So far I’ve manage to start an automation to fire last watched TvShow next episode on my Kodi when I returned from Work routine.
But I’m struggling with some parts of my automation rules
What it does:
If switch “Leave work” is on when my presence turn on it:
- T.V. turn on
- Request last TvShows watched (loop until it receive an response
- Take last Tv.Show ID
- With this id it request next episode not watched ID
- With this episode id it fire it on Kodi
- It attempt to pause it (May interfere with my automatic pause on subTitle search and download Kodi AddOn)
Here My rule:
rule "Start Next TvShow Episode"
Item QLexMedia_PartyPlayls received command NextTvShow
var String json ="%7B%22jsonrpc%22%3A%222.0%22%2C%0A%20%22method%22%3A%22VideoLibrary.GetTVShows%22%2C%0A%20%22params%22%3A%20%7B%0A%20%20%20%22properties%22%3A%5B%22lastplayed%22%5D%2C%0A%20%20%20%22sort%22%3A%7B%22order%22%3A%22descending%22%2C%22method%22%3A%22lastplayed%22%7D%7D%2C%0A%20%22id%22%3A1%7D"
var String shows = sendHttpGetRequest("http://192.168.0.199:8080/jsonrpc?request="+ json)
logWarn ("Qtronik old","Last tvShow response: "+shows)
if(shows !== null){
var Number lastTvShowPlayedId =
Integer::parseInt(transform("JSONPATH","$.result.tvshows.[0].tvshowid",shows))
logWarn ("Qtronik old","Last played tvShowId: "+lastTvShowPlayedId)
logWarn ("Qtronik old","next episode is indeed a number")
QLexMedia_lastTvShowWatched.sendCommand(lastTvShowPlayedId)
var String getNextEpisodeLastTvShowJson = "%7B%22jsonrpc%22%3A%222.0%22%2C%0A%20%22method%22%3A%22VideoLibrary.GetEpisodes%22%2C%0A%20%22params%22%3A%7B%0A%20%20%20%22sort%22%20%3A%20%7B%22order%22%20%3A%20%22ascending%22%2C%20%22method%22%20%3A%20%22episode%22%7D%2C%0A%20%20%20%22tvshowid%22%3A%20"+lastTvShowPlayedId+"%2C%0A%20%20%20%22filter%22%3A%7B%22field%22%3A%22playcount%22%2C%22operator%22%3A%22lessthan%22%2C%22value%22%3A%221%22%0A%20%20%20%7D%0A%20%7D%2C%0A%20%22id%22%3A1%7D"
var String nextEpisodes = sendHttpGetRequest("http://192.168.0.199:8080/jsonrpc?request="+ getNextEpisodeLastTvShowJson)
try {
val int episodeToPlay = Integer::parseInt(transform("JSONPATH","$.result.episodes.[0].episodeid",nextEpisodes))
logWarn ("QtronikOld","episodeToPlay: "+episodeToPlay)
var String playEpisodeString = "%7B%22jsonrpc%22%3A%222.0%22%2C%0A%20%22method%22%3A%22player.open%22%2C%0A%20%22params%22%3A%7B%0A%20%20%20%22item%22%20%3A%20%7B%22episodeid%22%3A"+episodeToPlay+"%7D%0A%20%7D%2C%0A%20%22id%22%3A1%7D"
var String playEpisode = sendHttpGetRequest("http://192.168.0.199:8080/jsonrpc?request="+ playEpisodeString)
logWarn ("QtronikOld","Playing episode response: "+playEpisode)
sendCommand(gFF_QLexMedia_Control,"PAUSE")
} catch (NumberFormatException e) {
logWarn("QtronikOld","Episode returned is not a number. Redo NextTvShow")
//TODO if empty json do next lastTvShow watched ------------------------------------------------------
} else {
logWarn ("Qtronik lasttvShowPlayed","Returned null so redo lastPlayedtvShow rule")
QLexMedia_PartyPlayls.sendCommand("NextTvShow")
Here some problems to solve:
- So I am not able to change waiting time for http response some what the paperUI parameters wont save on change…
- If there is no more episodes to play I want to be able to get the next last TvShow watched last episode not played to fireup
- I want to watch it until it pause properly
Finally I am sure that alot of you people would like this type of automation to their routine
