”. But that is a minor detail, happy that it works as it is.
Define that phrase in the Alexa app as a routine and let it turn on the switch for you.
Thanks, I was not aware of that „phrase“ feature, I‘ll give it a try!
You could create a scene as well. Scenes aren’t associated to a specific device on the Alexa side. That’s why these don’t appear under discovered devices. So you wouldn’t define your item as MobilePhone
but just as Scene
, which can be used in a routine as @Wolfgang_S suggested.
Thanks, but so far it works fine with using the MobilePhone
device type and having a phrase to make access to it more natural. Also, my wife uses Android and there we used a dedicated app for this feature with its own Alexa skill. Using another phrase I could make that app accessible via the same language as my iPhone.
