Hi All.
I have a Raspberry pi 3+ Running as a Remote DB . This is basically a Remote io with some smart controls and monitoring. that sends information via MQtt and runs some rule controls via Node Red.
so what I want to do is install FireMotD on it the same as what is on my openhab server as I log in to it via SSH to show me the same information . just the stats of the pi but also the openhab Logo . ?
can I change the wording to add a access clause to it ?
Thanks for all the help we always receive from the Community
Beyond any trouble you may have with it on openHABian, it’s really out of scope for openHAB.
I’m not sure how much help it is, but here is the FISH script I use to install FireMotD on my machines on first login after I’ve changed my default shell to FISH.
function fish_greeting
if not type /opt/FireMotD/FireMotD > /dev/null 2>&1
echo ----Installing FireMotD
sudo apt-get -y install bc sysstat jq moreutils make
echo ----Cloning FireMotD repo
sudo git clone https://github.com/OutsideIT/FireMotD.git /opt/FireMotD
echo ----Making the program
cd /opt/FireMotD
sudo make install
sudo make bash_completion
sudo ./FireMotD -s
echo ----Creating cron to generate/update /var/tmp/FireMotD.json
sudo echo "#!/bin/bash
/usr/local/bin/FireMotD -S &>/dev/null" | sudo tee -a /etc/cron.daily/firemotd >/dev/null
sudo chmod a+x /etc/cron.daily/firemotd
echo ----Configure Apt updates count
sudo echo 'DPkg::Post-Invoke {
"if [ -x /usr/local/bin/FireMotD ]; then echo -n \'Updating FireMotD available updates count ... \'; /usr/local/bin/FireMotD -sru -S; echo \'\'; fi";
};' | sudo tee -a /etc/apt/apt.conf.d/15firemotd >/dev/null
switch $HOST
case argus
set -g _theme red
case cerberos
set -g _theme blue
case chiron
set -g _theme orange
case fafnir
set -g _theme gray
case fenrir
set -g _theme modern
case huginn
case hydra
set -g _theme original
case manticore
set -g _theme red
case medusa
case sibyl
case norns
set -g _theme blue
case penguin
set -g _theme gray
case sirens
case nidhogg
set -g _theme red
case sleipnir
case '*'
set -g _theme invader
bash /opt/FireMotD/FireMotD -HV --theme $_theme
# Theme colors: (256) original, modern, gray, orange, invader (16) red, blue, clean, (HTML) html
I synchronize my fish configs between all my hosts using git so the switch statement at the end chooses a different theme based on the name of the host I’ve logged into. The last line is what actually shows the table of info. You will want this in your .profile or whatever is the right file for bash (or whatever is the right file for your preferred shell).
Thank you! I’ve been trying to figure out how to get FireMotD installed on my other raspberry pi systems that don’t have OpenHAB. I couldn’t figure out why “apt install firemotd” refused to find and add the package for it. I even added the repository and gpg key for OpenHAB hoping it will pull it from there, but still no luck.
I’m essentially a beginner so I’ve been trying to find where it’s installed and see if I could duplicate the steps. Not successful until I found your script so thank you. I attempted to convert your FISH script to BASH. It seems to work so far. LOL.
One question though. I’m confused by this line in your script:
I guess it confuses “make” too since it says there’s no bash_completion target.
