Continuing the discussion from Fine Offset Weather Station Binding: Discussion:
Hi, I did upgrade this week from OH3.x to OH4.2.
Since this upgrade my Weather stations behaves a little bit erratic, to say it polite:
2024-10-14 21:03:58.766 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Read timed out
2024-10-14 21:03:59.824 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
2024-10-14 21:04:36.995 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Read timed out
2024-10-14 21:04:39.611 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
2024-10-14 21:05:21.205 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Read timed out
2024-10-14 21:05:21.234 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
2024-10-14 21:05:42.299 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Read timed out
2024-10-14 21:05:45.431 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
2024-10-14 21:05:50.435 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Read timed out
2024-10-14 21:06:10.569 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
2024-10-14 21:06:33.687 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Read timed out
2024-10-14 21:06:33.712 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fineoffsetweatherstation:gateway:b154b09fe6' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
I tried to remove all three things (the gateway, the weatherstation thing and one additional sensor) and add them again.
This didn’t solve the problem.
Anybody any idea what I’m doing wrong?
When it is connected, it seems to work and delivers reliable values.
Edit: While writing this, I found the solution myself:
The one sensor was low on Battery Voltage, replaced it and the problems are gone.
So maybe someone will find this later useful. If not, then at least I can hopefully find this post if the battery is low again and the things behave the same.
