Hi @chris
Thanks for adding the Z-Combo-G Smoke and CO detector to the database so quickly. I updated the binding and the device is discovered properly and I see the expected channels:
- Alarm (System);
- Alarm (Smoke)
- Alarm (CO)
- Battery-level
The item attached to the Battery-level channel updates properly, but I am not getting data in the other items. Each hour, I see a log entry for the detector’s heartbeat with a message: channel alarm_system is not implemented. I’m not sure how to handle this.
2020-09-30 13:34:07.955 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 16: Received COMMAND_CLASS_ALARM V8 NOTIFICATION_REPORT
2020-09-30 13:34:07.956 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 16: NOTIFICATION report - 0 = 0, event=5, status=255, plen=0
2020-09-30 13:34:07.956 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 16: Alarm Type = SYSTEM (0)
2020-09-30 13:34:07.956 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 16: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-09-30 13:34:07.956 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 16: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-09-30 13:34:07.956 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 16: Alarm converter processing NOTIFICATION
2020-09-30 13:34:07.956 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 16: Alarm converter NOTIFICATION event is 5, type OnOffType
2020-09-30 13:34:07.956 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 16: Alarm converter NOTIFICATION event is 5, channel alarm_system is not implemented.
2020-09-30 13:34:07.957 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 16: Alarm converter processing NOTIFICATION
2020-09-30 13:34:07.957 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 16: Alarm converter NOTIFICATION event is 5, type OnOffType
2020-09-30 13:34:07.957 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 16: Commands processed 1.
The binding defines each alarm channel as a switch but the device sends more than on/off messages:
| Event of device | Channel | Notification Type | Notification Event |
| Test detected | Alarm (Smoke) | 0x01 | 0x03 |
| Test clear | Alarm (Smoke) | 0x01 | 0x00 |
| Smoke detected | Alarm (Smoke) | 0x01 | 0x02 |
| Smoke clear | Alarm (Smoke) | 0x01 | 0x00 |
| Smoke silence | Alarm (Smoke) | 0x01 | 0x06 |
| CO detected | Alarm (CO) | 0x02 | 0x02 |
| CO clear | Alarm (CO) | 0x02 | 0x00 |
| CO silence | Alarm (CO) | 0x02 | 0x06 |
| CO End-Of-Life detected | Alarm (CO) | 0x02 | 0x05 |
| Malfunction detected | Alarm (System) | 0x09 | 0x01 |
| Malfunction clear | Alarm (System) | 0x09 | 0x00 |
| Heartbeat | Alarm (System) | 0x09 | 0x05 |
I appreciate your guidance on how I should proceed.
Thanks,
Bruce
